Hey that's exactly what it was, I just figured with two downloads that wasnt it. Thanks a ton, I'm beanin it up right now maeng.Corrupt file
Again thanks a ton, that was the end to a lot of frustration
Posted 29 December 2012 - 12:43 PM
Posted 29 December 2012 - 12:47 PM
Posted 29 December 2012 - 01:18 PM
Posted 29 December 2012 - 02:08 PM
Posted 29 December 2012 - 02:19 PM
ok, so verizon sent me a warranty replacement and I want to stay on ICS with root like I was before the Christmas day change...
which root method should I use for a 1 click method for ICS 4.0.4 that I can 1 click back to stock in case I want to upgrade to JB later? I searched, but there are so many methods I just want to get the latest/easiest one
thanks for all the info, mucho appreciated!
Posted 29 December 2012 - 03:04 PM
Posted 29 December 2012 - 03:50 PM
when I run the utility in AP fastboot mode it comes up, - then when I press "any key" the utility disappears? I have the drivers installedThe 1.82 utility......
sent from my JB RAZR tapadriving
Posted 29 December 2012 - 03:59 PM
I tried to run as administrator also... what am I missing?
Posted 29 December 2012 - 04:18 PM
yes, now the utility runs but it stalls on waiting on phone?Did you completely extract the utility to your desktop?
Posted 29 December 2012 - 04:20 PM
Posted 29 December 2012 - 04:22 PM
"If you truly learned from your mistakes, I would be a genius by now!"
Posted 29 December 2012 - 04:34 PM
yes and yes? I rooted ICS previously and an comfortable rooting because I have rooted several prior to now droid x, bionic, several razr's also.. Im at a lossAre you booted normally and in mtp mode.... and have USB debugging enabled?
Posted 29 December 2012 - 04:39 PM
Posted 29 December 2012 - 05:03 PM
OK when you plug in to the computer let the computer recognize the phone then switch to mass storage mode let the computer recognize the phone then back to mtp mode.... try to run option 2 again.... what this does is makes sure the drivers are fully installed....yes and yes? I rooted ICS previously and an comfortable rooting because I have rooted several prior to now droid x, bionic, several razr's also.. Im at a loss
Posted 29 December 2012 - 05:05 PM
Posted 29 December 2012 - 05:12 PM
I did this by accident to make sure the phone was in mtp mode and then tried again and success!
thanks, I am rooted now it just took multiple reboots and installing drivers again. Do I need the safestrap recovery app? Thanks againChange your windows username.. If you have for example Jack & Jill for a logon name in windows, it will do that to you.. Create a new windows profile, something is wrong with your current one, name it something like Jack with Admin rights and try again..
Posted 29 December 2012 - 05:15 PM
Posted 29 December 2012 - 05:20 PM
Posted 29 December 2012 - 05:26 PM
no, luckily it worked after re-installing the drivers and changing from USB mass storage to mtp and back again. each time I switched it re-installed the drivers.Did you have to change your username, because I had an issue with one user on the same exact thing, and no matter how many times I re-installed and rebooted, remoted into his pc, it wouldn't work until he created a new user account without the "&"
Posted 29 December 2012 - 05:34 PM
