#1001
Posted 28 December 2012 - 05:36 PM
Sent from my Droid Razr Maxx booting JB leak within .211 safe strap. (JB Dual Boot - XT912)
#1002
Posted 28 December 2012 - 05:51 PM
It constantly gets forced into landscape mode, brings up a selection box to choose "webtop" or "mirror on display" and shows a notification in the status bar that an HDMI cable IS detected...
I was wondering if anyone else has noticed this and it could be a possible bug in the webtop app or if I just messed something up.
FYI this problem goes away as soon as you uncheck the box so it is not a big deal...
#1003
Posted 28 December 2012 - 06:02 PM
Anyone that wants the jellybean leak without losing ICS and fast boot ability should checkout JB Dual boot - XT912. It works perfectly and you can use it from .211, .214, or .215 without redoing your whole phone to get there. Just be rooted on ICS with safe strap 3.07 installed and follow the instructions in the thread. This method allows you to go back to ICS again if you want. Does not take you off the upgrade path either.<br /><br />Sent from my Droid Razr Maxx booting JB leak within .211 safe strap. (JB Dual Boot - XT912)<br /><br />
This is not for the OTA LEAK this is for ROMs based off the JB OTA and ICS.
#1004
Posted 28 December 2012 - 06:13 PM
#1005
Posted 28 December 2012 - 06:14 PM
this is what i get Matt
"Have drivers installed, phone connected, and USB Debuggin
r Options."
mount: Operation not permitted
276 KB/s (91992 bytes in 0.325s)
1163 KB/s (1020803 bytes in 0.857s)
cp: /system/xbin/su: Read-only file system
cp: /system/app/Superuser.apk: Read-only file system
Unable to chmod /system/xbin/su: Read-only file system
Unable to chmod /system/app/Superuser.apk: Read-only file s
rm failed for /system/bin/su, Read-only file system
"Rebooting..."
uid=2000(shell) gid=2000(shell) groups=1003(graphics),1004(
(mount),1011(adb),1015(sdcard_rw),1028(sdcard_r),3001(net_b
,3003(inet),3006(net_bw_stats)
If the above id shows 0 then you are rooted. Press any key
Thanks for the help.
anyone know what the hea=ck happened....and why read only file system?
i get it that i will not have root but wanted to understand what happened......
thanks Matt for all the RAZR love!
Robert
#1006
Posted 28 December 2012 - 06:20 PM
Yes but you can install the base rom Hashcode made and have pretty much the same thing.
Just making it clear to anyone who thinks they can have both the leak and the official ICS on the same phone... but yeah you're right.
#1007
Posted 28 December 2012 - 07:11 PM
#1008
Posted 28 December 2012 - 10:32 PM
Has anyone noticed any problems with the webtop on this OTA release? If you go into settings>display>HDMI settings>HDMI connection and you check the box for "enable to detect HDMI cable" the phone automatically goes into HDMI mode and detects an HDMI cable even if there is not one connected?
no such error on my phone.
#1009
Posted 29 December 2012 - 03:07 AM
ps - pls forgive my n00bness...
#1010
Posted 29 December 2012 - 06:20 AM
Does anyone have any Ideas please.
I've never seen this but it keep asking me to set up my yahoo account because that is what is registered with VZW. What a pain because I can't get it to sync and I checked my login and pw over and over.
Surely someone has had a problem like this and fixed it.
#1011
Posted 29 December 2012 - 07:08 AM
#1012
Posted 29 December 2012 - 07:41 AM
Thanks, I just tried that through TiBu and it did not work so I tried going into apps in settings, selected the mail app and "cleared data" and tried to set back up but still not communication.Try clearing data for the email app in Tibu-I had a similar issue adding my hotmail. That solved it.
Is your email app version 4.7?
Does anyone know if this is something that I may have to call Verizon on? It sounds like it has something to do with their server?? not sure HELP, I am screwed if I can't get my work email.
- hawkz28 likes this
#1013
Posted 29 December 2012 - 07:43 AM
No, HDMI cable detect works normally, I can connect to a display and disconnect.
#1014
Posted 29 December 2012 - 08:09 AM
I had no problems with outlook- I haven't been able to get hotmail to work with the native app for a while-Ics included.
#1015
Posted 29 December 2012 - 08:55 AM
Ok I have an update. In despiration I tried shutting down the wifi and set up over strictly verizon and I was able to set up my work email but I have never had any luck with Yahoo even under ICS. It must have been the server over my internet connection preventing the sync!!Correct- 4.7.
#1016
Posted 29 December 2012 - 09:42 AM
Not sure exactly what I did, but the error stop for now.
#1017
Posted 29 December 2012 - 10:40 AM
<p> </p>
<p>I have used Matts Godly utility following the steps scrupulously 4 times now, but keep having the same issue ='(. When trying to install the update packages, install hangs for about 8 seconds and then spits this at me</p>
<p>Verifying update pakage...</p>
<div>E:signature verification failed</div>
<div>Installation aborted.</div>
<div> </div>
<div> Does this make any more sense to some of you other Brothers out here than it does to me? 1♥ </div>
#1018
Posted 29 December 2012 - 11:08 AM
- 8all3r likes this
#1019
Posted 29 December 2012 - 12:30 PM
<p>I have been trying to install jellybean for 2 nights and a day and a half now, an its gotten to the point of just needing to make it worth my time (Again)... ( RAAAURGH) Im kranky to say the least at this point, but far from ready to give up... I have 2 update.zips, 1 was the 96.??.?? some odd 1 an the others name corresponds to the .211 wich looks like it makes more sense but Im of the impression they are the same thing.. </p>
<p> </p>
<div> </div>
Don't know what happened to my post. You can check the file using MD5 checker. The Check sum is on this link
#1020
Posted 29 December 2012 - 12:33 PM
<p> </p>
<div> </div>
Either corrupt file or you are choosing the wrong file on your SD card. Make sure you transferred the correct file (blur_verizon.6.16.211) and then make sure thats the one you are clicking on when you are in recovery and trying to install. If you are doing all that correct, re-download the file and try again after you delete the original file so you dont accidentally select that one again.
- 8all3r likes this
