What is the unbrick procedure you mention? I soft bricked after going to JB and am stuck.
Matt created this unbrick jelly bean utility. Someone said it saved them.
Posted 27 December 2012 - 10:47 AM
Posted 27 December 2012 - 10:49 AM
You said you were successful in the doing the update... what did you do to soft brick? .... and can you still boot into stock recovery?
sent from my JB RAZR tapadriving
Posted 27 December 2012 - 10:51 AM
instead of using matt's utility try downoading the fastboot file and using rsdlite. sometimes people have luck using rsd rather than the utility, and sometimes the utility works better than rsd. different situations i suppose....i used rsdlite to go back to .211, factory reset, root, then followed op directions and worked.try rsdlite see if that does anything different.
Posted 27 December 2012 - 10:57 AM
I stupidly installed Razr Clockwork Modtouch 5.8.4.5 Black Edition without seeing in the first line of the thread that it was for ICS. After installing this I ended up in Clockwork Mod Recovery menu and chose to reboot. The phone reboots and goes through the normal droid animations and then stops with an "Encryption Error". It says the phone needs to be Factory Reset and has a button to do so. Pressing the button reboots the phone and it goes through to the same point. I am able to power off the phone and boot into the Motorola Recovery. Running "wipe data/factory reset" does nothing. I am able to wipe the data, but rebooting brings to same error. I'm stuck.
Posted 27 December 2012 - 10:59 AM
Posted 27 December 2012 - 11:02 AM
Have you tried re running the JB update from recovery...
Posted 27 December 2012 - 11:20 AM
Posted 27 December 2012 - 11:48 AM
Will you be releasing a tool in the near future for JB like the 1.82 I have been using on ICS? I moved on to JB following your direction successfully but have since soft bricked my phone and have no way to factory reset.
Posted 27 December 2012 - 11:50 AM
I assume this is a silly question, but did you make a backup of the stock rom before you changed this? If so, have you tried to restore the backup?Yes. It starts and then aborts.
Posted 27 December 2012 - 12:02 PM
Posted 27 December 2012 - 12:03 PM
Posted 27 December 2012 - 12:15 PM
Posted 27 December 2012 - 12:18 PM
I did the same thing.. Trying to avoid losing data... When you did the unbrick did you lose all your data?
Posted 27 December 2012 - 12:24 PM
That sounds like a "factory wipe." That doesn't erase the sdcard, just the apps and settings in the phone itself.it did not erase my sdcard, but I did have to set the phone up again as if it was brand new. It is running buttery smooth, just needs root and a recovery.
Posted 27 December 2012 - 12:40 PM
Same deal here, but I tried 1.82 and the encryption error went away...now I just get the bootlogo. My battery is charging and then I will try again. I was in the process of using the unbrick utility and then battery fail... RSD'ing to .211 fastboot did not work, error'd out. Wish I could use clockwork on JB for a number of reasons not needed for this thread.
Posted 27 December 2012 - 01:04 PM
maybe try this....... here are the most current Superuser.apk
and the su binaries you can copy and paste them into the folder that contains the utility (or the "files" folder if using the Linux Mac Utility) then ru-run the utility? if you re-reun the utility with these then you will automatically have the current binaries...... i should have suggested that last night but i think my brain was dead LOL.... i will be updating the Linux Mac utility(at least) with these today so everone will have them
Posted 27 December 2012 - 01:10 PM
Motorola's getting slammed on Facebook for this "oops".
Posted 27 December 2012 - 01:17 PM
I saw that too.... bad timing huh
