1212 replies to this topic
#901 johnbrain
johnbrain
  • 101 posts
Posted 27 December 2012 - 09:08 AM
typically a factory wipe does not wipe system (where superuser and su live) it only wipes data so you should not loose root
So Would SU show Back Up After A Factory Reset? Then Download Voodoo And Restore Root? Not Sure Why I Even Care. Just Being Ocd About Deleting A System App.
#902 kmoore81
kmoore81
  • 5 posts
Posted 27 December 2012 - 09:10 AM
Used Droid Utility 1.8.2, followed instructions, worked perfectly and retained root with Voodoo root keeper. Now I just need a 1% battery mod for jb and I will be set!
#903 androidlearner
androidlearner
  • 904 posts
  • LocationPeoria, AZ
Posted 27 December 2012 - 09:34 AM
If you add a notification widget using Widgetsoid it will add a battery percentage to your status bar. Just an option you could try for now. I'm not on JB so Idk if it will work still.
Sent from Razr Maxx running Full Throttle Killer Bean
#904 lazer
lazer
  • 287 posts
  • LocationWestern PA
Posted 27 December 2012 - 09:35 AM
.............. Now I just need a 1% battery mod for jb and I will be set!
Check this thread I had made here --->
A pretty decent alternative (App) for now was mentioned
#905 Yandroid
Yandroid
  • 62 posts
Posted 27 December 2012 - 09:41 AM
Kinda bummed we can't scroll to the left for the quick settings pane :( haha oh well
#906 akeezy
akeezy
  • 11 posts
Posted 27 December 2012 - 09:49 AM
These are the steps I did... Downloaded 3.06, uninstalled 3.05, installed 3.06 apk, opened 3.06, installed all the stuff it asked me to do, rebooted into recovery & backed up stock JB with SS 3.06. You might have skipped one of those steps of it FC.
I don't have any other recovery installed. When I install it, and try to open it then it forces closes before the app even appears
#907 phlogis
phlogis
You have saved my phone, which I'm grateful for. Actually, my phone is running smooth as butter, although I did loose root. Then again, that's a small price to pay for my stupidity. Thanks again Matt, hopefully we'll have root soon and recovery close behind.
I did the same thing.. Trying to avoid losing data... When you did the unbrick did you lose all your data?
#908 johnthehillbilly
Yes su and root access should still be there... and I understand being OCD about deleting system apps.... :) I am (used to be) the same way lol
sent from my JB RAZR tapadriving
#909 The Doctor
The Doctor
  • 205 posts
  • Twitter:@disc_or_die
  • Google+:plus.google.com/104749243954429604279/
  • LocationAnn Arbor
Posted 27 December 2012 - 09:50 AM
Couldn't hold back any longer and pulled the trigger. Had zero issues. Used Matt's utility, rooted, Voodoo'd, and installed. Root came back and I changed over to SuperSU (by Chainfire) and away we go.
Cannot thank this community enough, great work to Matt and everyone else involved (too many to keep track of). This is hands down one of the best sites out there. My advice to anyone thinking of pulling the trigger.....Read the OP...slowly. And then go back to the top and work your way down step by step. I went slow, been mucking around with this for the past few hours but it was worth it. Might not be Jelly Bean, but better than ICS. I think we should really call this....Jelly Cream ;)
Only issues I have had is connecting to exchange, but Im working on it. Wifi and 4g connected right away and my 4g bars are normally where they are at in this area. True test will be when I get home and I teeter on 3g/4g
#910 Animal
Animal
  • 19 posts
Posted 27 December 2012 - 09:59 AM
Will you be releasing a tool in the near future for JB like the 1.82 I have been using on ICS? I moved on to JB following your direction successfully but have since soft bricked my phone and have no way to factory reset.
#911 johnthehillbilly
Posted 27 December 2012 - 10:03 AM
You said you were successful in the doing the update... what did you do to soft brick? .... and can you still boot into stock recovery?
#912 jagman
jagman
  • 90 posts
Posted 27 December 2012 - 10:05 AM
I have the same problem. That and my phone is on speaker at full volume and no matter what I do it stays that way. I was extra careful to follow Matt's directions. The only thing I haven't done is wipe cache and try a factory reset since doing the update. I did get a message when trying to do the update that the SD card needed to be installed, but then I pressed vol up and down at the same time and it then started the update. Kind of weird. I did manage to maintain root but my pulldown looks no different than stock Moto ICS. I'm wondering if I have remains from ICS and a partial update. Can I do a factory reset, rewipe cache and redo the update? Also, my update DL was 329gb, not 331. I redownloaded it from one of the mirrors and it was the same size.
Sent from my Droid RAZR MAXX using Tapatalk 2
I just downloaded the free version of the "AquaMail" email client app and it works fine with this leak so I'd try it if you are having trouble with the native email client. It also has a dark mode and is very customizable so I think it is actually better.
#913 johnnyfrost
johnnyfrost
  • 67 posts
  • LocationWisconsin
Posted 27 December 2012 - 10:18 AM
Ok, this is my third post for the same issue, and while I realize people have day jobs and such, I am hoping that Matt or someone with a "real" clue can help.
Unlike the majority of users here, I am not a N00b and I have read everything multiple times, but still cant get past the Status 7 error (mine is occurring on lte.img.
instead of using matt's utility try downoading the fastboot file and using rsdlite. sometimes people have luck using rsd rather than the utility, and sometimes the utility works better than rsd. different situations i suppose....i used rsdlite to go back to .211, factory reset, root, then followed op directions and worked.try rsdlite see if that does anything different.
  • Yandroid likes this
#914 Ernietum
Ernietum
  • 31 posts
Posted 27 December 2012 - 10:23 AM
Are you going to Motorola recovery or to clockwork recovery. This has to be done in Motorola recovery.
#915 TrueBlueWitt
TrueBlueWitt
  • 17 posts
Posted 27 December 2012 - 10:29 AM
Doesn't have the same launcher as the RAZR M.. If you check in this and other threads, people have figured out how to install it on the RAZR.
#916 kmoore81
kmoore81
  • 5 posts
Battery Circle actually shows 1% whereas the one you suggest does not. Although I do really like the look of your suggested widget better. Will have to keep it in mind once someone creates a 1% battery mod.
#917 Memnoch73
  • 5,016 posts
  • Current Device(s):Pixel 3XL
Posted 27 December 2012 - 10:31 AM
Battery widget reborn does show 1%. I used it for months. Might be a settings check box or reboot needed.
#918 kmoore81
kmoore81
  • 5 posts
Posted 27 December 2012 - 10:33 AM
Yup, found the Motorola hack check box. Thanks!
  • Memnoch73 likes this
#919 Animal
Animal
  • 19 posts
Posted 27 December 2012 - 10:39 AM
I'm running it. Had to do the unbrick procedure and I'm stuck without root though. I'm pretty happy with it.
I've heard people have ringtone and call issues.
Reduced data and WiFi reception
Only cons of the leak whatsoever.
What is the unbrick procedure you mention? I soft bricked after going to JB and am stuck.
#920 BytecodeMe
BytecodeMe
    Private Pile
  • 2,004 posts
  • Twitter:@BytecodeMe
Posted 27 December 2012 - 10:43 AM
I fastbooted some parts of .211 and applied the update in recovery. It was around 2AM so I don't exactly remember. I can give no guarantees, but I would say fastboot .211 and than apply the update in recovery.
