1212 replies to this topic
#801 jtelander
jtelander
  • 134 posts
Posted 26 December 2012 - 06:05 PM
I was like, 'Oh yes I am!' and pulled up the about phone screen to find that I did indeed upgrade to .214. Forgot all about that...
Thanks for pointing out my basic, obvious error. Well, THERE's your problem!
Techno
I read somewhere that there is a handy-dandy utility that will get you to .211.....
just sayin...
#802 mrbelding
mrbelding
Posted 26 December 2012 - 06:08 PM
So I have a slightly different problem than most - the update installs without errors but after reboot I'm still stuck on 4.0.4. Tried both links @ xda and here, used the utility option1/2/ota rootkeeper etc just like the instructions say, multiple data/cache wipes + re-flashing - still on 4.04. :(
#803 neckchop
neckchop
    pluh!
  • 477 posts
  • Locationatlantic City
Posted 26 December 2012 - 06:15 PM
Are you sure you're installing the JB update? Is it possible you've accidentally installed one of the previous leaks by mistake? The name would be the same, as the updates are named after the build you're updating from. Just a thought... :-) in fact, I was worried about doing this exact same thing and went through my memory card with a file manager to remove any previous versions to avoid a mix up.
#804 mrbelding
mrbelding
Posted 26 December 2012 - 06:20 PM
Wish it(I) was that stupid, the md5 matches the link in OP.
#805 neckchop
neckchop
    pluh!
  • 477 posts
Posted 26 December 2012 - 06:21 PM
Sorry man. That kicked it up over my abilities to help. Lol
#806 fr3qu3nc7
fr3qu3nc7
Posted 26 December 2012 - 06:23 PM
this is what i get Matt
"Have drivers installed, phone connected, and USB Debuggin
r Options."
mount: Operation not permitted
*snip*
Thanks for the help.
same here. If i'm just boned cause i'm dumb then not a big deal, i can be patient and wait for a root method!
#807 BladeRunner
BladeRunner
    Chatroom Tech Support
  • 347 posts
  • LocationMaine
Posted 26 December 2012 - 06:35 PM
How's everyone's battery life on this one? I'm seeing some saying great, others saying horrible. Kind of hard to judge battery when I keep messing with it. also, was a pleasant surprise that they update the desk dock clock to the current one I believe is used on the HD versions. I really HATED the one on ICS.
1d 8h 41m 54s, 32% remaining on my Razr maxx, average use.
Sent from my KFJWI using Tapatalk 2
#808 panapress
panapress
  • 11 posts
  • LocationDC
Posted 26 December 2012 - 06:40 PM
corrupt zip file.
Yeap! the zip file was corrupted. I re-download the file and was able to install without any problem. Now on to testing.
Thank you Mattlgroff.
I am now running JB.
#809 jasonwuzthere
jasonwuzthere
Posted 26 December 2012 - 06:55 PM
Thanks, OP!
Used Matt's tool. Didn't even have to redo the tether hack!
If you hit your menu key while in the main screen of handcent it has a "mark all read" option.
#810 TrueBlueWitt
TrueBlueWitt
  • 17 posts
Posted 26 December 2012 - 06:59 PM
My post says Voodoo OTA Root keeper.... not Superuser temp unroot.
Surprised it didn't work?
The Superuser app also has an "OTA Survival" checkbox now.. Should that be checked or unchecked? Anyone know what that does?
#811 liamfm
liamfm
Posted 26 December 2012 - 07:04 PM
Thanks to all the great posts - I'm on JB now.
A couple things I had to do to make it work:
Delete cache for Bluetooth Sharing (was getting FC's)
Delete updates, cache, data for google play store (FC's)
Was getting one related to VZW VMM, but that seems to have gone away.
But...
I would like to get my Picassa albums to pull up in the gallery. Does anyone know how to do this and a confirmation that, if going back to an older version of gallery is the answer, will not ruin the camera?
So far that is the only thing that is wonky.
Thanks!
#812 johnthehillbilly
That is supposed to do the same thing as Voodoo's ota root keeper.... but for this you need to use voodoo...or it will not work...you should leave it unchecked...
#813 fliptwister
fliptwister
Posted 26 December 2012 - 07:28 PM
Thank you Matt for the root fixer utility! great work! I'm making a donation. I updated to JB, did a factory reset, and I was not rooted anymore. This fixed it.
#814 sgtguthrie
sgtguthrie
  • 135 posts
  • Twitter:@sgtguthrie1
  • LocationMichigan
Posted 26 December 2012 - 08:59 PM
I can't for the life of me get the SU binary to update to 3.1.1, can I use superSU instead? Anyone tried it?
#815 Picaso86
Picaso86
  • 64 posts
  • Twitter:DonAndres861
  • LocationNew Jersey
Posted 26 December 2012 - 09:08 PM
we need some more info..... status 7 is quite common ...... :)
Here is the error im getting :
Verifying current system
asserted failed : apply patch check("preinstall/knowyourdevice/Motorola_xt912_battery save 3gp.
E : error in/tmp/sideload package.zip.
Status 7
Installation aborted.
#816 catchbigd22
catchbigd22
Posted 26 December 2012 - 09:17 PM
Status 7
I cleared data and it seemed to fix this problem.
#817 johnthehillbilly
Posted 26 December 2012 - 09:22 PM
i have the updated su binaries .... i will post a link for them and using a root explorer you can copy/paste them to /system/bin ...then reboot..... it worked for me
#818 sgtguthrie
sgtguthrie
  • 135 posts
  • LocationMichigan
Posted 26 December 2012 - 09:24 PM
I would certainly appreciate that :-)
#819 johnthehillbilly
Posted 26 December 2012 - 09:27 PM
here is the link
make sure you use a root explorer, mount file system as r/w then paste to /system/bin ....overwrite if prompted
or if you are familiar with ADB you can push it to /system/bin
#820 johnbrain
johnbrain
  • 101 posts
Posted 26 December 2012 - 09:29 PM
FWIW I was on a custom ROM and kept trying. Didn't work. Then I switched to "Stock Side"/"Safe Side" and had no problem.
  • johnthehillbilly likes this
