1212 replies to this topic
#741 mattlgroff
mattlgroff
    The Dark Knight
  • 2,298 posts
Posted 26 December 2012 - 11:34 AM
successfully downloaded the zip file and saved to ext. SDcard. I get the following error message when I apply the update file
"Finding update package....
Opening update package....
Verifying update package....
E:signature verification failed.....
Installation aborted...."
I unfreeze all bloatware apps with TB. But still getting the error msg. Anyone having the same problem or know how to fix this?
corrupt zip file.
#742 wabmorgan
wabmorgan
  • 236 posts
Posted 26 December 2012 - 11:43 AM
on 12/24 i took the ota upgrade to jb it loaded without a problem. my phone (RAZR MAXX) was not rooted. I cannot use foxfii now, pdanet is working fine. I've read this forum and decided to talk to verizion. they claim this was an official upgrade and it is still under way, they can't or won't return my phone to ics
They can't... there is nothing they can do. There is no way back to ICS. Only way back would be a new phone without the update.
Only other thing you can do is await root for JB,
#743 Dave12308
Dave12308
    "The Don"
  • 4,939 posts
  • LocationSchenectady, NY - 518 Represent!
  • Current Device(s):Motorola X 2014 (AT&T - Biggest MISTAKE! i've EVER made), ASUS Padfone X (Thanks, Kaos!)
Posted 26 December 2012 - 11:51 AM
They shouldn't be calling this an official release, though. Because it definitely wasn't meant to be.
#744 BytecodeMe
BytecodeMe
    Private Pile
  • 2,004 posts
  • Twitter:@BytecodeMe
Posted 26 December 2012 - 11:52 AM
You can tell it wasn't meant to be lol
Not enough polish IMO
  • Nitewolf likes this
#745 hwood464
hwood464
Posted 26 December 2012 - 11:56 AM
Whoever has updated - could you please confirm if any wifi-tether option (foxfi, etc.) works with the JB build? I am holding off until that's confirmed. Losing wifi tethering would not be a "present" to me. :)
Don't know if anyone answered this yet or not but it does work.
After running Matt's How to Restore Root (Only If You Used Voodoo's OTA Rootkeeper!):
I got root back this was the first thing I tried WiFi-Tether works, I am running -- (3.2-beta2 ***BETA***)
  • mhotovec likes this
#746 bobcat54s
bobcat54s
  • 32 posts
Posted 26 December 2012 - 12:04 PM
I upgraded to jb with no issues at all. The only thing I have noticed is all of my pictures have been duplicated. So I all of my folders have doubles. Is there any way to fix this easily?
#747 bobcat54s
bobcat54s
  • 32 posts
Posted 26 December 2012 - 12:05 PM
#748 jerkwad
jerkwad
  • 109 posts
Posted 26 December 2012 - 12:13 PM
Seems as though your posts have doubled too LOL ;-)
  • mixerpilot and mattkilla like this
#749 foxisbubba
foxisbubba
  • 15 posts
Posted 26 December 2012 - 12:15 PM
I have JB stock rom which I sideloaded (from this forum) to from rooted ICS. I used superuser with temp unroot. I lost root, and can't get it back. I have tried the restore root zip with an I/O error?? Can anyone help? TIA - Mike
#750 Picaso86
Picaso86
  • 64 posts
  • Twitter:DonAndres861
  • LocationNew Jersey
Posted 26 December 2012 - 12:19 PM
I got an error: (Status 7) Any ideas?
#751 johnthehillbilly
Posted 26 December 2012 - 12:25 PM
we need some more info..... status 7 is quite common ...... :)
#752 mhotovec
mhotovec
  • 175 posts
  • LocationJacksonville, Fl
  • Current Device(s):Razr Maxx, Asus TF700
Posted 26 December 2012 - 12:34 PM
Thanks for mentioning WiFi-Tether. I couldn't get either FoxFi or PDAnet to work, but this works great. A speedtest.net test just showed 18.7 mbps down and 8.5 mbps up - which is better speed than my Clear hotspot gives me.
For those who are looking, this is what I'm using
#753 jimd1050
jimd1050
  • 47 posts
  • LocationMassachusetts
Posted 26 December 2012 - 12:37 PM
I upgraded to jb with no issues at all. The only thing I have noticed is all of my pictures have been duplicated. So all of my folders have doubles.
I just checked and that DIDN'T happen to me? Weird... all my pics are fine!
Regards, Jim D
#754 johnthehillbilly
Posted 26 December 2012 - 12:46 PM
heres what i have so far..... (i went ahead and updated/upgraded this morning)..... the default WIFI tether works great (assuming you are on the proper plan to use it) .....as of right now, 6 hours 39 min on battery down to 60% (not too bad considering i am not easy at all on my battery, and i am usually plugging in right about now) .... everything seems to be noticeably smoother.... bluetooth is working fine.... GPS (google navigation) seems to be working..... My 4G signal seems a bit weaker right now (usually full bars here at home, and it is only showing 4 of 5 bars) ....WIFI is right on where it usually is while i am at home.. speeds are about the same as they were prior to update.... i have not tried installing a bunch of apps yet, so i cant comment on the performance of certain apps yet.....so far the only oddity is my boot animation has no sound...
Now a repetitive note for those who have not updated yet.... if you are going to update, i recommend that you use Matts 1.82 utility (option 1) to completely go back to stock .211 and make sure you let it wipe data etc when finished....... it is pretty much the only way to ensure that you will have a fresh clean start... ANY little "thing" left over from previous ROMs etc can and probably will stop the install with errors....
enjoy JB goodness!!!
more to come.....
#755 kr8os71
kr8os71
  • 21 posts
  • LocationAustin, TX
Posted 26 December 2012 - 01:09 PM
you'll lose root but might be worth a shot.
You have saved my phone, which I'm grateful for. Actually, my phone is running smooth as butter, although I did loose root. Then again, that's a small price to pay for my stupidity. Thanks again Matt, hopefully we'll have root soon and recovery close behind.
  • johnthehillbilly likes this
#756 SteakNEggs
SteakNEggs
  • 11 posts
Posted 26 December 2012 - 01:11 PM
Can I just wipe/flash from Motorola Recovery or do I have to use Matt's utility to get rid of safestrap and go back to default?
#757 johnthehillbilly
Posted 26 December 2012 - 01:13 PM
you should use the utility (option 1) to fully "nuke and repave"
  • Thach likes this
#758 SteakNEggs
SteakNEggs
  • 11 posts
Posted 26 December 2012 - 01:15 PM
OK Thanks... Hard to download, first one was corrupt :(
#759 Shawn!
Shawn!
  • 67 posts
  • Current Device(s):Note 3
Posted 26 December 2012 - 01:17 PM
If that was any easier it would have been coloring class in preschool. Way to go!
  • Thach likes this
#760 johnthehillbilly
Posted 26 December 2012 - 01:25 PM
I may get bashed or scolded for this comment but....... I love it when someone can admit their own mistakes... and are willing to live peacefully with the results of that mistake... :) thank you that is very refreshing
  • Nitewolf, kr8os71 and The Doctor like this
55 user(s) are reading this topic
0 members, 55 guests, 0 anonymous users
