1212 replies to this topic
#721 The Doctor
The Doctor
  • 205 posts
  • Twitter:@disc_or_die
  • Google+:plus.google.com/104749243954429604279/
  • LocationAnn Arbor
Posted 26 December 2012 - 10:00 AM
Weeelll, I wasn't going to install the leak, but then we got over a foot of snow... So this will let me kill a couple hours. The think I'm going to miss most coming from CNAcore v1 is my status bar toggles. But I guess I can tough it out until TSC or whoever gets some builds out there.
Thanks for all the work!!
trust me....They are already working on it ;)
#722 Skipr
Skipr
  • 6 posts
  • Current Device(s):razr maxx
Posted 26 December 2012 - 10:03 AM
on 12/24 i took the ota upgrade to jb it loaded without a problem. my phone (RAZR MAXX) was not rooted. I cannot use foxfii now, pdanet is working fine. I've read this forum and decided to talk to verizion. they claim this was an official upgrade and it is still under way, they can't or won't return my phone to ics
#723 dtomlin
dtomlin
    Droid Elite
  • 1,557 posts
Well that will be fun trying to get all my apps back without TiBU..
Yeah I'm running the bare minimum until a root method is found. I doubt it will take long. All the other moto jb builds are rooted.
#724 The Doctor
The Doctor
  • 205 posts
  • LocationAnn Arbor
Posted 26 December 2012 - 10:05 AM
Noob question:
If I have safestrap installed, flashed a few ROMs (safe side of course) What is the procedure to update to JB without using Matt's utility?
my common sense tells me to do the following:
1. Toggle back to stock (.211)
2. Disable/remove Safestrap
3. Download the official OTA
4. Use Vodoo to keep my root
5. Update Razr to JB
Will that work?
Yep....The only real catch is you have to be on the OG .211 update. After you update to this new JB leak, I would do one more step and that's a fresh wipe. If there is a trace of previous builds, ROMs, etc, can make for a dirty flash. Do this wipe in STOCK recovery
  • Picaso86 likes this
#725 The Doctor
The Doctor
  • 205 posts
  • LocationAnn Arbor
Posted 26 December 2012 - 10:06 AM
Interesting.........
#726 mhotovec
mhotovec
  • 175 posts
  • LocationJacksonville, Fl
  • Current Device(s):Razr Maxx, Asus TF700
Posted 26 December 2012 - 10:08 AM
I tried PDAnet and it didn't work for me. Did you have to do anything in particular to get it to work?
#727 cmh714
Posted 26 December 2012 - 10:12 AM
First, a HUGE thanks to Matt! Unfortunately for me tho, I cannot seem to get the update to install. I am pretty seasoned at doing the hacks, but cant get this working. I have tried everything I can think of, including reading this and xda-forum for any solution.
I have a Droid Razr Maxx with 211 and nothing much special past that, except for root.
I ran Matts DR 1.82 and reset back to stock 211, re-rooted, installed Voodoo OTA. Checked everything and all seems well. I still have root. I boot into Recovery mode to apply the update, but fail when it tries to update LTE. snippet below...
Updating LTE
assert failed: motorola.motoflash("/tmp/lte.img")
E:error in /tmp/sideload/package.zip
(Status 7)
Installation aborted....
Like I said, nothing special that I did to this phone, so I shouldnt have a problem, but I do. DANG
Matt, or anyone please I would like to get myself updated. Again, as I said already, YES I read everything and followed all steps properly.
TIA!
#728 lte
lte
Posted 26 December 2012 - 10:15 AM
FYI...
Posts in another forum are indicating wifi disconnects and failure to connect occurring and double copies of photos in gallery. also reports of bluetooth disconnecting when apps opened like Gmail and Facebook.
Everything is great except for Handcent SMS said i had unread messages, so i just re-read them and it fixed that.
The duplicate gallery I seem to have fixed, go into each Album and go to the menu | get info on a picture, if gallery crashes, delete that album.
BT has been fine, I believe if people follow the directions to a T, and remember to wipe cache before the install, should go well!
#729 Skipr
Skipr
  • 6 posts
Posted 26 December 2012 - 10:18 AM
No pdanet was working before the upgrade and it worked afterwards
#730 jmdearrasrazr
jmdearrasrazr
  • 10 posts
Posted 26 December 2012 - 10:20 AM
I did not wipe anything, and it went fine, still rooted. (SuperSU)
#731 jdog_12345
jdog_12345
  • 5 posts
Posted 26 December 2012 - 10:27 AM
Works perfect. Thank you so much! I can confirm that the Wifi tether hack also works. For those of you that don't know about this go here...
  • mhotovec likes this
#732 The Doctor
The Doctor
  • 205 posts
  • LocationAnn Arbor
Posted 26 December 2012 - 10:28 AM
Updating LTE
(Status 7)
TIA!
Have you tried to download the file again and try a fresh flash?
#733 cmh714
Posted 26 December 2012 - 10:31 AM
One, its not the file being corrupt, and two yes, I have actually tried that 4 times. The files are fine, MD5 good, its something else. but thx.
#734 noamparn
noamparn
  • 51 posts
Posted 26 December 2012 - 10:33 AM
1. Glad to hear you didn't have problems installing the update.
2. At this time, Foxfi isn't compatible with Jelly Bean on the RAZR/RAZR Maxx. They mention that on their website:
3. Others have reported they were told by Verizon that the upgrade was pushed out accidentally, and was stopped as soon as they discovered that.
4. Once the phone is upgraded to JB, it cannot be reverted back to ICS. There are software / firmware changes that take place that cannot be reversed (it seems). Yor only hope would be for a warranty replacement of the phone.
#735 Skipr
Skipr
  • 6 posts
Posted 26 December 2012 - 10:47 AM
thanks. I guess i'll be watching for a foxfi upgrade, or a way to root jb
#736 panapress
panapress
  • 11 posts
  • LocationDC
Posted 26 December 2012 - 10:49 AM
successfully downloaded the zip file and saved to ext. SDcard. I get the following error message when I apply the update file
"Finding update package....
Opening update package....
Verifying update package....
E:signature verification failed.....
Installation aborted...."
I unfreeze all bloatware apps with TB. But still getting the error msg. Anyone having the same problem or know how to fix this?
#737 jamminjon82
jamminjon82
  • 610 posts
  • Twitter:@jamminjon82
  • LocationGloucester, VA
  • Current Device(s):LG G2, Moto X, Kindle Fire 2,Razr M, Nexus 7, Acer A100
Posted 26 December 2012 - 11:03 AM
matts utility
#738 johnthehillbilly
Posted 26 December 2012 - 11:21 AM
as far as i know.... if thats all the further it got, it didnt start writing (and changing "stuff") in the phone..... you should be able to use option 1 of the 1.82 utility to fastboot back to fresh clean stock.... then when its finished and booted up, you can manually boot into stock recovery and update from sdcard....
#739 dpic
dpic
Posted 26 December 2012 - 11:24 AM
I tried over and over always getting the "E:signature verification failed". I thought I was all stock, but after I used Matt's utility to reload 211 then rooted, the update worked fine.
#740 mattlgroff
mattlgroff
    The Dark Knight
  • 2,298 posts
Posted 26 December 2012 - 11:33 AM
it means your file is corrupted.
