1212 replies to this topic
#681 mhotovec
mhotovec
  • 175 posts
  • LocationJacksonville, Fl
  • Current Device(s):Razr Maxx, Asus TF700
Posted 26 December 2012 - 08:08 AM
I upgraded to jb just fine but i installed the RAZR M homescreen and remembered why i didn't like it. I went searching for it in ES file explorer and deleted it.... so i thought. Is there anyway to get the regular home screen back from the update or can one of you upload the homescreen apk. Many thanks. Sent from my DROID RAZR using Tapatalk 2
Tried to, the forum says I'm not allowed to upload this type of file. Tried to PM you, no luck there either. If you want to PM me with an email address I'll send it there.
#682 The_Chupacabra
The_Chupacabra
  • 115 posts
  • LocationLawton OK
Posted 26 December 2012 - 08:10 AM
Well I am talking about the stock home screen because they are named the same and I picked the wrong one.
#683 doby-nut
doby-nut
  • 114 posts
Posted 26 December 2012 - 08:12 AM
How is bluetooth working ?
#684 Detonation
Detonation
  • 12 posts
  • LocationWI
Posted 26 December 2012 - 08:13 AM
I don't know but I just want my "Circle Battery - Percentage" back in my statusbar.... :o
Any how-to on that?
It's for the Galaxy Nexus but that doesn't matter. Just gotta decompile SystemUI, update battery xml, and add 1% battery images like the directions say.
#685 mhotovec
mhotovec
  • 175 posts
Oh, if you're asking what I think you are - and you've got both installed now.
Go to system > apps > all > homescreen and clear data. Then the next time you press 'Home' it will ask you which launcher you want to use.
#686 mhotovec
mhotovec
  • 175 posts
Posted 26 December 2012 - 08:15 AM
Bluetooth worked fine for me for both phone and music while in my car.
#687 The_Chupacabra
The_Chupacabra
  • 115 posts
  • LocationLawton OK
Posted 26 December 2012 - 08:18 AM
No what I need is the actual apk for the stock homescreen cause I deleted it.
#688 doby-nut
doby-nut
  • 114 posts
Posted 26 December 2012 - 08:30 AM
No, there are no soft keys.
Yes, you can install inverted .apks
Thanks for prompt replies! What a great forum!
Just attempting to confirm everything works and can set up as I am now with inverted calendar, contacts, mms, etc prior to taking the plunge,
#689 lazer
lazer
  • 287 posts
  • LocationWestern PA
Posted 26 December 2012 - 08:35 AM
Lol thanks but that's a bit over my head atm... Was hoping for a "flashable" .zip I could do in SS3 or something?
#690 The_Chupacabra
The_Chupacabra
  • 115 posts
  • LocationLawton OK
If you go into your explorer, system/app/homescreen.apk is what i am looking for.
#691 hbar98
hbar98
  • 28 posts
  • LocationSouthern Illinois
Posted 26 December 2012 - 08:42 AM
Weeelll, I wasn't going to install the leak, but then we got over a foot of snow... So this will let me kill a couple hours. The think I'm going to miss most coming from CNAcore v1 is my status bar toggles. But I guess I can tough it out until TSC or whoever gets some builds out there.
Thanks for all the work!!
#692 FcHsChilD
FcHsChilD
  • 86 posts
  • LocationWellington
Posted 26 December 2012 - 08:43 AM
Where would you like it uploaded?I attached it here but if that doesn't work let me know.
#693 robocuff
robocuff
  • 415 posts
Posted 26 December 2012 - 08:49 AM
If you still have the update file you should be able to unzip it and extract it from there. Then copy it to your /system/app folder and set permissions. In the zip you downloaded you'll find it in the patch/system/app folder. My guess is that's it anyway. Named homescreen.apk.p . My guess is you'll have to rename it to just homescreen.apk.
#694 FcHsChilD
FcHsChilD
  • 86 posts
Posted 26 December 2012 - 08:53 AM
That's what I was gonna tell him too..but all I found in the .zip was the homescreen.odex file.
#695 robocuff
robocuff
  • 415 posts
Posted 26 December 2012 - 08:56 AM
It's in the patch/system/app folder rather than just system/app.
#696 superrelaxx
superrelaxx
  • 921 posts
  • Twitter:jasNwa
  • LocationSeattle, Washington
Posted 26 December 2012 - 08:57 AM
Had some issues with root.
C:\Users\Public\Documents\RAZR_JB_UPGRADE\RestoreRoot>chmod +x RestoreRoot.sh
'chmod' is not recognized as an internal or external command,
operable program or batch file.
I launched the FixRoot.bat and good to go.
There's something exhilarating about working on phones with locked bootloaders. I always get butterflies while doing this unlike working on my SG3! ;)
Thanks for the write-up and support bro!
#697 ericbee
ericbee
  • 15 posts
  • Twitter:magicaldustman
Posted 26 December 2012 - 08:59 AM
Not sure what docs you are reading, but that is for Mac/Linux. chmod is not a Windows command.
#698 FcHsChilD
FcHsChilD
  • 86 posts
Posted 26 December 2012 - 09:00 AM
Ahh..touché completely overlooked that part of your post.
#699 nobreak1970
nobreak1970
    Transition Leader from Rombot
  • 130 posts
  • LocationAlabama
Posted 26 December 2012 - 09:02 AM
It worked for me. I also kept root.
God bless.
#700 The_Chupacabra
The_Chupacabra
  • 115 posts
  • LocationLawton OK
Posted 26 December 2012 - 09:10 AM
I moved, renamed, and set permissions and it said install failed.
