1212 replies to this topic
#621 Brad92
Brad92
  • 624 posts
  • LocationTexas
Posted 25 December 2012 - 08:46 PM
Follow the instructions in the 2nd post
#622 TwoBuells
TwoBuells
  • 153 posts
Posted 25 December 2012 - 08:50 PM
VooDoo never works for me.
I followed Matt's instructions in the second post, got root back. Running great
Great Job Matt!
Better to be a Racer for a moment, Than a Spectator for a lifetime.
#623 a_sty2007
a_sty2007
  • 23 posts
Posted 25 December 2012 - 09:24 PM
Should i uninstall SS3 first, or just fastboot to .211 with Matt 1.82?
#624 Mr. Orange 645
Mr. Orange 645
  • 128 posts
  • LocationSW, Missouri
Posted 25 December 2012 - 09:46 PM
Just use Matt's utility. Follow his instructions EXACTLY and you shouldn't have an issue. Mine went super smooth. Rooted, WiFi tether working, and no bugs yet. Very happy with the update. Not even interested in custom ROMs right now since JB is so smooth. Only customization I did was use ROM Toolbox to delete some bloat and installed Apex Launcher because it seems even smoother than the stock Blur launcher.
#625 youknowhim
youknowhim
Posted 25 December 2012 - 09:50 PM
What a great xmas present! Love how gmail now shows waaay more lines of text in the notification area when a new email arrives!!! Fast motion pictures of the kids have improved 25% or better.
#626 Adevos
Adevos
  • 62 posts
  • LocationVirginia
  • Current Device(s):Droid RAZR xt912
Posted 25 December 2012 - 09:58 PM
Sorry for the noob question,
I have restored to stock using 1.82 utility, rooted and have loaded the update zip onto my ext sd card. I am back in the stock recovery where you can select "AP Fastboot" and "Recovery"...when I choose "Recovery" it goes to the screen with the green guy laying on his side with the red triangle and exclamation point....what do I do from here?
Basically everything is ready to load the new update I just can't figure it out from the stock recovery program.. Thanks in advance!
#627 Detonation
Detonation
  • 12 posts
  • LocationWI
Posted 25 December 2012 - 09:59 PM
Just got done upgrading. Was on .211 rooted with some bloat frozen/removed. I ended up having to fastboot restore .211 to get the update to work (regular factory reset wasn't enough). But I used OTA rootkeeper to restore root after updating and all is good right now.
Anyways, everything works great and it's nice to see them moving closer to AOSP, but they've removed some Blur things I actually used. Alarm is now straight AOSP - no more "use increasing volume" option or built in timer (still angry about the GB to ICS alarm too, GB alarm was great). Sticky Note and some other Blur widgets are gone. Hopefully this is just an early build and some of these missing things will be added back in.
#628 Detonation
Detonation
  • 12 posts
  • LocationWI
Posted 25 December 2012 - 10:00 PM
Press Vol Up + Down to show menu, Scroll with Vol, Select with Power
#629 orateam
orateam
  • 120 posts
Posted 25 December 2012 - 10:06 PM
For those who lost root, give me the out-put on the screen if it doesn't work:
Windows Only
Note: Don't have USB Mass Storage enabled.
Note 2: I reuploaded it with a fixed root checker for the end.
as always Matt, thanks. I like many here rushed to get JB installed and did not update SU files prior. Your fix worked great. Root granted fully afterwards and all my root apps worked as expected. You save the day again and again.
by the way, i had a rom with circle widgets backed up with Titanium and just restored the circle widgets. No go. Says circle widgets do not work on a 3rd party launcher. so apparently circle widgets must only work on a certain blur launcher version.
#630 sherri
sherri
  • 288 posts
  • Twitter:sherri64
  • LocationMy own personal hell....
Posted 25 December 2012 - 10:10 PM
Someone pulled the RAZR M launcher and circle widget. I have them in a zip file. Zip has 4apk's (launcher/circles widget/weather/time).
I have them running on RAZR Maxx using FT Killer Bean ROM. (I needed an AOKP ROM, so I am not updating....)
Disappointed and hurt. Not surprised.
#631 usmcamgrimm
usmcamgrimm
    Berserker
  • 958 posts
  • Twitter:@usmcamgrimm
  • LocationMassillon, OH
  • Current Device(s):VZW G3
Posted 25 December 2012 - 10:15 PM
About to take the plunge...I just can't help myself!
  • hectorlumbago likes this
#632 Adevos
Adevos
  • 62 posts
  • LocationVirginia
Posted 25 December 2012 - 10:21 PM
Thank you, one last one, is it okay to install this off of your ext sd card (I just stored it in a random folder there) or do you have to install it off of "cache"...
#633 MahoVader
MahoVader
  • 27 posts
  • Current Device(s):RAZR MAXX HD
Posted 25 December 2012 - 10:23 PM
Thanks so much, Matt! Followed the OP and it worked like a charm! Used your utility and went back to a clean slate (fixed the error caused by safestrap), then used your root zip. Perfection!
Question: Isn't JB supposed to have the ability to put widgets on the lock screen, or did I dream that?
#634 jeppes
jeppes
Posted 25 December 2012 - 10:30 PM
Did yall see there is no weather app in this jelly bean update i installed the razr m homescreen circle widget app and weather app without out root and it works
#635 a_sty2007
a_sty2007
  • 23 posts
Posted 25 December 2012 - 10:43 PM
Do all work well? especially bluetooth?
#636 usmcamgrimm
usmcamgrimm
    Berserker
  • 958 posts
Posted 25 December 2012 - 10:48 PM
It needs to be on your ext SD card
#637 usmcscott
usmcscott
  • 19 posts
Posted 25 December 2012 - 11:33 PM
I guess nobody knows how to fix the reoccurring ( error: more then one device and emulator) ...I keep getting..I just want root back lol.
Every time I run fix root it sais that
#638 theatomizer90
theatomizer90
  • 19 posts
  • LocationSoutheastern AZ
  • Current Device(s):Droid Razr, SIII, Note 10.1
Posted 25 December 2012 - 11:38 PM
Success for me!
#639 withmenilu
withmenilu
  • 6 posts
I advise all of yáll not to.. this screwed up my wifi as well as sound :-( waiting for a workaround from Matt...
#640 nailbomb3
nailbomb3
  • 195 posts
Posted 25 December 2012 - 11:58 PM
You'd think everyone would have learned after last summers ics leaks that couldn't be fast booted lol..nope.
