1212 replies to this topic
#561 Krunk_Kracker
Krunk_Kracker
  • 160 posts
  • Twitter:Krunk_Kracker
  • Google+:https://plus.google.com/u/0/113737551782095597526
  • Current Device(s):Droid RAZR MAXX, 32gb Nexus 7
Posted 25 December 2012 - 02:42 PM
Can anyone tell me if this update has "Hebrew" as one of the available input languages?
It's available on the stock keyboard
#562 djholograf
djholograf
  • 85 posts
  • LocationSouthern California
  • Current Device(s):Motorola Droid RAZR XT912
Posted 25 December 2012 - 02:48 PM
Anyone having an issue with email?
I seem to be having a hard time setting up my email accounts...and deleting an existing account. Keeps saying an error has occured and can't delete.
#563 Dr0idDR
Dr0idDR
  • 43 posts
Posted 25 December 2012 - 02:49 PM
I'm having a time here. I of course learned I can't do this on Windows 8. (I just HAD to upgrade.) I hopped on a vista pc and it's saying "adb is not recognized as internal or external command operable program or batch file".
I installed drivers
Windows Vista 64bit
I finally got it to run option 1, but it gives me that error any time I try to root it. Grrr.
lol I should have tried this first.
I renamed adb.exe to adb.exe.exe rebooted, renamed it back to adb.exe and now it's working.
Thanks for the help Dr0idDR
#564 Dr0idDR
Dr0idDR
  • 43 posts
Posted 25 December 2012 - 02:53 PM
You're so welcome!!!
#565 mvp4him3
mvp4him3
  • 231 posts
  • Current Device(s):Nexus 7, RazR MAXX
Posted 25 December 2012 - 02:57 PM
driver issue? the 1.82 utility does have a folder with the driver
I already ran that for my 64bit so that could not be it.
#566 lazer
lazer
  • 287 posts
  • LocationWestern PA
I wiped cache as you suggested but to no avail. I'm also running .211. Here's the error message it gave me
"Verifying current system...
assert failed: apply_patch_check("/system/bin/logwrapp
er", "f39fcbd278b9e92e9fbedc6a62a047dc23459416", "4a63
fec78956def045b442910a754fa640db8f5a")
e:error in /tmp/sideload/package.zip
(status 7)
Instalation aborted."
Same error here. I apologize if it's been answered I'm reading on from page 6 to current #19 :huh:
#567 wabmorgan
wabmorgan
  • 236 posts
Posted 25 December 2012 - 03:05 PM
Anybody tried the exploit from Dan Rosenburg for root?
didn't work. :-(
#568 jburchii
jburchii
  • 48 posts
  • LocationCharlotte, NC
  • Current Device(s):Droid Razr xt912
Posted 25 December 2012 - 03:08 PM
Did someone say they used Matt's 1.81 to REVERT BACK to ICS ---- AFTER installing this update?
#569 ruokuo
ruokuo
  • 10 posts
Posted 25 December 2012 - 03:13 PM
I believe it should be caused by SS3. Best to fastboot back to stock 211 (root and save root), then update again.
#570 mvp4him3
mvp4him3
  • 231 posts
Yep second this or third or fourth
(status 7)
#571 lazer
lazer
  • 287 posts
Posted 25 December 2012 - 03:14 PM
Hrmm, Could be it. I am running with SS3. Any way to regain it and my installed "Slot" roms back in order after this process?
#572 lte
lte
Posted 25 December 2012 - 03:20 PM
Right now running
got root back, didnt even lose any charge still at 70% kept it plugged in :)
cleared cache before update, probably helped!
Thanks everyone for the info and instructions...
LTE is working fine so far, going to see if it drops out like it did on ICS.
& WiFi Tether for root users is working!
#573 Thach
Thach
    Motorola Fanboy
  • 2,364 posts
  • Twitter:thach2639
  • Google+:Thach26
  • LocationGrand Forks ND
Posted 25 December 2012 - 03:21 PM
I know a lot hate to hear this but going back to .211 with Matt's utility is the easiest way to avoid most of the issues we see. I hate doing it myself but on updates like this I always do. It gives me a little more peace of mind when I do it this way and reduces my chances of having problems. Now I am not saying this is the guaranteed way to do things with no problems so please don't think that. I just know that a lot of us, myself included tend to do things between updates that could cause a failure without us thinking about it or remembering.
  • SnoDrtRider, disturbed58, DarkOverDroid and 3 others like this
#574 Dr0idDR
Dr0idDR
  • 43 posts
Agreed I assumed since I was on .211 and stayed there I would be fine. I kept getting that status 7 error. FINALLY I decided hmmm let me do what the op actually says and fastboot back and all.
It's updating to JB now with no issue.
#575 samwelborn
samwelborn
  • 21 posts
  • Twitter:@samwelborn
Posted 25 December 2012 - 03:24 PM
I installed drivers
Windows Vista 64bit
I have windows 8 64 and it works for me!
#576 jburchii
jburchii
  • 48 posts
Posted 25 December 2012 - 03:26 PM
Noob question: why can we NOT use Matt's Utility 1.81 to go BACK to ICS? What happens when you update that makes the revert not possible? I thought that the RU wiped all the files then re-wrote them?
Yeah, I have absolutely no idea how it works.
#577 MattyP
MattyP
  • 86 posts
  • LocationIn a Race Car
Posted 25 December 2012 - 03:39 PM
I'm no expert but my guess is differences in the kernel and or bootloaders between the two systems. That's why you couldn't go back to Gingerbread once you updated to ICS. One of the experts can probably weigh in and shed more light on it. :)
Rooted Razr Maxx!!
#578 DarkOverDroid
DarkOverDroid
    DROIDOSAPIEN
  • 502 posts
  • Twitter:@DarkOverDroid
  • Google+:DarkOverDroid@gmail.com
  • LocationMobile, Al
  • Current Device(s):DROID RAZR MAXX HD, DROID RAZR MAXX, iPhone 4, Galaxy Tab 2 10.1 (WiFi) 7" Acer Iconia Tab A-100 (Wifi)
+1
#579 lazer
lazer
  • 287 posts
Posted 25 December 2012 - 03:44 PM
Okay as suggested. Starting from scratch using DroidRazrUtility and FB back then proceeding with Root and hopefully did "Voodoo-Root Keeper" correctly, (time will tell) as my system seems to be processing the update now and proceeding.
? = Can I install SS3 and get back into my previous ROMS from this or am I porked? :P
#580 johnthehillbilly
Posted 25 December 2012 - 03:46 PM
basically... the update/upgrade changes the filesystem and partitions and the "order of operations" .... each of the utilities are set up to run in a specific order based on the filesystem and partitions ......
