1212 replies to this topic
#481 MattyP
MattyP
  • 86 posts
  • LocationIn a Race Car
Posted 25 December 2012 - 10:51 AM
It will be just like a new phone. (Execept your SD card, It` will not touch it.)
Thank you Dark! :)
Rooted Razr Maxx!!
#482 DarkOverDroid
DarkOverDroid
    DROIDOSAPIEN
  • 502 posts
  • Twitter:@DarkOverDroid
  • Google+:DarkOverDroid@gmail.com
  • LocationMobile, Al
  • Current Device(s):DROID RAZR MAXX HD, DROID RAZR MAXX, iPhone 4, Galaxy Tab 2 10.1 (WiFi) 7" Acer Iconia Tab A-100 (Wifi)
Posted 25 December 2012 - 10:52 AM
does any of the strapped recoveries work w/ this? i want to install the extra gov's as well on this..
Safestrap 3.05 will install, Create slots, and Flash, but I have not tried any tweaks yet to see if they take.
#483 DarkOverDroid
DarkOverDroid
    DROIDOSAPIEN
  • 502 posts
Posted 25 December 2012 - 10:53 AM
Thank you Dark! :)
No prob!
#484 CLoft2620
CLoft2620
  • 64 posts
  • LocationOklahoma
Posted 25 December 2012 - 10:58 AM
No one's gonna make it flashable..
Ah, guess my decision is made then lol. That was simple.
Sent from the Titanic. I named my phone "The Titanic" so when I plug it into the computer it says "The Titanic is syncing".
#485 dave8311
dave8311
Posted 25 December 2012 - 11:00 AM
Your pretty much stuck until then yeah.
I have the same situation.
Is there another root method that might work? I would be willing to try it.
#486 MattyP
MattyP
  • 86 posts
Posted 25 December 2012 - 11:05 AM
Last questions before I jump off this cliff ... do I wipe cache and data BEFORE downgrading back to .211 with the 1.82 utility or AFTER?
And do I reinstall all my apps and root before I side load or just do the root/temp unroot/root and sideload before re-installing apps?
(Especially the Hotspot hack with SQLite, do I run the hack before sideloading or does it have to be done after)
I want to do this right the first time ... :)
Rooted Razr Maxx!!
#487 mvp4him3
mvp4him3
  • 231 posts
  • Current Device(s):Nexus 7, RazR MAXX
Posted 25 December 2012 - 11:09 AM
error in /tmp/sideload/package.zip (status 7) that is what I am running into matt. I read your post and I believe it is because I am rooted. I am trying to pull the update from my sd card in moto recovery. I did the voodoo thing and made sure I was not temp unrooted while trying to unzip the update. I am thinking that it has something to do with maybe I need to be temp unrooted?
#488 DarkOverDroid
DarkOverDroid
    DROIDOSAPIEN
  • 502 posts
Posted 25 December 2012 - 11:23 AM
The utility will give you the option to wipe data/cache at the end. root/temp un-root first. Restore apps after sideload and setup. Run the hack after you boot into JB and restore root.
  • MattyP likes this
#489 BytecodeMe
BytecodeMe
    Private Pile
  • 2,004 posts
  • Twitter:@BytecodeMe
SS3 works just fine, but we dont have any updater-script yet, so we cant flash anything. Gotta push it using abb.
#490 mr4r4n
mr4r4n
    OSE-DEV
  • 210 posts
  • Twitter:Cobra_CMDR_47
  • LocationNYS
Posted 25 December 2012 - 11:25 AM
thanks i thought it did because bytecode was talking bout using hotplugx
Uploaded with ImageShack.us
#491 BytecodeMe
BytecodeMe
    Private Pile
  • 2,004 posts
Posted 25 December 2012 - 11:28 AM
Wait, I said hotplugx? I meant hotplug lol Do they still work? lol
#492 DarkOverDroid
DarkOverDroid
    DROIDOSAPIEN
  • 502 posts
YW, See Bytecodes post about using ADB to push instead of recovery for now.
#493 DarkOverDroid
DarkOverDroid
    DROIDOSAPIEN
  • 502 posts
Posted 25 December 2012 - 11:29 AM
Lol, You also said abb :blink: :D
#494 MattyP
MattyP
  • 86 posts
The utility will give you the option to wipe data/cache at the end. Restore apps after sideload and setup. root/temp un-root first. Run the hack after you boot into JB and restore root.
I have my apps and data backed up to Google, so if I remember correctly it will start re-installing my apps after I boot back up on stock .211 ... so I need to root and temp unroot then go straight to recovery and sideload the update after downgrading to .211 correct?
Rooted Razr Maxx!!
#495 mr4r4n
mr4r4n
    OSE-DEV
  • 210 posts
  • LocationNYS
Posted 25 December 2012 - 11:30 AM
who knows.. il try it, whatsw the worst that could happen :P
#496 BytecodeMe
BytecodeMe
    Private Pile
  • 2,004 posts
Posted 25 December 2012 - 11:31 AM
Should check my spelling before I post lol
#497 DarkOverDroid
DarkOverDroid
    DROIDOSAPIEN
  • 502 posts
Posted 25 December 2012 - 11:33 AM
Correct, and As long as you don`t setup your Google account in .211 it won`t download your apps. You can setup once your on JB. Make sure you have SU updated also.
#498 MattyP
MattyP
  • 86 posts
Posted 25 December 2012 - 11:35 AM
AWESOME!! Thanks Dark!! Wish me luck ... Here goes nothing!! LOL :D
Rooted Razr Maxx!!
#499 DarkOverDroid
DarkOverDroid
    DROIDOSAPIEN
  • 502 posts
Posted 25 December 2012 - 11:37 AM
YW. Please remember to update SU in .211 before you temp unroot/root
#500 DarkOverDroid
DarkOverDroid
    DROIDOSAPIEN
  • 502 posts
Posted 25 December 2012 - 11:41 AM
Also, as per Matt`s instructions, Do not temp unroot before side loading, and be sure to go back into VooDoo OTA Rootkeeper and restore root once booted into JB.
  • MattyP likes this
