Quadrant was 2900. Not bad for straight stock.Benchmarks anyone?
Sent from my KFJWI using Tapatalk 2
Posted 25 December 2012 - 10:13 AM
Posted 25 December 2012 - 10:21 AM
Posted 25 December 2012 - 10:26 AM
Can score 3200 debloated w/ hotplugx + noop and GPU 2D rendering plus HW overlays enabled. Had some other kernel and memory tweaks in there too, but that shouldn't matter too much.
Posted 25 December 2012 - 10:28 AM
Posted 25 December 2012 - 10:30 AM
No one's gonna make it flashable..I really am having a crisis here!
I can't decide if I should install now, or wait until somebody makes it flashable.
Arrrrg I hate decisions!
Sent from the Titanic. I named my phone "The Titanic" so when I plug it into the computer it says "The Titanic is syncing".
I`ve got SS3 installed, and I`ve tried serveral different AOKP/CM10 and Cna Roms, They all flash good, but never boot up. I`m guessing it`s because of kernel changes. On the other hand, I have not tried any .211 based Roms yet. I`ll give them a shot a lil` bit later and see what the outcome is. Thanks for the idea!If you folks remember the .75 and .79 OTA Leaks, we still had the old GB kernel with the benefits of ICS. This is the same thing except this breaks the CDT.bin. SafeStrap should technically run on this as well and I am not sure why you couldn't run all your older ROMs (.211) on SS3 while being on this leak.
Unless I am missing something.
X
Posted 25 December 2012 - 10:31 AM
This tells you that you weren't rooted to begin with.... or you didn't back it up.I know Matt's been in the chat trying to resolve the lost root issue, but if anyone could put any possible solutions into the thread, that would be an immense help.
I am still getting this with the RestoreRoot...
"Have drivers installed, phone connected, and USB Debugging enabled in Developer Options."
/system/bin/sh: su: not found
368 KB/s (91992 bytes in 0.244s)
363 KB/s (1020803 bytes in 2.742s)
"Rebooting..."
If the above id shows 0 then you are rooted. Press any key to exit.
Thanks guys! Merry Christmas and happy holidays to all!
Use a new window in Firefox.Anyone else having a problem with the chat? Its been stuck on "Please wait while we load the chatroom."
Posted 25 December 2012 - 10:32 AM
"Rebooting..."
Posted 25 December 2012 - 10:34 AM
Posted 25 December 2012 - 10:35 AM
I'm talking about the Hotspot app hack done with the SQLite Editor ... where the "entitlement check" is changed, I need to make sure that is going to work before I jump into JB ... that's my main concern.
Posted 25 December 2012 - 10:37 AM
Your pretty much stuck until then yeah.Im almost positive that I went through the entire process and backed up, but I could very easily have forgotten to. In that case, im stuck until a root exploit is found for JB?
Theres no way I can manually root by pushing via ADB? I also have access to the root directories from within ES File Explorer, if that can possibly help.
Posted 25 December 2012 - 10:38 AM
Posted 25 December 2012 - 10:39 AM
May I ask what you did? Can you load init.d script's and extra governors on the stock side?.
Sorry for sounding newbish, used to doing this on safe side.
Posted 25 December 2012 - 10:41 AM
It will be just like a new phone. (Execept your SD card, It` will not touch it.)When I run the 1.82 utility will it make any difference having Bootstrap installed on my phone or will the utility take the phone all the way back to bone stock .211?
Posted 25 December 2012 - 10:44 AM
Posted 25 December 2012 - 10:46 AM
Posted 25 December 2012 - 10:47 AM
Posted 25 December 2012 - 10:49 AM
V6 Supercharger minfrees, background writeout tweaks... well... you'll get it eventually, I'm gonna be releasing leak ROMs that don't have much work in them tbh Just what I'm running lol
