#381
Posted 25 December 2012 - 05:23 AM
#382
Posted 25 December 2012 - 05:35 AM
No, mine updated fine. You don't have another file named the same on your SD card? LIke the .215 update that you're selecting by mistake?Is anyone having a problem with installing update and still being on 4.0.4 after reboot
#383
Posted 25 December 2012 - 05:46 AM
This SHOULD restore root lol
Worked for me, thanks mucho! Good to know I have root back even though I don't REALLY need it. I just used it to use sqllite for hotspot and I like to use adfree/adaway too. I get a force close on a backup assistant file, someone said they erased data and now it's not giving a force close, but I don't know if it it's worth it to re-set everything up.
I was thinking "Oh yea, Jelly Bean, now we get Photosphere!" Then I realized, crap, that's under 4.2. I wonder with JB now if someone can put something together to get Photosphere installed/working? I've noticed that that was possible, but only with an ASOP rom, something like that.
#384
Posted 25 December 2012 - 05:54 AM
This is not the case.
Sent from my Transformer using Tapatalk 2
that is what i thought.
Rockin' it with SS3.05,Ikream 2.9, Licorice CM10 and Tapatalk
#385
Posted 25 December 2012 - 06:05 AM
#386
Posted 25 December 2012 - 06:07 AM
Thanks for the Head's Up about SS3. I did install it and made a backup last night. It seemed to work fine but then I haven't needed to try a restore.
#387
Posted 25 December 2012 - 06:19 AM
Curious what version she has, can you post what version she received this morning?
Ditto.
#388
Posted 25 December 2012 - 06:26 AM
- trikotret, hectorlumbago, mrmuggyd and 5 others like this
#389
Posted 25 December 2012 - 06:32 AM
i used it ,but did not root for 4.1.2Worked for me, thanks mucho! Good to know I have root back even though I don't REALLY need it. I just used it to use sqllite for hotspot and I like to use adfree/adaway too. I get a force close on a backup assistant file, someone said they erased data and now it's not giving a force close, but I don't know if it it's worth it to re-set everything up.
#390
Posted 25 December 2012 - 06:38 AM
#391
Posted 25 December 2012 - 06:39 AM
Is that how moto builds this stuff? I checked the Razr HD forum and saw from screenshots of their jelly bean it does say 3.0.31 as the kernel, whereas our ICS is 3.0.8. But why would they be working on, essentially, an ics-based jelly bean rom? or is the kernel updated later?It is the same base kernel version (3.0.8) and is the incorrect version for JB. This is because this was never meant for release. JB is technically supposed to be based on a Linux 3.0.31
This accidentally released build you guys are running is working off the same principal a Cyanogen/AOKP build does. It takes advantage of the fact that the ICS kernel and JB kernel are technically compatible.
#392
Posted 25 December 2012 - 06:41 AM
yes,but many of my app data ...Y.YAlright...so far no root for this update unless we use ota root keeper or this restore root thingy...right?lol...I will just wait patiently cuz a root for it will come soon...Merry Christmas everyone.
#393
Posted 25 December 2012 - 06:50 AM
#394
none of your posts make any sense and are getting less and less helpfulyes,but many of my app data ...Y.Y
- bjoestanley and samwelborn like this
#395
Posted 25 December 2012 - 06:56 AM
lolnone of your posts make any sense and are getting less and less helpful
Sent from my KFJWI using Tapatalk 2
#396
Posted 25 December 2012 - 06:59 AM
#397
Posted 25 December 2012 - 07:03 AM
#398
Posted 25 December 2012 - 07:16 AM
i didnt update su binary. thought i did before i flashed the update but apparently not. is there a fix or do i have to wait? the update took and everything works except root.
#399
Posted 25 December 2012 - 07:18 AM
Do i just flash in recovery?
#400
Posted 25 December 2012 - 07:21 AM
