1212 replies to this topic
#261 Saik0Shinigami
Saik0Shinigami
  • 12 posts
  • Twitter:Saik0Shinigami
  • Google+:Saik0Shinigami
Posted 24 December 2012 - 07:03 PM
So far these are all the broken things I've run into and would appreciate if someone else can confirm or if I just got a bad flash. To clarify, I used the method mattlgroff posted and have root.
Lock screen missing on all settings
Notification bar shows nothing but time, settings icon, and Verizon branding
Home and Search button so not respond what-so-ever (not touch sensor, cease to function on webdock as well. INCLUDING the software home button)
Vibrate doesn't seem to function
Power off menu doesn't have anything except power off...
seemingly random 4G and WiFi reception drops (not to 0 bars... but down to 2 bars from maxed out for no reason)
These are just a few things I've noticed in the few minutes I've been running this update. I'm going to assume that a factory reset will drop my root like every other build so I don't particularly want to do that.
#262 BytecodeMe
BytecodeMe
    Private Pile
  • 2,004 posts
  • Twitter:@BytecodeMe
Posted 24 December 2012 - 07:12 PM
What do you mean its missing in settings?
That's what the status bar is supposed to do...
All soft keys work perfectly for me
Don't know about vibrate
Power Menu also has airplane mode and volume toggles
Not getting drops, just signal isn't as good.
You got some weird problems with your build lol
#263 Steeleio
Steeleio
  • 18 posts
  • Twitter:@steeleio
  • LocationColorado
Posted 24 December 2012 - 07:15 PM
I removed SS and followed the instructions in the OP. Once the update was done, I reinstalled SS. I was setting up my rom slots again and made the mistake of rebooting with one of the rom slots selected instead of the stock slot. I tried to go back into recovery and factory reset but that just made things worse. When I tried to go back into recovery, it showed the tipped over android but would not bring up the menu to let me select anything. So I figured I was screwed so I tried something drastic...the 1.82 utility. I went into AP fastboot and ran the utility. It showed the files being written for .211 but I kept thinking there is no way this is going to work. Once the utility finished, I rebooted the phone and it showed the update screen with the android with the thing spinning in its chest. The phone rebooted and just sat at the Motorola screen. I rebooted again into recovery and this time it showed me the menu. I chose to apply the update again and to my surprise and answering a bunch of prayers, it restored my phone to the JB update! Of course I don't have root now but at least I'm not bricked.
  • theatomizer90 likes this
#264 mr4r4n
mr4r4n
    OSE-DEV
  • 210 posts
  • Twitter:Cobra_CMDR_47
  • LocationNYS
Posted 24 December 2012 - 07:19 PM
i got it installed and while im no stranger to rooting and temp unroots and the whole process, even though voodoo sees it, it keeps on hanging w/ restoring root, supersu accepts but when i open supersu says binary isnt installed,and then reg superuser when i installed it and disabled reg su nogo for either
Uploaded with ImageShack.us
#265 Saik0Shinigami
Saik0Shinigami
  • 12 posts
On all settings... as in the lock screen doesn't appear when set to pin, slide, password... etc.
So it's supposed to be blank and not show any notifications? Didn't think so.
Probably a bad flash then... I'll try to factory reset and see how that goes. Else I guess I'll be trying out some fastboot.
#266 jayb
jayb
  • 19 posts
Posted 24 December 2012 - 07:24 PM
Thanks a million times Matt.................Just updated both of my Razr's and kept the wifi tether from verizon using the 1-0 method and everything is still kicking. I have been reading through the comments and I think too many peeps that are just itching to throw this on are making some mistakes that could be avoided if they would have ever rooted or used a rom or flashed a phone at all. ( Not trying to be an gluteus maximus but I think this is the prob. ) I have had 6 shots of Rumple tonight and flashed this without any probs.
Once again Matt thank you sooooooooooooo much!
Jay
#267 coletrane09
coletrane09
  • 236 posts
  • Twitter:coletrane09
  • LocationHart, MI
Posted 24 December 2012 - 07:25 PM
Jay
+1
#268 mechatricity
mechatricity
  • 151 posts
Posted 24 December 2012 - 07:28 PM
Does not appear I was able to retain root of can anyone confirm they still have root access after upgrading?
I protected root and temp unrooted before flashing,
#269 Cirrus
Cirrus
  • Current Device(s):Razr Maxx
Posted 24 December 2012 - 07:30 PM
Installed with out a hitch (took forever).
Works great.
Thanks to all... ;)
#270 Oaklands
Oaklands
  • 312 posts
Posted 24 December 2012 - 07:36 PM
Glad to see people having success. It would be a heck of a lot easier to keep up with this thread if they would get the Tapatalk problems fixed on this forum. Really a pain to have to backtrack to where you left off.
Sent from my AT100 using Tapatalk 2
#271 SnoDrtRider
SnoDrtRider
  • 95 posts
  • Twitter:SnoDrtRider
  • Google+:SnoDrtRider
  • LocationSouth Jersey or Tug Hill, NY
  • Current Device(s):Droid Maxx, Motorola Xoom Wi Fi
Posted 24 December 2012 - 07:37 PM
No root here either...
#272 theatomizer90
theatomizer90
  • 19 posts
  • LocationSoutheastern AZ
  • Current Device(s):Droid Razr, SIII, Note 10.1
Posted 24 December 2012 - 07:39 PM
did you update the binaries before the update?
#273 johnnyfrost
johnnyfrost
  • 67 posts
  • LocationWisconsin
Posted 24 December 2012 - 07:40 PM
I may be missing something but from the OP "(Yes, we did that twice. And no, you do not want to be Temp. Unrooted when you update.)" you shouldn't be temp unrooted before flashing.
#274 johnnyfrost
johnnyfrost
  • 67 posts
  • LocationWisconsin
Posted 24 December 2012 - 07:44 PM
Ouch... didn't mean to offend anyone with a noob question. I'll be more careful in the future.
don't be so sensitive. your question was answered.
#275 oatmealboy
oatmealboy
  • 15 posts
Root only appears to work in TiBU and Nova Launcher for me (was able to run backups in TiBU without a hitch). The SU app only shows those two apps as allowed, even though Automatic Response has been set to either 'Prompt' or 'Allow' (currently set to 'Allow'). In the Voodoo app, everything under 'Status' is checked except for 'Root permission granted'.
I backed up root with Voodoo, and Idid not temp. unroot before flashing. However, I did not update the SU binaries before flashing (still on 3.0.3.2).
#276 papi92
papi92
    Developer
  • 727 posts
  • Twitter:afox2015
Posted 24 December 2012 - 07:48 PM
Y
Sent from my HTC6435LVW using Tapatalk 2
#277 mr4r4n
mr4r4n
    OSE-DEV
  • 210 posts
  • LocationNYS
Posted 24 December 2012 - 07:50 PM
i was and i still did, gives me the notification like it is from voodoo OTA but nothing else... had the same issue with ICS in the beginning cant remember what i did to fix it. damn my memory
#278 Pearkel
Pearkel
  • 23 posts
  • Twitter:@pearkel
  • LocationMaysville, Ky
Everything went great here, upgraded and kept root! Very nice Christmas present! Thanks for the great instructions.
#279 Oaklands
Oaklands
  • 312 posts
Posted 24 December 2012 - 07:51 PM
You have to be temporary unrooted when applying the update. If you dont you'll lose root.
If this is the case then the OP needs to be updated. It specifically says opposite of this.
#280 mattlgroff
mattlgroff
    The Dark Knight
  • 2,298 posts
Posted 24 December 2012 - 07:52 PM
This is not the case.
Sent from my Transformer using Tapatalk 2
  • sgtguthrie likes this
