1212 replies to this topic
#241 minabeshara
minabeshara
  • 55 posts
  • Google+:http://www.gofundme.com/36fiag
  • LocationNYC
  • Current Device(s):Moto Razr MAXX
Posted 24 December 2012 - 06:12 PM
Hold Power, Vol Up, Vol Down ( all 3) until you see the screen flash, then let go of power. That should get you to the bootloader screen.
Again, I have done this multiple times. My phone is stuck in a boot loop. I cannot get into recovery or access fastboot or anything else
#242 SpyderMan
SpyderMan
  • 535 posts
  • LocationBrooklyn, NY
Posted 24 December 2012 - 06:14 PM
Please pardon any mental lapse on my part
I do not 'get' what is in the following section of Matt's OP (I'm adding #'s to the steps for sake of reference )
Quote
Superuser App is 3.1.3 Superuser (su) binary is 3.1.1
1. Open OTA Rootkeeper.
2. Choose ' Backup Root '
3. Choose ' Temp Unroot '
**** sounds normal so far***
4. Choose ' Restore Root '
5. Choose ' Temp Unroot '
6. Choose 'Restore Root' (Yes, we did that twice.
And no, you do not want to be Temp. Unrooted when you update.)
here's where I am confused, I recall that you do need to be temp unrooted in order to get OTA update & afterwards you need to Restore root in Voodoo after update is done
sorry if I missed something obvious - but step 6 is confusing as I prev mentioned.
tia for any help & thanks Matt for being there for everyone, yet again!
Sig Created by Thach
#243 luke61456789
luke61456789
  • 165 posts
Posted 24 December 2012 - 06:16 PM
Quote
I think this is what I messes up on to I believe your correct and I didn't temp unroot
#244 satman80
satman80
    Gny. Sgt. Hartman
  • 3,159 posts
  • LocationPluto
Hold all down for about 10 seconds, when you see the screen go black, quickly release the power button and press it again while holding both volume buttons. you have to do it quick..
Site Rules and Guidelines
#245 etrorteepe
etrorteepe
    Not a Belieber
  • 221 posts
  • Current Device(s):Nexus 5
Posted 24 December 2012 - 06:17 PM
I was rooted / (protected root backup) when I applied the Ota, sideloaded ota successfully and then restored root. The temp unroot prior to appying an update was a myth, I've never temp unrooted and I've installed just about every leak there was.
You do have to make sure that your su binaries are up-to-date though prior to taking the ota or you'll be hosed for root.
Edit: To clarify, I'm not talking about Matt's steps above where you root and unroot being a myth, I'm saying it was a myth that people thought that you had to temp unroot prior to applying the update.
#246 satman80
satman80
    Gny. Sgt. Hartman
  • 3,159 posts
  • LocationPluto
Posted 24 December 2012 - 06:19 PM
Quote
When you see it says it has a copy of root, or backup of root (su) you wan't the button to say "Temp. un-root (keeps backup)"
  • SpyderMan likes this
#247 xlightwaverx
xlightwaverx
    CrackFlasher
  • 409 posts
  • Twitter:xlightwaverx
  • LocationEast Coast
  • Current Device(s):XT912, Kindle Fire HD
Posted 24 December 2012 - 06:20 PM
If someone uploads a System Pull, we can make a Base ROM that works with ICS and that is fastbootable back. We can patch the kernel, and directly write it it with fastboot.exe. Only thing we won't have is updated radio's but by the sound of it they're not that good anyways.
X
#248 minabeshara
minabeshara
  • 55 posts
  • LocationNYC
Posted 24 December 2012 - 06:21 PM
X
This would be perfect for my problem! thats my only hope at unbricking my phone i think.
#249 Chewbacka
Chewbacka
Posted 24 December 2012 - 06:22 PM
Thanks. Work Great. No Issues So Far.
#250 etrorteepe
etrorteepe
    Not a Belieber
  • 221 posts
Posted 24 December 2012 - 06:27 PM
X
You have somewhere I can upload to?
#251 SpyderMan
SpyderMan
  • 535 posts
Posted 24 December 2012 - 06:29 PM
thanks satman, that cleared it up for me
sounds like I should wait, like other early releases / leaks
there seem to be early adapter probs…
& a worse updated radio doesn't sound inspiring…
#252 theatomizer90
theatomizer90
  • 19 posts
  • LocationSoutheastern AZ
  • Current Device(s):Droid Razr, SIII, Note 10.1
Posted 24 December 2012 - 06:32 PM
Just put it on Drop box or google drive
#253 xlightwaverx
xlightwaverx
    CrackFlasher
  • 409 posts
Just use a free dropbox account.
#254 SoccerRef12
SoccerRef12
  • 529 posts
  • Twitter:@SoccerRef12
  • LocationLampasas, TX
Posted 24 December 2012 - 06:34 PM
JellyBean Update Mirror:
when I click on the link it says it's the Blur_Version.6.16.211??? That's the ICS, isn't it?
"If you truly learned from your mistakes, I would be a genius by now!"
#255 luke61456789
luke61456789
  • 165 posts
its still the update
#256 johnnyfrost
johnnyfrost
  • 67 posts
  • LocationWisconsin
Posted 24 December 2012 - 06:37 PM
if you take a few minutes to google this, you'll find out that updates are named for the version you are upgrading from. This question is asked hundreds of times everytime there is an update. i chuckle when people like you ask this, like the devs are this site post files as a joke. if a dev says its ics, or jb, or whatever, 99% of the time it is. they aren't going to post a file that is JB but link to a file that's ics.
  • bradenfontaine likes this
#257 jburchii
jburchii
  • 48 posts
  • LocationCharlotte, NC
  • Current Device(s):Droid Razr xt912
Posted 24 December 2012 - 06:38 PM
Just downloaded the file and am at the "Android is upgrading" screen.......
  65.76KB   2 downloads
Edit: So far everything is working Easytether Pro works fine. Blue 4G LTE works also.
interface seems MUCH MUCH smoother than ICS.
Edit (2): I used Matt's Utility to go back to the .211 ..... then flashed the .zip file. I have had ABSOLUTELY NO PROBLEMS. 4G LTE works...tethering works...screen is very responsive and smoother than on ICS.
#258 SoccerRef12
SoccerRef12
  • 529 posts
Posted 24 December 2012 - 06:46 PM
if you know anything about updates, leaks, etc you would know updates are named for the version you are upgrading from. This question is asked hundreds of times everytime there is an update.
Ouch... didn't mean to offend anyone with a noob question. I'll be more careful in the future.
#259 jtelander
jtelander
  • 134 posts
Posted 24 December 2012 - 06:50 PM
No big deal..it is a question that gets asked and answered a lot...no reason to think that will change. If one only does this a couple of times per year, it is easily forgotten.
#260 trikotret
trikotret
    Droid Elite
  • 1,461 posts
Posted 24 December 2012 - 06:55 PM
once we restore root, do we delete su backup?
