The OTA was pulled.My phone is dead and I might hold off until tomorrow since my moms razr which is stock hasn't got the OTA either.
#181
Posted 24 December 2012 - 04:27 PM
#182
Posted 24 December 2012 - 04:28 PM
I wiped cache as you suggested but to no avail. I'm also running .211. Here's the error message it gave me
"Verifying current system...
assert failed: apply_patch_check("/system/bin/logwrapp
er", "f39fcbd278b9e92e9fbedc6a62a047dc23459416", "4a63
fec78956def045b442910a754fa640db8f5a")
e:error in /tmp/sideload/package.zip
(status 7)
Instalation aborted."
you either have safestrap installed or bootmenu manager installed that has hijacked the logwrapper. If you fastboot back to 211, that will take care of the problem.
Then root with his utility, update su binaries, protect root with OTA rootkeeper, then reboot into recovery, wipe cache, and apply the update again.
#183
(status 7)
Uninstall safestrap?
#184
Posted 24 December 2012 - 04:31 PM
Start Fresh, use Matts utility, blow the phone back to stock, and follow his page 1 instructions to the T
#185
Posted 24 December 2012 - 04:32 PM
#186
#187
Posted 24 December 2012 - 04:34 PM
lets pretend we lost root......no reason, let just say we did. now what?
Wait for Someone to find a fix, as in seeing if you can go back to ICS and try again, or wait for a root method for JB..
#188
Have not tested yet, but webtop is still showing under settings.Did I read correctly that webtop is not available on jelly bean?! If its not available, can it be downloaded or flashed on jelly bean. I've recently started using webtop for Netflix at the house saving me from having to have internet service hooked up (I'm cheap and saving money any way I can.)
#189
Posted 24 December 2012 - 04:35 PM
We Honestly have no idea yet
#190
You can try rooting with Matt's utility but if that doesn't work, you're SOL until another exploit comes out, unless this is fastbootable back to .211.
#191
Posted 24 December 2012 - 04:36 PM
I thought I saw it in the screenshot but then read through the posts that it may not be available. Hopefully it will be confirmed soon
#192
Posted 24 December 2012 - 04:41 PM
lol ive been on it
#193
Posted 24 December 2012 - 04:43 PM
I uninstalled safestrap but it's still not working. Currently downloading Matt's utility 1.82 and will start from scratch. Thanks for the help. I'll update once I've tried that and see if that works.
#194
Posted 24 December 2012 - 04:49 PM
#195
Posted 24 December 2012 - 04:50 PM
#196
Is it possible to install the update via Motorola Recovery Tool without an External SD Card?
No
#197
#198
Posted 24 December 2012 - 04:58 PM
Make sure you follow the directions going back to stock 211...you don't want to have ss installed, when you update your binary..Same here +1
#199
Posted 24 December 2012 - 05:04 PM
#200
Posted 24 December 2012 - 05:08 PM
Everything worked fine for me used 1.82 to get back to 211 rooted installed ota rootkeeper installed update through recovery jellybean!
Odd. Look closely at the kernel version. This particular 4.1.2 build seems to be running an ICS kernel (v3.0.8)
Wonder if the actual release is going to be running something a bit newer?
