Black Bear Blanc over at XDA :
What is themed:
framework-res
SystemUI
Settings
Phone
Contacts
DownloadProvider
MotCamera & Messaging (just the launcher icons)
I didn't change any XMLs so this is basic Icarus with themed dialers and icons
Download link:
Alternate link:
Screen shots:
611.06KB 59 downloads 506.39KB 57 downloads 391.38KB 55 downloads
680.02KB 55 downloads 108.74KB 53 downloads 89.89KB 54 downloads
This theme works for me. Flash at your own risk.I am not to be held responsible for damaging your phone.
*It will take the screen being off after everything settles for the status bar to change*
Boot into Safestrap v3.05 (Thanks Hashcode)
Select Icarus 1.5 ROMslot
Wipe Cache and Dalvik
Install
Jayrod's RetroPhone Theme Black_cyan.zip
Reboot system
If you like it,let me know with a thanks
*This theme will work with 1.7, however since 1.6+, most status bar icons for included apps were changed to blue. Since this does not affect anything, only the above .apks will be white and is not necessarily needed for updating*
*ADDED 1/9/13 SystemUI and framework update for 1.7
Link :
![Posted Image](http://www.droidrzr.com/uploads/monthly_01_2013/post-41248-0-35934500-1357614981_thumb.png)
