Hello, I think I have everything set up correctly. but I keep getting this error caleb@caleb-System-Product-Name:~/Groove$
make -j2 otapackage
How do I fix it? Running ubuntu 64-bit
Thanks Bacu12
Posted 19 December 2014 - 02:40 PM
make -j2 otapackage
Thanks Bacu12
Posted 20 December 2014 - 10:14 AM
you need the right java..run this
Posted 20 December 2014 - 11:10 AM
Ok thanks it fixed that part. but now it gives this Checking build tools versions...
How do I fix this? Thanks for helping me. I am kinda a noob. But I guess everyone started a noob. Thanks Bacu12
Posted 20 December 2014 - 01:21 PM
yep we all do....before you mess with that error need to change a couple of things...your building cm engineering build..need to change that to userdebug..in lunch look for lunch_combo cm_(your device)-userdebug....if its not there add it to your vendersetup.sh in the device folder...example in mine it would be in device/samsung/jflte/vendorsetup.sh add this line anywhere....add_lunch_combo cm_your device-userdebug.....now lunch again an choose that...then start the build with ...make bacon
Posted 20 December 2014 - 03:57 PM
Ok so I added add_lunch_combo cm_msm_8960-userdebug to vendersetup.sh Is that right? still giving same thing as before.
Posted 20 December 2014 - 04:02 PM
thats right ...so now you still have the kernel error?
Posted 20 December 2014 - 04:11 PM
Yes I do. Looks exactly the same as before. Would it be easier if I just re did everything related to the repo and device tree?
Posted 20 December 2014 - 04:13 PM
This is the tutorial I followed. http://forum.xda-dev...d.php?t=2320007
Posted 20 December 2014 - 04:16 PM
Sorry wrong link I followed this tutorial. http://forum.xda-dev...d.php?t=2455005
Posted 20 December 2014 - 04:17 PM
I am pulling my device from this git hub repo https://github.com/C...la_moto_msm8960
Posted 20 December 2014 - 04:18 PM
Posted 20 December 2014 - 04:19 PM
Would you mind pointing me toward device tree?
Still same as above commit...Sorry wrong link I followed this tutorial. http://forum.xda-dev...d.php?t=2455005
Posted 20 December 2014 - 04:20 PM
What bootloader are you tying to build for.Would you mind pointing me toward device tree?
Posted 20 December 2014 - 04:22 PM
prob has wrong sdk too...if he followed that
Posted 20 December 2014 - 04:26 PM
Actually after further researching the sdk isnt really important since its included in the prebuilts when pulled in.. FYIprob has wrong sdk too...if he followed that
Posted 20 December 2014 - 04:27 PM
So it would be better to start over?
Posted 20 December 2014 - 04:28 PM
KK bootloader. I basically want to create my own version of cm 12.0 unofficial.
Posted 20 December 2014 - 04:29 PM
post a screenshot of your about phone the way it is now
