![Photo](http://www.droidrzr.com/uploads/profile/photo-thumb-39588.jpg?_r=0)
Help with odin
Daino92
, Dec 21 2012 08:02 PM
7 replies to this topic
Posted 21 December 2012 - 08:02 PM
I was reading the thread that dirty made about getting back to full stock. I was wondering how one usues 7z to extract the tar file as I have no idea. I have the md5 file wiyh the stock firmware but no idea how to extract it right. Thanks for the help.
Posted 21 December 2012 - 08:14 PM
If 7-Zip does not launch when you double-click the .tar.gz file, ensure that 7-Zip is set to handle these types of files by default.
Open up 7-Zip
Click Tools → Options
Go to the “System” tab.
Make sure “tar” and “gz” are checked off.
Click “OK”.
Now go back and try to open your .tar.gz file. 7-Zip will start up and decompress the archive.
Open up 7-Zip
Click “OK”.
Posted 21 December 2012 - 08:16 PM
If that doesnt work let me know and i will give ya info on how to extract it by command prompt.
Thanks a lot man.
Posted 21 December 2012 - 08:17 PM
Thanks a lot man.
Np. Let me know if it works for ya.
Posted 21 December 2012 - 08:38 PM
Winrar also works with .tar files.
- tmyinc likes this
Posted 21 December 2012 - 08:40 PM
Ah yes.. forgot about that lol. Not quite with it tonight. Might be easier then my command method too
![:)](http://www.droidrzr.com/public/style_emoticons/default/smile.png)
Posted 22 December 2012 - 07:31 AM
Or just right click, extract to
