Moto Razr HD xt925 stuck in fastboot
stuck in fastboot
8 replies to this topic
#1 Faisaljee311776
Faisaljee311776
  • 5 posts
  • Google+:faisaljee3117767@gmail.com
  • Locationpakistan
  • Current Device(s):motorola xt926
Posted 09 December 2014 - 12:20 PM
[/CENTER]
firstly i am confused about model number
model xt925 is written on back side
i m trying to online update with motorola DeviceSoftwareUpdate
But it shows model xt926
i m trying to flash with RSD Lite but it shows error
i m trying to flash fastboot this files
9.8.2Q-8-XT925_VQU-26_USERSIGNED_S7_USAVANQUGBOR031.0R_LSAVNQJBEEGB_P011_A006_CFC.xml
9.8.2Q-50-XT925_VQLM-20_AmericaMovil_BR_SIGNED_S12_USAVANQUCLABRLA01F.0R_VANQJBCLABRLA_P007_A007_S1FF_v2_fb.xml
DROID_RAZR_HD_Utility_1.3.gpt fix
DROID_RAZR_HD_Utility_1.4gpt KK
and
Slim-xt926-4.2.2.build.5.6-UNOFFICIAL-20130521-0436
VRZ_XT926_9.8.1Q-94-1_RSD.xml
VZW_XT926_4.1.2_9.8.1Q_62_VQW_MR-2_VQW_CFC.xml
VZW_XT926_4.4.2-KDA20.62-10_1FF.xml
but following error show.
 Flashing bootloader images ...
 So as to use latest flash capabilities
sending 'partition' (32 KB)...
OKAY [  0.031s]
writing 'partition'...
FAILED (remote failure)
finished. total time: 0.172s
sending 'sbl1' (101 KB)...
OKAY [  0.016s]
writing 'sbl1'...
OKAY [  0.516s]
finished. total time: 0.531s
sending 'sbl2' (126 KB)...
OKAY [  0.016s]
writing 'sbl2'...
OKAY [  1.891s]
finished. total time: 1.906s
sending 'sbl3' (512 KB)...
OKAY [  0.047s]
writing 'sbl3'...
OKAY [  1.141s]
finished. total time: 1.188s
sending 'rpm' (140 KB)...
OKAY [  0.031s]
writing 'rpm'...
OKAY [  0.484s]
finished. total time: 0.547s
sending 'tz' (192 KB)...
OKAY [  0.031s]
writing 'tz'...
Preflash validation failed
finished. total time: 0.234s
sending 'aboot' (256 KB)...
OKAY [  0.047s]
writing 'aboot'...
OKAY [  1.797s]
finished. total time: 1.859s
 Flashing modem SW...
sending 'modem' (30720 KB)...
OKAY [  2.344s]
writing 'modem'...
OKAY [  2.828s]
sending 'modem' (17416 KB)...
OKAY [  4.031s]
writing 'modem'...
OKAY [  1.141s]
finished. total time: 10.344s
sending 'fsg' (2850 KB)...
OKAY [  0.234s]
writing 'fsg'...
OKAY [  1.969s]
finished. total time: 2.203s
erasing 'modemst1'...
OKAY [  0.797s]
finished. total time: 0.797s
erasing 'modemst2'...
OKAY [  1.281s]
finished. total time: 1.281s
 Flashing AP Images...
sending 'logo' (1709 KB)...
OKAY [  0.141s]
writing 'logo'...
OKAY [  1.969s]
finished. total time: 2.109s
sending 'devtree' (512 KB)...
OKAY [  0.063s]
writing 'devtree'...
OKAY [  0.375s]
finished. total time: 0.500s
sending 'boot' (10240 KB)...
OKAY [  0.828s]
writing 'boot'...
finished. total time: 1.109s
sending 'recovery' (10240 KB)...
OKAY [  0.828s]
writing 'recovery'...
finished. total time: 1.719s
sending 'system' (30720 KB)...
OKAY [ 20.781s]
writing 'system'...
finished. total time: 21.000s
sending 'cdrom' (30720 KB)...
OKAY [  2.375s]
writing 'cdrom'...
OKAY [  1.844s]
sending 'cdrom' (22538 KB)...
OKAY [  5.203s]
writing 'cdrom'...
OKAY [  1.516s]
finished. total time: 11.063s
erasing 'tombstones'...
OKAY [  2.375s]
finished. total time: 2.406s
erasing 'cache'...
OKAY [  2.719s]
finished. total time: 2.750s
 All images flashed. Check logs for errors!
i am in trouble for a week . please help me to find the solution of this problem.
#2 soocold
soocold
    OC & OCD Specialist
  • 8,736 posts
  • Google+:amcsocold@gmail.com
Posted 09 December 2014 - 12:26 PM
The xt926 WILL NOT flash to the xt295
Sent from my Nexus 6 using Tapatalk
sig by jayrod
The Rules-Follow them.
#3 RikRong
RikRong
    Cap'n Slow
  • 2,117 posts
  • LocationNoDak
  • Current Device(s):Pixel 7
Posted 09 December 2014 - 05:06 PM
Many have tried and all have failed.
OP, if you have attempted to flash every single one of those, there's a good possibility you could have a brick. Can you still get into fastboot?
If you can still get into fastboot, head over to XDA to get the current firmware for the 925. The KK FW isn't hosted anywhere yet, but there are several threads that talk about the KK update for the 925.
Sent from my HTC6525LVW using Tapatalk
  • Faisaljee311776 likes this
#4 Faisaljee311776
Faisaljee311776
  • 5 posts
  • Locationpakistan
Posted 10 December 2014 - 03:55 AM
Many have tried and all have failed. OP, if you have attempted to flash every single one of those, there's a good possibility you could have a brick. Can you still get into fastboot? If you can still get into fastboot, head over to XDA to get the current firmware for the 925. The KK FW isn't hosted anywhere yet, but there are several threads that talk about the KK update for the 925. Sent from my HTC6525LVW using Tapatalk
Can you please help me by giving this firmware ?
#5 RikRong
RikRong
    Cap'n Slow
  • 2,117 posts
  • LocationNoDak
Posted 10 December 2014 - 05:18 AM
I don't have the firmware.  You'll have to go over to XDA and read through the threads on there and get the firmware.
#6 Faisaljee311776
Faisaljee311776
  • 5 posts
  • Locationpakistan
Posted 10 December 2014 - 08:54 AM
thanks sir
but same error not flash boot file write validation failed
or not install recovery.....
#7 Faisaljee311776
Faisaljee311776
  • 5 posts
  • Locationpakistan
Posted 13 December 2014 - 01:39 AM
any salution this time
please help me.................
#8 faniosalve
faniosalve
Posted 28 December 2014 - 07:47 AM
Good Afternoon!
My case is like that, I went to downgrade on my Razr HD. He was installed with the update 4.2.2 KitKat, but started giving a bug Contacts, Camera and other applications. I decided to Downgrade to original version but was giving error in RSD Lite. I was told it was just me going erasing the lines that gave error and that's what I did. If I'm not mistaken I had a line that was giving error: <step operation = "flash" partition = "system" filename = "system_signed" MD5 = "e8c0234f90cbe504cc68aede265c2dfc" />. After I deleted the lines that were giving error he has completed installation, but now my phone does not want to start the android, appears the first logo Motorola and then off and is all black. Could someone give me a light of what really happened?
From already thank you for your attention!
#9 RikRong
RikRong
    Cap'n Slow
  • 2,117 posts
  • LocationNoDak
Posted 28 December 2014 - 12:21 PM
You can't downgrade unless your boot loader is unlocked.
