now this is awesome
+1
My first PA ROM that I've ever used, glad to see something different. Great work!
Posted 23 December 2012 - 06:41 AM
now this is awesome
Posted 23 December 2012 - 05:43 PM
Posted 23 December 2012 - 07:51 PM
The first one is PA features built into CM10, the second is PA features built into AOKP. It comes down to which you prefer really - CM10 or AOKP.Love the Rom man. I have a question.
What's the difference from Stock & King Kangs version? Seen the update that your posting a Themed one today. Will wait for that one.
Posted 24 December 2012 - 08:54 AM
Posted 24 December 2012 - 09:26 AM
Definitely not ROM related as I do the same. Did you restore it with tibu/something similar or fresh install from play store? I actually have never had that error with GO so I'm not sure how much help I can be on that one.Love this ROM!
I have one issue and it may not even be a ROM issue. I'm using GoSMS and I'm getting an error that says GoSMS is attempting to send a lot of messages - when I send lots of text (10 or so) one after another. I am using the same apps and settings I have used on every other ROM and have never gotten this pop up. It doesn't appear to be a gosms message but something else. Any ideas? I'm on the AOKP version by the way.
thanks for your help.
Posted 24 December 2012 - 09:30 AM
I restore with tibu. It's not a gosms pop up. it looks more like an android security warning. the only reason why i thought it might be rom related is because I have flashed just about every rom made for the razr and never had this issue before, but I know with the frequency that apps update, it could be anything from the ROM, to Gosms to my virus protection. Who knows?Definitely not ROM related as I do the same. Did you restore it with tibu/something similar or fresh install from play store? I actually have never had that error with GO so I'm not sure how much help I can be on that one.
Posted 24 December 2012 - 06:44 PM
Posted 24 December 2012 - 09:29 PM
hope this helps if u have bluetooth on that might cause a problem not sureeverything worked great except i had no sound when making and recieving calls. sound does work on media. im using the hybrid rom. any help is appreciated.
Posted 25 December 2012 - 07:09 AM
Is it possible to get the tablet style bottom bar and softkeys enabled?
Posted 25 December 2012 - 08:49 AM
Posted 25 December 2012 - 01:38 PM
Posted 25 December 2012 - 02:17 PM
Will this be made compatible with the new release of JB?
Posted 25 December 2012 - 03:09 PM
Indeed, no time frame as of yet though.
Posted 25 December 2012 - 05:36 PM
Posted 25 December 2012 - 06:33 PM
Posted 26 December 2012 - 07:50 AM
Posted 26 December 2012 - 08:42 AM
Posted 26 December 2012 - 09:15 AM
did u freeze the stok messaging appI know that its explained in the op but I can't get the 3d app thing to work, or I'm not doing it correctly can someone help me?
Posted 28 December 2012 - 05:55 PM
