[ROM][STOCK][Base] Paranoid Android Hybrids - CM10 and AOKP 12/20
#61
Posted 20 December 2012 - 03:51 AM
#62
Posted 20 December 2012 - 09:12 AM
Work asked wtf I was doing on my phone as of late, so I have scaled back the crack flashing a tad. I will have to give this a whirl though this weekend
#63
Posted 20 December 2012 - 12:14 PM
Don't think it's a battery problem, as I was able to successfully boot into another ROM and the battery indicator in SS is correct. Tried to wipe cache/davlik and fix permissions but neither worked.
#64
Posted 20 December 2012 - 12:51 PM
#65
Posted 20 December 2012 - 01:42 PM
In terms of requests, having the basic email client inverted would be awesome. I have 4 work related email addresses and the white screen eats battery life. It would also be awesome if that could be done to the Y!Mail email client. I know it can be done for the regular email client since that was done with Full Throttle CNA. Can their email client be imported by an end user? That would save you the extra work. As for the Y!Mail app, I've yet to see it inverted... makes me think their isn't much demand. Either way it would be nice. Lastly, CNA allows for a lot of modifications with built in toggles and weather viewing. Is that possible with paranoid android? That would be awesome.
Anyways... I think this is a solid ROM. I'm definitely keeping it!
Sent from my Droid RAZR MAXX using Tapatalk 2
#66
Posted 20 December 2012 - 01:43 PM
#67
Posted 20 December 2012 - 01:54 PM
The major difference is that this is just a stock base ROM whereas FT CNA is a customized/tweaked ROM using the CNA base. This was put out so other devs could do much of the same with PA. The same goes for the AOKP/PA that I'm uploading tonight. Of course, after I have both bases uploaded, I will be doing some of the same myself.I downloaded this last night and like it a lot. I'm also on Full Throttle CNA. This ROM so far holds DATA much better. I love the new Gmail interface as well as Yahoo Y!Mail app. Obviously it would be nice to get the camera flash and BT up and running but we all know that is nothing you can do about it for now.
Assuming you're referring to them being in the PA guide pictures. Those aren't from the RAZR, rather they are 'stock' images you'll find in most PA posts.how do i enable soft keys ?
#68
Posted 20 December 2012 - 02:08 PM
#69
Posted 20 December 2012 - 02:13 PM
AOKPwhich do you prefer CM10 or AOKP
Sent from my XT912 using Xparent Blue Tapatalk 2
#70
Posted 20 December 2012 - 02:24 PM
AOKP
Noob here, Why?
#71
Posted 20 December 2012 - 02:58 PM
#72
Posted 20 December 2012 - 03:40 PM
Need to Calibrate battery. Make it a practice with every flash
I did that actually and encountered this issue after it drained.
#73
Posted 20 December 2012 - 07:47 PM
#74
Posted 20 December 2012 - 08:18 PM
#75
Posted 20 December 2012 - 08:53 PM
#76
Posted 20 December 2012 - 09:02 PM
You can change it like any other individual app. Going into Paranoid Settings, Apps, and then scroll down to Settings. It's like any other apk.This may be a dumb question...I don't care for the small system menu.,..etc...Can that be changed? (maybe I'm too "Paranoid")
#77
Posted 21 December 2012 - 12:15 AM
#78
Posted 21 December 2012 - 04:38 AM
I started to play around with the CM10 version last night, and I actually found it a little clunky. I think that is just me and having to learn the new interface is what is throwing me off a bit. Not used to it all being on one screen with the settings and options. I am actually going to install the AOKP version later today, as I am an AOKP junky. Now, if you guys get a CNA base working then the Razr will be stacked!!!!!
#79
Posted 21 December 2012 - 05:04 AM
Noob here, Why?
There is a good article floating around on XDA or maybe it's here on droidrzr.com about the differences between the two. CM10 is a little faster and plays a little better with the phone, but AOKP opens the door for far more customization. Both are great pieces of software and are very similar. I like AOKP because it gives me a little more freedom to change and do things my way. I also think it looks a little better graphics wise. But really it all comes down to swagger. Since I started using AOKP, the swagger just drips off the 'ol TARDIS like a fine wine. Can't keep the intergalactic babes from banging on the door of this tiny blue box
#80
Posted 21 December 2012 - 06:12 AM
