[ROM][STOCK][Base] Paranoid Android Hybrids - CM10 and AOKP 12/20
Posted 18 December 2012 - 07:44 AM
Paranoid Android - Unofficial for the DROID RAZR
Huge thanks to:
dhacker29 & Hashcode for making this possible in the first place
PA dev team ( )
King Kang dev team ( ) for the framework edits
halo13 for posting that guide in how-to that led me to start learning
What works/doesn't:
This should be the same as the other JB roms.
Install:
Download ROM and gapps ( )
Boot into recovery
Wipe data/cache/dalvik
Flash ROM
Flash gapps
Reboot
Enjoy
ROMS:
PA (CM10):
AOKP/PA Hybrid (King Kang) 12/20:
What's next:
Update: testing a customized/LIGHTLY themed rom using the AOKP/PA base, should be posted later today
Screens:
- damagickid, vtwinbmx, BytecodeMe and 8 others like this
Rebooting into recovery after changing PA settings?
Paranoid Android of any version for any device has always rebooted into recovery if you reboot from the Paranoid Settings Apply button. That is useful in case you need to do a factory reset when your screen is all "screwed up". Many people do not know the consequences of changing to different tablet layouts, or dpi, or px. Factory reset from the recovery boot is your friend. Once you know what you're getting into, you can just cancel out of the reboot prompt where applicable and reboot the normal method using the power button.
- Flameroid likes this
Posted 18 December 2012 - 07:51 AM
Posted 18 December 2012 - 08:05 AM
Posted 18 December 2012 - 08:12 AM
Posted 18 December 2012 - 08:15 AM
Probably the same as any other CM10 ROM on here. It's pretty much that with PA built into it. This is also an unmodified base, so I'm not sure.holy crap. Whats the battery life like on this? I know might as well say asap so there is not a million more people asking.
Posted 18 December 2012 - 08:30 AM
Posted 18 December 2012 - 09:02 AM
Posted 18 December 2012 - 09:12 AM
You should be fine, I had only tested with the gapps listed at the time of posting because it happened to be in the same folder on my SD card. I flashed the 20121011 pack without issue. Updating the OP.Looks great. getting notification that a gapp update is available. I'm guessing don't update?
- jbartolovich likes this
Posted 18 December 2012 - 09:23 AM
Thanks, this is going to take some getting used too. But so far no issues.
Posted 18 December 2012 - 09:42 AM
Posted 18 December 2012 - 09:46 AM
Downloading now, will report back later!
Thanks!
Posted 18 December 2012 - 09:55 AM
Posted 18 December 2012 - 10:08 AM
Posted 18 December 2012 - 10:10 AM
Dont know if you did this on purpose but when you are in your paranoid setting and you make a change and it reboots it goes into recovery instead of giving the option to bypass it.
That's app-dependent. Some apps/utilities reboot to recovery. If you reboot using the power button, it does not.
Posted 18 December 2012 - 10:17 AM
Posted 18 December 2012 - 10:18 AM
Sent from a Eclipsed RAZR Maxx
Posted 18 December 2012 - 10:23 AM
Does that for me as well.Dont know if you did this on purpose but when you are in your paranoid setting and you make a change and it reboots it goes into recovery instead of giving the option to bypass it.
Posted 18 December 2012 - 10:38 AM
