* * * * * 1 votes
[ROM][5.0.2][V7.0] Validus Lollipop (Updated 03/30/2015)
159 replies to this topic
#121 Martinusbe
Martinusbe
    Developer n00b ????
  • 24 posts
  • LocationBelgium
  • Current Device(s):bacon & falcon
Posted 19 January 2015 - 02:01 PM
What kernel works the best for this ROM ?
Something missing in my kernel?
<p> <img src="<a href='http://forum.xda-dev...ic4139665_2.gif'>http://forum.xda-dev...ic4139665_2.gif</a>" alt="sigpic4139665_2.gif">
#122 ClintT
ClintT
  • 16 posts
Posted 19 January 2015 - 02:18 PM
Not at all, I'm just going through some lollipop ROM on the forums and in a few of them people always talk about changing the kernel. I haven't seen it in this thread. So I was just asking. By the way very very nice ROM. :)
#123 mrlolli
mrlolli
    Put Member Title Here
  • 763 posts
  • LocationNowhere
Posted 21 January 2015 - 08:56 PM
just touching base with you guys, we haven't forgotten about ya! And thanks for the kind words, ClinT :) .  As soon as I see a new update posted, I will be bringing it here.
  • stoerte and ClintT like this
Nice job on the signature, jl90...thanks!
#124 ClintT
ClintT
  • 16 posts
Posted 22 January 2015 - 05:45 AM
Just a question. I see on other lollipop ROMs for the oneplus they say that u have to flash a zip called bacon_firmware_update_cm12.zip or something like that. Does this have to be flashed with Validus ROM as well coming from stock cm11s?
#125 mrlolli
mrlolli
  • 763 posts
  • LocationNowhere
Posted 22 January 2015 - 06:34 AM
I never have...
I don't know what is in that zip, but it seems that it helps people with some hardware related problems. So, if you are having a hardware problem, I guess it wouldn't hurt to try it :)
#126 stef
stef
Posted 22 January 2015 - 06:46 AM
Its the latest cm update zip and you need to flash it with ROM
#127 ClintT
ClintT
  • 16 posts
Posted 22 January 2015 - 08:40 AM
Thanks stef. @mrlolli I see you put a link for this zip on xda.B)
#128 mrlolli
mrlolli
  • 763 posts
  • LocationNowhere
Posted 22 January 2015 - 08:53 AM
Thanks stef. @mrlolli I see you put a link for this zip on xda. B)
oh, i thought you already had it  :lol . here is firmware upgrade zip for anyone else that may need it: https://www.androidf...897840722643821
#129 mrlolli
mrlolli
  • 763 posts
  • LocationNowhere
Posted 24 January 2015 - 07:33 AM
New build is up :) . This is still considered a test build for now, but it will be a release candidate so here it is.
changelog!
Fix-ups Pie
SystemUI: port lock screen toggle tile
SystemUI: animate state in Performance profile
Themes: Update LoadedApk resources.
Themes: Don't add common assets if files cannot be accessed
SystemUI: port compass tile to cm-12.0
Another attempt qs settings adjustment
SlimPie 1/2
SystemUI: add NFC tile
SystemUI : Add missing assets for AdbTile
SystemUI : Add adb over network tile
SystemUI: port performance profile toggle
SystemUI: add Profiles tile
SystemUI : Add QSDetailItems
WindowManagerService: Fix On-Screen keyboard popups when hw-keyboard is present
SystemUI : Move shortcut helper instantiation before updateVisibility
SystemUI: StatusBar: completely unbreak MSIM bar
Cleanup & optimization.
Themes: Ensure themed fonts always have fallbacks
bootanim: Add continuous splash support
Remove platform and baseband check for CSD init.
Settings: Move expanded desktop setting up.
Settings: Update notification drawer drawable
Revert "possible qs color update"
Settings : Add adb over network tile
Cleanup.
Settings: allow Profiles to be launched externally
utils: Introduce ScreenType class
SystemUI: Lockscreen shortcut customization
SystemUI: StatusBar: Unbreak MSIM bar
Fix "pm list permissions" crash if resource string missing
NPE in SearchManager.triggerSearch
check ntpserver as empty string instead of null
frameworks/base: Bringup expanded desktop and implement per-user configuration.
"framework/base: Bringup expanded desktop and implement per-user configuration."
Centralize QuickSettings constants
Do not allow the navigation bar to move if width == height
LS weather disabler (1/2)
Keyguard: Create lockscreen weather, move weatherimpl to utils.
Show carrier label and custom (2/2)
Status Bar Clock: rewrite for lollipop and add left clock, Add clock mods with new left position
  • jl90 and Martinusbe like this
#130 Martinusbe
Martinusbe
    Developer n00b ????
  • 24 posts
  • LocationBelgium
Posted 24 January 2015 - 08:12 AM
I disabled dt2w default-on because i needed to work in the overlay, you can just enable in Buttons menu
  • mrlolli and ClintT like this
#131 ClintT
ClintT
  • 16 posts
Posted 24 January 2015 - 08:33 AM
I have looked at a lot of lollipop ROMs for the oneplus one. This is the best one by farB)
  • mrlolli and Martinusbe like this
#132 mrlolli
mrlolli
  • 763 posts
  • LocationNowhere
Posted 24 January 2015 - 08:58 AM
We are glad that you like it! :)
  • Martinusbe and ClintT like this
#133 stoerte
stoerte
  • 31 posts
  • LocationKiel
  • Current Device(s):Oneplus
Posted 26 January 2015 - 01:26 PM
Just put with clean flash the latest build. Very nice work. I am just missing the date in the status bar. Was it removed ?
Send by Hyperdrive on one+One
  • jesterpaul likes this
#134 jesterpaul
jesterpaul
  • Google+:jesterpaul
  • LocationAuckland New Zealand
  • Current Device(s):OnePlus One
Posted 27 January 2015 - 01:04 PM
Same. I like the date on my clock to display. Will this be added in future builds?
Other than that, I too have tried almost every LP ROM out there for my Bacon, and I keep coming back to this one, because it is the best out there IMHO. Great work from the Devs.
#135 mrlolli
mrlolli
  • 763 posts
  • LocationNowhere
Posted 27 January 2015 - 06:25 PM
i don't know why it was taken out, but I'm sure it was for a good reason.  As far as when new builds will be released, I believe they are trying to get on a weekly schedule unless there is a major update.  Hopefully then will they be able to resolve any issues that may have been arising from the date on the clock and put it back in, but I cannot make any promises :)
  • stoerte and jesterpaul like this
#136 jesterpaul
jesterpaul
Posted 30 January 2015 - 12:00 AM
Look what have we got here? https://www.androidf...916177934519503
New strips of yummy Bacon?
Sent from my Sonic Open Kang
#137 mrlolli
mrlolli
  • 763 posts
  • LocationNowhere
Posted 30 January 2015 - 06:47 AM
Look what have we got here? https://www.androidf...177934519503New strips of yummy Bacon?Sent from my Sonic Open Kang
Yeah, I posted it yesterday lol
#138 jesterpaul
jesterpaul
Posted 31 January 2015 - 03:14 PM
Oops. Me blind. Lol
  • mrlolli likes this
#139 mrlolli
mrlolli
  • 763 posts
  • LocationNowhere
Posted 31 January 2015 - 03:19 PM
Oops. Me blind. Lol
Haha it's all good :D
#140 jlang11
jlang11
  • 29 posts
  • LocationFL
  • Current Device(s):RAZR HD MAXX
Posted 01 February 2015 - 07:27 AM
HI!! Just installed the 1/06 ROM and loving it so far. One thing I cant find is the alarm... I use my phone to get up in the morning... I may have to install the new update because I like PIE!
Wheres the alarm settings?
Thank you for all your hard work on this ROM!
