[ROM][5.0][Lollipop][MSM8960 KKBL & JBBL] CM12 UNOFFICIAL
cm12 lollipop 5.0 moto_msm8960
133 replies to this topic
#1 nprevette420
nprevette420
    BlissPop Maintainer
  • Banned
  • 1,626 posts
  • LocationNC
Posted 16 November 2014 - 04:14 PM
Here is CM12 (built by various people) for the moto_msm8960 devcies KKBL & JBBL
All credit goes to Cyanogenmod
ROM
(built by CM)
(built by CM)
(built by CM)
(built by nprevette420)
(built by nprevette420) COMING SOON
(built by jvartaniam94)
GApps
(by dhacker29)
New
for those tired of the old CM bootanimation
To see what has updated, check out the source
Initial boot takes about 10-15 minutes because ART takes a long time to build up. So be patient :D
Most everything works (I couldn't find anything that didn't work), but it is still beta, so don't post bugs, just be happy our device got updated to Lollipop
  • ATTACK, moroshek, st870109 and 1 other like this
Need Help? Send me a message
#2 nprevette420
nprevette420
    BlissPop Maintainer
  • Banned
  • 1,626 posts
  • LocationNC
Posted 16 November 2014 - 04:25 PM
Here is CM12 (built by Dhacker) for the moto_msm8960 unified KKBL ONLY
All credit goes to Dhacker29 and Cyanogenmod
ROM (Get it from his Twitter)
(check his twitter for updates)
GApps
(Coming Soon)
Flash
for root
  • st870109 and Dssj like this
#3 nprevette420
nprevette420
    BlissPop Maintainer
  • Banned
  • 1,626 posts
  • LocationNC
Posted 16 November 2014 - 06:32 PM
Posted update in Post 2, built by me....build 11-17-14
and edited OP, forgot to mention SuperSU for root.
#4 Johnny_McG
Johnny_McG
  • 17 posts
Posted 17 November 2014 - 02:26 PM
what would be the difference between your build and Dhacker s build?
#5 nprevette420
nprevette420
    BlissPop Maintainer
  • Banned
  • 1,626 posts
  • LocationNC
Posted 17 November 2014 - 03:58 PM
 More of the recent updates. They are always updating things, literately all the time. New commits pushed every 10-15 minutes. So my builds have more of those updates.
  • Slickademo likes this
#6 nprevette420
nprevette420
    BlissPop Maintainer
  • Banned
  • 1,626 posts
  • LocationNC
Posted 17 November 2014 - 06:13 PM
Update posted, post #2
#7 Slickademo
Slickademo
  • 380 posts
  • LocationUSA
Posted 17 November 2014 - 06:17 PM
*hoping for exfat support* :)
#8 grinz2much
grinz2much
  • 59 posts
  • LocationGilroy California
  • Current Device(s):Razr M
Posted 17 November 2014 - 09:12 PM
So are you done with Bliss Stalk and moved to CM12?
#9 nprevette420
nprevette420
    BlissPop Maintainer
  • Banned
  • 1,626 posts
  • LocationNC
Posted 18 November 2014 - 09:11 AM
Nope, bliss is still alive. We are going to build a new bliss based off of cm12.
#10 grinz2much
grinz2much
  • 59 posts
Posted 18 November 2014 - 11:38 AM
OK - does that mean there will be more from CM11?
Here's my concerns. Although Lollipop is interesting, I'm completely unimpressed with it so far. I've watch many videos and I'm not seeing any new features I want. I like the black menus over the white. The layered thing - not sure I like that. Just because it has a bigger version number doesn't make it better. Just like Windows 8 is worse than Windows 7 and Gnome 3 is worse then Gnome 2, I have serious concerns that Lollipop is better than KitKat.
In fact - my experience with KitKat sometimes makes me want to go back to Jelly Bean. JB was very stable. When it worked - it worked. With KitKat it seems like it never does the same thing twice. Sometime stuff just works and 2 minutes later - it doesn't. When you hit the Home button sometimes it goes home, sometimes it doesn't Often you have to hit it twice, or 3 times to make it work. Sometimes the task switcher button brings up the list, sometimes it doesn't.
Having said that - a BlissPop ROM (yes - you can use that) would be interesting especially if you can get rid of white and give me back my black. Black is beautiful!
My 2 cents .....
#11 Not_A_Dev
Not_A_Dev
  • 66 posts
  • Current Device(s):Motorola Droid Razr HD Maxx
Posted 18 November 2014 - 12:56 PM
Curious about the following message when I'm flashing CM 12 in Twrp 2.7.1, and how to eliminate it:
mount: failed to mount  /dev/block/platform/msm_sdcc.1/by-name/userdata  at: /data  Device or resource busy
CM 12 still flashes and everything, but I'm wondering what that message is about.
Edit: dirty flashing this time, but it also showed up when I clean-flashed CM 12 last time
#12 thewraith420
thewraith420
    Crack Flasher
  • 112 posts
  • Current Device(s):XT907 jbbl Blisspop
Posted 18 November 2014 - 02:51 PM
I got that message too, didn't think to mention it since the rom still flashed and booted fine
#13 nprevette420
nprevette420
    BlissPop Maintainer
  • Banned
  • 1,626 posts
  • LocationNC
Posted 18 November 2014 - 02:56 PM
Yes, you will get that error of you wipe system before flash. Just flash it again and it will install fine.
Also latest twrp is 2.8.1.0 for the kkbl.
#14 Not_A_Dev
Not_A_Dev
  • 66 posts
Posted 18 November 2014 - 05:03 PM
Yes, you will get that error of you wipe system before flash. Just flash it again and it will install fine. Also latest twrp is 2.8.1.0 for the kkbl.
Actually, I just wiped Dalvik (snicker...) and cache before I flashed, but it boots fine regardless. Yep gotta upgrade to TWRP 2.8.1
#15 jdjbmedina
jdjbmedina
  • 5 posts
  • Current Device(s):RAZR M, NEXUS 7
Posted 18 November 2014 - 05:17 PM
Great ROM.
I had a few issues with the camera and network connectivity but I reflashed a few times to get it to to work. Here is the process I followed.
1. Created Nandroid backup of my previous ROM
2. Factory reset
3. Flashed CM12 nighlty
4. Flashed the provided GAPPS
5. Flashed SuperSU
6. Rebooted then this process took about 5-10 minutes to complete
7. Did the restore from previous RAZR M(this took about 20 minutes to complete)
GPS works, wifi works, network works, phone calls work, sound is a little scratchy on phone calls, So far all apps work as far as I have seen. I will keep testing. My quadrant score is about 400 points higher. The system is fluid, I did notice that when I hadn't closed apps and had about 30 of them open the system was lagging a little bit, but this was not unbearable.
Thank you for getting this together. :)
#16 nprevette420
nprevette420
    BlissPop Maintainer
  • Banned
  • 1,626 posts
  • LocationNC
Posted 18 November 2014 - 06:42 PM
Update posted, build 11-19-14
Also switched OP and post 2, now my builds are in OP and a link dhackers are in post 2
#17 grinz2much
grinz2much
  • 59 posts
Posted 18 November 2014 - 08:54 PM
In the process of trying it out. So far it installed and is restoring for Titanium backup. Does not connect to Verizon so can't test it to see if it makes phone calls. I'm going to continue to see how close it gets to being acceptable understanding that this is very early code in development.
My expectations are very low so it's likely to do better than I expect. Trying to see if I like Lollipop.
#18 grinz2much
grinz2much
  • 59 posts
Posted 18 November 2014 - 09:25 PM
BTW - thanks for the great work you do. I know I point out problems and I'm opinionated - but don't think I don't appreciate your efforts.
#19 grinz2much
grinz2much
  • 59 posts
Posted 18 November 2014 - 10:39 PM
OK - tried it out. Verizon started working so it connects to my carrier. I like Lollipop better than I expected. Xposed doesn't work. But - I can see the day when I'm going to run it. Saving a backup and restoring Bliss Stalk.
#20 grinz2much
grinz2much
  • 59 posts
Posted 18 November 2014 - 10:55 PM
What to call it?
BlissPop?
BlissStalk-L?
Also tagged with one or more of these keywords: cm12, lollipop, 5.0, moto_msm8960
