OTA Flasher 1.0
28 replies to this topic
#1 SamuriHL
  • 44,535 posts
Posted 08 November 2014 - 08:34 AM
Please do yourself a favor and read, read again, and read one more time before installing and using this tool.  If it's set up correctly, it's very easy to use.  But if you don't follow directions, it'll either not work or not do what you expect.  Failure to read and follow the directions is NOT a defect of the tool!
Mission statement for tool:
This will allow users to sideload an OTA update zip to their phone.  Nothing more, nothing less.
WARNINGS:
o) You MUST be COMPLETELY STOCK to use this tool
o) Did I mention COMPLETELY stock?
o) That means no customizations to the system partition
o) Completely stock does NOT mean having TWRP or CWM or any other non-stock recovery installed
o) Failure to understand these warnings will result in lots of bad things™ happening
Downloads:
o)
Install:
o) Unzip to your C:\ drive <-- THAT DOES NOT MEAN JUST ANYWHERE YOU FEEL LIKE IT.  Just sayin'.  This means LITERALLY.
o) Optionally install the Universal ADB driver
Usage:
o) Copy your OTA zip file to the OTA sub-directory in the OTA_Install folder on your C:\ drive
o) Run the RunMe.bat file
o) Select the OTA from the menu
o) Follow the directions!!
NOTES:
The process for getting into stock recovery may be slightly different depending on your phone model/version/etc.  You may have to google it up to find out how to enter stock recovery.  That is up to you to do.
Once in stock recovery, you'll need to find the option for sideloading the update.  Sometimes it's called "apply update from adb".  Sometimes it's called sideloading.  This is device/version specific, as well, so you may have to search to find out how to get into the sideload mode in your particular stock recovery.
If your device is not recognized by ADB once in sideload mode, you should install the universal ADB driver and that should take care of it.
CAUTION:  This is version 1 and hasn't been tested.  I'm fairly sure it'll work, but, you know, version 1...
  • matjmonk, livinginkaos, transmissiontech and 2 others like this
#2 comiskeybum
comiskeybum
    Droid Oracle
  • 16,875 posts
  • LocationSouth Bend, IN
  • Current Device(s):Pixel 7pro, Pixelbook Go, Galaxy Watch 5pro
Posted 08 November 2014 - 08:45 AM
Sweet. I'll try it when I get home
Sent from my PURE blooded Moto X (2014)
Pixel 7pro, Pixel 6pro, Pixel 6a, iPhone 13, Galaxy Tab A7lite, iPad pro 2020, Galaxy Watch 5pro
#3 SamuriHL
  • 44,535 posts
Posted 08 November 2014 - 08:56 AM
Yea, let me know how it goes.  I obviously can't test it until I get a new OTA.
#4 comiskeybum
comiskeybum
    Droid Oracle
  • 16,875 posts
Posted 08 November 2014 - 12:37 PM
Sam, You around?  I am at step "select OTA from the menu"  however when i push 1 and hit enter it just blinks the screen and nothing happen.  Typing "e" exits the installer as it should.
#5 comiskeybum
comiskeybum
    Droid Oracle
  • 16,875 posts
Posted 08 November 2014 - 01:09 PM
Do I need the phone in recovery before I select option one maybe?
#6 SamuriHL
  • 44,535 posts
Posted 08 November 2014 - 01:54 PM
When I run it locally with your update and select option 1, I get:
Please ensure your phone is:
o] Charged
o] Connected to a USB 2 port using your OEM cable
o] USB drivers are updated and installed
You must be in stock recovery...
On Motorola phones:
o] Power off
o] Hold volume up and down, press power
o] Volume down to recovery, power up to select
o] On the Andy icon screen, hold volume up, press power to bring up the menu
For other phones, the process will be similar but MAY be slightly different
Once in recovery, select the option 'apply update from ADB' or similar
Ready to install...
And I don't have jack connected.  The answer is no, you do not need the phone connected until you press any key at the ready to install prompt.
#7 comiskeybum
comiskeybum
    Droid Oracle
  • 16,875 posts
Posted 08 November 2014 - 02:02 PM
Ok let me try it again.
#8 SamuriHL
  • 44,535 posts
Posted 08 November 2014 - 02:04 PM
Let me just ask one small little question.....because you've posted zero information which is what people do all the time that I complain about endlessly, let's just hypothetically wonder if you followed the installation instructions EXACTLY, or, perhaps you may have been a bit liberal with them and didn't follow them EXACTLY...
#9 comiskeybum
comiskeybum
    Droid Oracle
  • 16,875 posts
Yeah I keep hitting option 1 and nothing happens
#10 comiskeybum
comiskeybum
    Droid Oracle
  • 16,875 posts
Posted 08 November 2014 - 02:07 PM
Yes, I unzipped into a folder that I use on my C drive for android stuff.  Then i double clicked on run.  Two options appear.
1. blur_version.21.21.42.victara_tmo.tmo.en.us
e. exit installer
#11 SamuriHL
  • 44,535 posts
e. exit installer
SMFH.  Exactly my point.
#12 comiskeybum
comiskeybum
    Droid Oracle
  • 16,875 posts
Posted 08 November 2014 - 02:08 PM
Ok so you cant use a sub folder?  I did not know that.
#13 comiskeybum
comiskeybum
    Droid Oracle
  • 16,875 posts
i will reinstall to C drive with no sub folders
#14 SamuriHL
  • 44,535 posts
Posted 08 November 2014 - 02:09 PM
Re-read the OP and see if it's clearer now.
#15 comiskeybum
comiskeybum
    Droid Oracle
  • 16,875 posts
Posted 08 November 2014 - 02:13 PM
Yes yes yes.........got it...........i have to re dowload the effing zip file cuz i deleted it when i deleted the the installer.  give me a few.
#16 comiskeybum
comiskeybum
    Droid Oracle
  • 16,875 posts
Posted 08 November 2014 - 02:23 PM
flashing blur version.......
#17 SamuriHL
  • 44,535 posts
Posted 08 November 2014 - 02:25 PM
Enjoy.
#18 comiskeybum
comiskeybum
    Droid Oracle
  • 16,875 posts
Posted 08 November 2014 - 02:26 PM
Thanks for that "small" little correction.  LOL.
#19 SamuriHL
  • 44,535 posts
Posted 08 November 2014 - 02:29 PM
I assume it's done installing now?
#20 comiskeybum
comiskeybum
    Droid Oracle
  • 16,875 posts
Posted 08 November 2014 - 02:31 PM
It is, the phone is currently unpacking new files
