[FXZ] 4.4.4 21.21.15
35 replies to this topic
#1 SamuriHL
  • 44,493 posts
Posted 04 November 2014 - 11:34 AM
WARNING: You REALLY need to UNDERSTAND and read EVERYTHING or you MAY brick your phone!
Purpose of this thread:
To get you, the locked or unlocked (bahahaha, sorry) Droid Turbo XT1254 owner, from any version to 4.4.4 (KDF21.128-15.15).
Things you will need:
FXZ KDF21.128-15.15
Instructions:
Use the RSD Flasher with KEEP DATA to flash this to your phone with RSD.
OR
Use the House of Moto with KEEP DATA to flash this to your phone with fastboot.
  • livinginkaos likes this
#2 livinginkaos
Posted 04 November 2014 - 11:59 AM
Disregard this statement....... I have short term memory loss...... ha ha ha
  • SamuriHL likes this
#3 SamuriHL
  • 44,493 posts
Posted 04 November 2014 - 12:08 PM
http://www.droid-lif...build-21-21-15/
I disagree with your assertion at this time.  :)
#4 livinginkaos
Posted 04 November 2014 - 12:27 PM
Oh yeah, I did have an update out of the box.... my bad.
#5 HDWILLIAMS
HDWILLIAMS
  • 41 posts
  • LocationCalifornia
  • Current Device(s):XT1254,Acer A200
Posted 05 November 2014 - 09:38 PM
Having problems. I can't seem to boot into fastboot mode in order to flash the blur Version. Via Rsd Lite. I am a hella noob so please bare with my lack of terminology. Ty.
#6 livinginkaos
Posted 06 November 2014 - 04:46 AM
With the phone off, hold the volume down then press and release the power while continuing to hold the vol down for a couple seconds.
I have to ask, why did you need to flash this fxz?
Turbo Driven Comment
#7 irishkush
irishkush
  • LocationPhiladelphia
  • Current Device(s):Droid Turbo, Galaxy Note II
Posted 06 November 2014 - 12:15 PM
This may the big dummy question of the day, but is this file the same as the OTA that VZW was pushing to new DT owners?
If it is, I have already applied to my DT, and that concludes my existence on this thread.
If not, what is special about it?
Finally, do I get something special (other than my account closed) if this was the big dummy question of the day?
Thanks!
#8 livinginkaos
Posted 06 November 2014 - 12:20 PM
Thanks!
Yes, this is the same build that they OTA'd out of the box.  The reason this is here is to support the device for those who have run into problems.  Also if the OTA to this build fails, flashing this FXZ will get you there just the same, but cleaner.
Not a dummy question.  We've seen much worse :)
  • irishkush likes this
#9 livinginkaos
Posted 06 November 2014 - 12:21 PM
BTW, things do tend to show up here sometimes ahead of OTA, even into the soak timing, so don't be afraid to come back.
#10 irishkush
irishkush
Posted 06 November 2014 - 12:40 PM
Understood and THANKS for the quick and merciful response!!
#11 HDWILLIAMS
HDWILLIAMS
  • 41 posts
Posted 06 November 2014 - 02:11 PM
I was under the assumption that if I flashed the Blur_version.21.21.15.quark_verizon.verizon.en.us.zip I would get rid of the bloat ware. Was I wrong for assuming this? If so please forgive my Ignorance in advance.
#12 SamuriHL
  • 44,493 posts
Posted 06 November 2014 - 02:13 PM
Why would you think that, exactly?  I'm not sure why people get the impression that an FXZ is somehow different than the OTA.  It's EXACTLY the same.
#13 HDWILLIAMS
HDWILLIAMS
  • 41 posts
Posted 06 November 2014 - 02:19 PM
Actually I wanted to flash back to out of the box. I took the 1st OTA. And did not want to do that.
#14 livinginkaos
Posted 06 November 2014 - 02:25 PM
You cannot flash backwards...
#15 SamuriHL
  • 44,493 posts
Posted 06 November 2014 - 02:33 PM
And it makes no sense to want to go back to a broken build anyway.
#16 HDWILLIAMS
HDWILLIAMS
  • 41 posts
Posted 06 November 2014 - 02:37 PM
TY for the Info. As my avatar states I'm a Hella noob. Again Thank You.
#17 transmissiontech
transmissiontech
    Your Tranny Specialist
  • 7,484 posts
Posted 06 November 2014 - 09:07 PM
Wasnt this a major bug fix OTA or FXZ....
Google pixel 32 gig....
#18 BladeRunner
BladeRunner
    Chatroom Tech Support
  • 347 posts
  • LocationMaine
Posted 11 November 2014 - 01:28 PM
What bugs did it allegedly fix?  The Turbo I had was running fine on 21.12.12
#19 SamuriHL
  • 44,493 posts
Posted 11 November 2014 - 01:47 PM
No idea.
#20 GTIM2L8
GTIM2L8
    A Man On A Mission!
  • 89 posts
  • Twitter:@GTIM2L8
  • Google+:gtim2l8
  • LocationThe Southern State That Started It All.
  • Current Device(s):Raspberry Pi, Droid Razr Maxx HD XT926 - Droid Razr XT912 - TF201 Asus Transformer Prime
Posted 07 January 2015 - 12:14 PM
I was just wonderiing if anyone has seen this for the XT1225? Turbo.
Is this even possible?
http://gadgetunlocke...-twrp-recovery/
How to root Verizon Motorola Droid Turbo XT1225 with TWRP Recovery
  1. Download both the file and extract the Xperia Advance Kernel, inside the extracted folder, you will find a file called boot.img (if not, then rename the .img file to boot.img), copy the file and paste it to the working fastboot folder on your PC.
  2. After completing the first step, go to the fastboot folder and open command prompt there, do press Shift+Right Click and select ‘open command prompt here’.
  3. Now connect your device to your PC via USB cable and run the following commands:
    adb reboot bootloader
    fastboot flash boot.img
    fastboot reboot
  4. Now disconnect your device from your PC and boot into recovery, to do so: first switch off your device and press Volume Up+Power until you see Moto logo on the screen.
  5. In the next screen you will several options, you just select “install from SD card” option, it will ask you to locate the zip file, just locate the SuperSU zip file that you have already copied to your device’s SD card.
  6. After completion, just reboot your device.
Tha’s it, you have successfully rooted Verizon Motorola Droid Turbo XT1225
''Imagination is more important than knowledge. Knowledge is limited. Imagination encircles the world.'' - Albert Einstein
