DOWNLOAD FOR XT910:
[01/29]
GAPPS:
(Use CM10.1 - 4.2.1 version at the top)
ALL BUILD REFRESHES WILL INCLUDE LATEST CM10.1 CHANGES
WHAT'S WORKING:
- [01/23]MMS Fix(VZW)
- [01/18]Incoming phone call bug fixed
- [01/16]Bluetooth device starts/stops correctly (audio issues still)
- Phone / 4G Data
- Wifi
- Display rotation has been fixed
- Camera should work for images/video
- GPS
- HD codecs for YouTubeHD and Netflix
- Bluetooth audio needs work (leaving Bluetooth ON but unpair will cause the entire device to lose audio, turning Bluetooth OFF while unpaired fixes)
- No hwcomposer yet for enhanced composition (wifi display, gpu enhanced overlays for battery savings)
- GUI has some graphical "tearing" when moving rapidly through screens. We need to update graphics binaries to fix.
- Wireless tether has some fields mixed up
- Requires Safestrap 3.05+ and it's HARDCODED to only work from ROM-SLOT1 for now
- Download the .zip and place it on your SD card
- Reboot into recovery, install the .zip file and GAPPS from here: (use CM10.1 version at the top)
- I've always tested with a full wipe and TitaniumBackup restore of apps/data.
- Enjoy
Why only ROM-SLOT1 for now?
Due to some security changes in 4.2.1 I was having issues with the initial Safestrap script running early in the init process. This script checks to see what the "active" ROM-slot is and maps the correct system/userdata and cache files.
I'll fix this later, but for now always install 4.2.1 ROMs to ROM-SLOT1.
