[Theme] Master Page for Pink Floyd theme - Various ROMS
Pink Floyd Pink Floyd ZKK007 Theme
71 replies to this topic
#1 ZKK007
ZKK007
    That Kiwi Guy
  • 1,687 posts
  • LocationDallas, TX, USA.
Posted 05 December 2012 - 09:24 AM
Pink Floyd
Hi all, enjoy some Pink Floyd!
PLEASE NOTE: The above picture is based on the Aviator ROM. This shows you what the theme looks like. It will look slightly different on each rom due to rom differences such as lockscreen layout, etc.
Custom boot animation:
This does have a short boot sound if your rom allows for music during the boot animation. Some roms will not play sound during boot animation.
I am not responsible for anything that may happen to your device. (…Nothing should happen)
General Thanks: JaeKar99 - bootanimation help. sherrylee0669 - custom icon help. Thanks to the individual rom creators will be under their rom section.
What apk's have been themed (some more than others):
  • Framework-res
  • Browser
  • Contacts
  • Camera
  • Email
  • Gmail
  • MMS
  • Phone
  • SystemUI
Differences to stock roms:
  • Bootanimation – Taken from "The Wall" movie. No copyright infringement intended!
  • Battery Icon changed (with 1% battery changes).
  • Status Bar Icons.
  • Dialer font.
  • Lockscreen Clock Font - Font inspired by "The Wall."
  • Dock and Lockscreen Icons.
  • Default Wallpaper – Can be changed to any wallpaper.
  • White text in SMS.
  • MANY different icons.
Installation:
  • This is assuming you are already on the Rom you want this theme for.)
  • Download and install onto SD Card.
  • Reboot into Recovery Mode SafeStrap (I have only tested using SafeStrap v3.xx, but it should also work with 2.11).
  • If you want to be safe: Wipe Cache, Wipe Dalvik Cache (In “Wipe”).
  • Choose “Install”
  • Locate “Pink Floyd” file.
  • Swipe to Confirm Flash
  • After installation, Reboot, and enjoy!
Downloads:
Aviator
(Current Theme Version v1.0.7)
THIS IS BASED ON Aviator ROM:
Download:
Uninstall Theme and return to stock Aviator:
Default_wallpaper:
(It may not change upon flash):
Icon Pack:
This is a zip of various circle icons (Not shown on images, but similar color, just a different picture). Download, unzip and move the icons you want to your SD card. To change you will need to change each icon individually. Long press on the icon, select Edit, press icon, and locate the icon you want to replace it with. Then press OK.
If anyone would like to pull and edit to use things for theming etc, go ahead. If you do post, all I ask is to be added under credits with a link to the page. You do not need to ask.
  • mugsy77, lownslow200sx, vtwinbmx and 3 others like this
Donate? Click on signature :)
#2 ZKK007
ZKK007
    That Kiwi Guy
  • 1,687 posts
Posted 05 December 2012 - 09:25 AM
ICS ROM LIST
(Unsupported)
SIMPLEX:
(Current Theme Version 1.0.2)
THIS IS BASED ON Simplex-V1.3 | Ics4.04 | 10/1/2012 ROM:
– Creator of Simplex Rom.
Download:
LICORICE:
(Current Theme Version 1.0.1)
THIS IS BASED ON (Aokp) Licorice 1.0 *non Kexec* ROM:
– Creator of (AOKP) Licorice 1.0 Rom
Download:
FULL THROTTLE RETRIBUTION (CM9):
THIS IS BASED ON Full Throttle Retribution V2 Cm9 {10/19/12} ROM:
– Creators of Full Throttle Retribution Rom.
Download:
FULL THROTTLE RELOADED (AOKP):
THIS IS BASED ON Full Throttle AOKP M6 Reloaded {11/9/12} ROM:
– Creators of Full Throttle Reloaded Rom.
Download:
EVOLUTION:
THIS IS BASED ON Evolution 5.1 | ICS 4.0.4 | .215 Base | [12/10/12] ROM:
- Creator of the Evolution Rom
Download:
Change Log:
V1.0.2 - Updated to Evolution 5.1. Removal of Gmail. Replaced MotoCamera with Evolution 5.1 BlurCamera.
REVOLUTION:
THIS IS BASED ON Revolution 1.1 | ICS 4.0.4 | Blur Version | [12/10/12] ROM:
- Creator of the Revolution Rom
Download:
Change Log:
V1.0.2 - Updated to Revolution 1.1. Removal of Gmail and Email from theme. Replaced MotoCamera with Evolution 5.1 BlurCamera.
FLICK:
THIS IS BASED ON Flick 5.0 Tornado [12/3/12] ROM:
- Creator of the Flick Rom
Download:
White Widow:
THIS IS BASED ON wWidow ICS ([6.16.214 ROM]) ROM:
- Creator of the wWidow Rom
Download:
Arctic HD:
THIS IS BASED ON Arctic HD ROM:
- Creator of the Arctic HD Rom
Download:
Eclipse:
THIS IS BASED ON Eclipse 1.5 ROM:
- Creator of the Eclipse Rom
Download:
  • trekkin1707 likes this
#3 ZKK007
ZKK007
    That Kiwi Guy
  • 1,687 posts
Reserved.
#4 prosaschi
prosaschi
  • 313 posts
  • Google+:paulrosaschi@gmail.com
  • LocationTucson, AZ
Posted 05 December 2012 - 12:53 PM
How about for the White Widow ICS?
#5 ZKK007
ZKK007
    That Kiwi Guy
  • 1,687 posts
Posted 05 December 2012 - 01:11 PM
Links for Full Throttle AOKP M6 Reloadedand Flick 5.0 Tornado have been added to the OP.
#6 ZKK007
ZKK007
    That Kiwi Guy
  • 1,687 posts
Posted 05 December 2012 - 02:24 PM
I'll have to check with the rom dev first, but it is definitely possible.
#7 andlaw
andlaw
    BW ftw!! !!!!!
  • 2,463 posts
  • LocationOH-I-O
Posted 05 December 2012 - 02:31 PM
your always more than welcome to port themes over to any of my ROMs. .. wwidow ICS could always use another theme :ph34r: btw Pink Floyd ftw!
#8 ZKK007
ZKK007
    That Kiwi Guy
  • 1,687 posts
Posted 05 December 2012 - 03:17 PM
Thanks! I'll probable have time this weekend to do it :)
#9 bfederspill
bfederspill
  • 284 posts
  • LocationRoy, Utah
  • Current Device(s):Razr Maxx
Posted 05 December 2012 - 06:20 PM
Thank you for doing it for Full Throttle reloaded M6.
Not to ask for too much but could you throw one in for Artic HD also? That's the second rom I use on a regular bases.
Sent from my Droid Razr Maxx
#10 ZKK007
ZKK007
    That Kiwi Guy
  • 1,687 posts
Posted 05 December 2012 - 10:16 PM
You're welcome. If I get time this weekend I'll port it over to Arctic HD as long as its OK with the dev :)
#11 logan3824
logan3824
  • 308 posts
  • LocationHouston, Texas. GO TEXANS!
Posted 06 December 2012 - 12:55 AM
This is awesome work and I use it, the only thing I didn't like was the font...My eyes just aren't a fan of it lol...But love the work you did and since this band is my favorite, I'll be using it far into the future!
#12 ZKK007
ZKK007
    That Kiwi Guy
  • 1,687 posts
Posted 06 December 2012 - 04:55 AM
What rom are you using? I know there was one rom where I had to change the whole system font. I'll look for another Pink Floyd font and perhaps offer it as an add on. It won't take much to switch it out.
Let me work on it :)
#13 ZKK007
ZKK007
    That Kiwi Guy
  • 1,687 posts
Posted 06 December 2012 - 02:24 PM
How about this font? It has been used by Pink Floyd in the past.
Let me know what rom you're on and I'll let you know what files to change.
  • logan3824 and trekkin1707 like this
#14 usmcamgrimm
usmcamgrimm
    Berserker
  • 958 posts
  • Twitter:@usmcamgrimm
  • LocationMassillon, OH
  • Current Device(s):VZW G3
Posted 06 December 2012 - 05:37 PM
Looks awesome!
#15 logan3824
logan3824
  • 308 posts
Posted 07 December 2012 - 11:20 AM
I just switched to the Droid font. Used font changer in the play store and everything is working smooth. I've been complimented multiple times on this theme!
#16 ZKK007
ZKK007
    That Kiwi Guy
  • 1,687 posts
Posted 07 December 2012 - 12:04 PM
Awesome! Glad you found a solution!
#17 ZKK007
ZKK007
    That Kiwi Guy
  • 1,687 posts
Posted 07 December 2012 - 01:09 PM
Busy afternoon of porting, but now we have Pink Floyd for Evolution 5, Revolution 1.0, wWidow ICS and Arctic HD! Enjoy!
#18 johnthehillbilly
Posted 07 December 2012 - 01:16 PM
Nice work! ... now i can take my RAZR (arcticHD and simplex) to the "dark side of the moon" :)
sent from my DROID RAZR tapadriving ...
#19 willjohnson
willjohnson
  • 32 posts
  • LocationSavannah, Georgia
Posted 09 December 2012 - 07:39 AM
Don't knowif its your themed apps or the roms, but just about all the apps from Google in the Evolution rom need to be updated, but have to be deleted and redownloaded because of the inversion(you get the package was signed incorrectly error from market). Again not complaining just letting you know the only problem I see in an otherwise beautiful theme. Probably something the Rom devs will have to fix anyway. Thanks for the great work.
#20 ZKK007
ZKK007
    That Kiwi Guy
  • 1,687 posts
Posted 09 December 2012 - 09:01 AM
Yeah, the rom uses inverted gmail, etc. as a way to keep amazing battery sipping usage to a minimum. Normally the updates are turned off so the play store does not ask you to update these apps. If you do update, they will be the stock gapps. I'm not sure if Halo13 will update the rom to the new versions or not. If he does I will make the small changes I made. If you want the icons to match, just use the icon pack listed above and you will get the same look as the theme :)
Also tagged with one or more of these keywords: Pink Floyd, Pink, Floyd, ZKK007, Theme
