Help Help Help XT925
14 replies to this topic
#1 timeport323
timeport323
  • 5 posts
  • Current Device(s):Motorola XT925
Posted 25 October 2014 - 11:11 PM
this is my last resource. got an XT925 a year and half ago. didn't use it until now. used it for two weeks and the 'M' logo was stuck when booting.  I tried everything in AP Fastboot and nothing worke. i  even tried factory wipe in the external hard reset.  can't even get into the android lying down now with the yellow exclamation.
I've tried almost every possible solution out there. Right now I am only able to get to AP Fastboot and that's it! anything out there to get this phone up and running?  this is all i see:
AP Fastboot Flash Mode (S)
10.9B(*) (sha-61146a2, 2014-05-02 03:15:48)
eMMC Info: Size 16GB
Device in UNLOCKED, Status Code:3
Battery OK
Transfer Mode:
USB Connected
Fastboot Reason: Boot menu selected
usb connected
Like I said, I've tried everything. I even get error messages such Invalid partition or when trying to install CWM or TWRP
Motorola XT925
#2 shane1
shane1
    Droid Elite
  • 1,596 posts
  • Twitter:1shane15
  • Locationny
Posted 26 October 2014 - 05:09 AM
Have you tried flashing whatever firmware you where previously running?
sig made by
Rinkle McBally
#3 timeport323
timeport323
  • 5 posts
Posted 26 October 2014 - 10:28 AM
Thx for your reply. I have tried that too. I even edit the firmware to and deleted the 'get var' 'oem'' lines. I just want to go back to original factory settings. Most forum suggest I need to ensure my USB debugging is on, but I can't even get into my phone to enable it. I only unlock the boot loader because most people said I needed to.
#4 shane1
shane1
    Droid Elite
  • 1,596 posts
  • Twitter:1shane15
  • Locationny
Posted 26 October 2014 - 12:29 PM
What errors do you get when you run rsd? Need as much info as possible to try to help.
sig made by
Rinkle McBally
#5 livinginkaos
Posted 26 October 2014 - 12:36 PM
Also, what firmware are you flashing, exact name. Does your AP Fastboot screen show "Battery OK"?
sent from my G3
  • shane1 likes this
#6 transmissiontech
transmissiontech
    Your Tranny Specialist
  • 7,484 posts
Posted 26 October 2014 - 03:40 PM
I wonder if it was taking an ota update and battery died in the middle of update.
Google pixel 32 gig....
#7 livinginkaos
Posted 26 October 2014 - 03:50 PM
This is the 925 though
sent from my G3
#8 transmissiontech
transmissiontech
  • 7,484 posts
Posted 26 October 2014 - 04:21 PM
He said it had not been used for 1 year and 1/2 and he turned it back on and it worked for 2 weeks, then it went south...thats why i said what i said...so this phone hasnt had any updates in the last year and 1/2 then, just seems strange it would just up and go poof without something being done, unless hardware failure happened.
my 1/2 cent
#9 timeport323
timeport323
  • 5 posts
Posted 26 October 2014 - 07:48 PM
Battery is OK
Here is the firmware I am trying:
7.7.1Q-144_VQL_S3-49_USERSIGNED_CANADA_SIGNCanadaIRDUnlk_USAVANQURGRCANA005.0R_CFC_fastboot.xml
The error message on RSD Lite 6.1.6:
Failed flashing process. 1/20 flash partition "partition_signed" -> Phone returned FAIL
The error message on the phone:
downgraded security version
update gpt_main version failed
preflash validation failed for GPT
I have even tried RSD Flasher, error message:
Extract failed. check your zip file and extract manually
I extracted it manually with winrar, but when i tried flashhing with any of the option, nothing came up. i don't even get the other window that suppose to open up.
Thanks everyone
#10 livinginkaos
Posted 27 October 2014 - 03:49 AM
First off, it is unnecessary to extract it as RSD will do so for you. Secondly,the error you are getting tells you the problem, you are trying to flash older firmware than what was on your device. You need the same or newer. That should be able to be found here -
Your bootloader must be unlocked in order to flash a custom recovery. The invalid partition error when flashing recovery sounds like you might have the fastboot command incorrect?
Fastboot flash recovery nameofrecovery.img
sent from my G3
  • RikRong likes this
#11 timeport323
timeport323
  • 5 posts
Posted 27 October 2014 - 06:28 PM
i tried your suggestion and still get the same error on the phone:
I tried both version of the firmware for Rogers (Canada)
Any other ideas?
#12 RikRong
RikRong
    Cap'n Slow
  • 2,117 posts
  • LocationNoDak
  • Current Device(s):Pixel 7
Posted 28 October 2014 - 07:58 AM
That's saying that you're still trying to downgrade.  Do you know what version you were on, prior to the issues you're having?  Did you flash the FW from here:
#13 timeport323
timeport323
  • 5 posts
Posted 28 October 2014 - 10:27 AM
I did try the FW from the link.  I don't know which FW it was because I didn't use the phone for over a year and a half. There's only two FW listed. I tried both FW and they both didn't work.
FW 4.0.4 could not run as it was saying the file extension is too long
FW 4.1.2 got an error on 3/23
Am I missing something else?
#14 xXGhosToastXx
xXGhosToastXx
Posted 15 January 2016 - 06:35 AM
got a similar problem with my XT925... but I have a boot loop... to fix it I need that fastboot.xml... which one do I need when living in germany?
#15 spainter
spainter
    Droid Oracle
  • 3,339 posts
  • LocationUtah
Posted 15 January 2016 - 07:43 AM
