Cm10 and 10.1 will never have the battery life of a stock based rom. It's a tough choice between customizable, no bloat, newest software vs battery stability. If it's any consolation I've found cm10.1 charges faster than stock. So it will go from 50% to 90% in like 15 or 20 min on a wall or car charger.
That doesn't sound like it's getting the right charge if it's doing that software shouldn't affect how fast it charges the amp rating of the charger should affect that I could be wrong though
I agree, charging rate should be handled by the chip on the battery not the phone. But ya if it's not reading the chip right it's not really knowing what is going on. I wonder if you run it all the way down till it dies if it sits at 1% for 5 hours lol
It will do exactly that. An easy fix is to let the phone die, than charge to 100% without interruption. If you have the know how wipe the battery stats too.
I find I get better battery life with cm10.1. Mostly because I don't have useless bloat pulling power for junk I'll never use.
Get an app like rom toolbox that allows you to turn off auto start receivers. It's crazy how many apps start automatically and draw power. Just one reason android makes iOS look so bad. You have full control over your phone, may as well use it....... Just my two cents.
P.s. I hate blur. It has a corporate stink attached to it that is anathema to the open source community. Companies make things for profit, devs make things ( ROMs, apps, kernels) for the challenge and because it's fun. It shows clear as day too.
Sent from my XT907 using Xparent Blue Tapatalk 2
