Ya that's probably it, I'll redownload it
I downloaded the new AOSP rom and got error code 7.
Posted 14 May 2013 - 05:17 PM
Need Help? Send me a message
Posted 14 May 2013 - 05:52 PM
Yea I've download it on my phone, desktop, and slate pc and all get error 7.
Posted 14 May 2013 - 06:24 PM
Posted 15 May 2013 - 05:04 AM
just tried this on my xt907 and got the fail also. it fails the ro.product.device assertion.
here is the the xt907 version with the asserts removed from the updater-script:
Hope this is ok
Posted 15 May 2013 - 06:04 AM
Started running Mic's latest build, and I'll have to say it's the best version of CM10 I've had on the phone so far. Good work.
Posted 15 May 2013 - 11:28 PM
idk what the problem is but ive tried to flash this to my phone multiple times, everything seems to be successful i wipe and flash just like i would with any other rom once i install and reboot i get the Cyanogenmod boot screen and it just continues to try to boot up i waited today for literally 30 minutes it still didnt start up so i said F it, did a soft reset went back into safestrap wiped and flashed my old rom back and booted up no problem..i do understand that the Cyanogenmod first boot up tends to take longer then other roms but 30 mins with no luck just doesnt seem right to me...any idea what the problem could be? am i missing something? not being patient enough? ive had no issue with any other rom but this one, and from what ive heard and seen Cyanogenmod seems to be the way to go, any insight would be greatly appreciated
Just curious to know if you ever got an answer. You are grabbing the SafeStrap version and not the version meant to be flashed in a unlocked boot loader using a full custom recovery like TWRP/CWM? Curious to know if this might be your issue? I'm unlocked, so I'm not using SafeStrap.
Twitter: @motoroid7
ADN: @seven07
Posted 15 May 2013 - 11:41 PM
Honestly, I wouldn't even touch the original versions posted in the OP. mic213 has posted several updates to this in the last few pages. The last build seems to be 100% bug free and highly customizable.
Posted 16 May 2013 - 06:30 AM
Just curious to know if you ever got an answer. You are grabbing the SafeStrap version and not the version meant to be flashed in a unlocked boot loader using a full custom recovery like TWRP/CWM? Curious To know if this might be your issue? I'm unlocked, so I'm not using SafeStrap.
Posted 16 May 2013 - 11:40 AM
I don't even think the original links work. I had to scroll through the thread until I found his post where he linked to the updated file when I originally wanted to flash this.I try to go with the latest updates if I can anyways... they usually have things I want fixed. Though I'm holding off on 10.1. It seems there are a good number of issues going on to keep people from having it as a daily driver.
Also, anyone else having issues with Bluetooth in the latest version of this? It seems to connect to my headset but doesn't manage to push audio to it for even calls. I have it selected during the phone call too. My headset is Motorola S-10 HD.
Twitter: @motoroid7
ADN: @seven07
Posted 16 May 2013 - 03:16 PM
In my experience any rendition of CM has Bluetooth issues as it relates to the Razr M. I have a Bluetooth speaker I like to stream to and it has never worked properly with CM.
Posted 16 May 2013 - 03:23 PM
Posted 16 May 2013 - 06:56 PM
I haven't tried anything BT yet. I rarely use it, usually only to transfer files between the computer and the phone. I'll try it out tomorrow and see what happens. On Trippin' Bean, BT wouldn't work for me at all but that's because it was a CM build designed to work in SS. CM builds don't get along well with the stock ROM as a base.
Posted 24 May 2013 - 04:21 PM
Hey Mic, wondering if there wil be an update soon? Just wondering cause it has been a while.
And DevHost is down does anyone have a mirror for the most recent CM10 please? The 5-9-13 build
Posted 24 May 2013 - 08:31 PM
Posted 25 May 2013 - 03:26 AM
I think everyone's been leaning on cm10.1 here lately it's already DD material
Posted 25 May 2013 - 08:30 AM
Posted 25 May 2013 - 11:39 AM
Posted 25 May 2013 - 01:26 PM
Cm10 and 10.1 will never have the battery life of a stock based rom. It's a tough choice between customizable, no bloat, newest software vs battery stability. If it's any consolation I've found cm10.1 charges faster than stock. So it will go from 50% to 90% in like 15 or 20 min on a wall or car charger.
Posted 25 May 2013 - 03:36 PM
That doesn't sound like it's getting the right charge if it's doing that software shouldn't affect how fast it charges the amp rating of the charger should affect that I could be wrong though
Posted 25 May 2013 - 06:56 PM
