Mine says. 44mb, thought it was normal. Is it not right?
I mean like your combined MB at the bottom there is like 700mb or so. On stock OS it's a little over 800mb. I'm really curious as to why or if its just a glitch.
Posted 11 May 2013 - 01:44 PM
Posted 11 May 2013 - 02:03 PM
Need Help? Send me a message
Posted 12 May 2013 - 10:38 PM
Quick question with the latest version. Does anyone else have issues with trying to get the 4G icon to display? I seem to just always show 3G even when I believe I'm connected to 4G.
(My city is 4G city wide. I live 13 minutes outside of town and usually get 2-3 bars of 4G in my bed room, but here it displays 3G as well)
Thanks, loving this ROM so far. It's greatly improved my battery life and my phone runs much faster.
Twitter: @motoroid7
ADN: @seven07
Posted 12 May 2013 - 11:07 PM
Quick quesI has on with the latest version. Does anyone else have issues with trying to get the 4G icon to display? I seem to just always show 3G even when I believe I'm connected to 4G.
Change your mobile network setting to look like this. I had the same problem, this fixed it. See it shows 4g now.
Posted 13 May 2013 - 07:37 AM
Oh i gotcha. Yeah I'd like to know why too.
I believe it is just a glitch from porting to our device, when I was on a MyTouch4g we had a similar issue with one of the roms but the phone was still running at full specs/power.
I wouldnt worry about it too much,
on another note... why doesnt Mic create a new thread for his work on this? I am just curious, it seems like it would be easier if he does anymore updates.
Posted 13 May 2013 - 10:46 AM
Thank you for the response bud! Having Cyanogenmod again has really taken me back to my HTC Thunderbolt days.
Again, thanks for the reminder I needed to set this!
Twitter: @motoroid7
ADN: @seven07
Posted 13 May 2013 - 11:08 AM
idk what the problem is but ive tried to flash this to my phone multiple times, everything seems to be successful i wipe and flash just like i would with any other rom once i install and reboot i get the Cyanogenmod boot screen and it just continues to try to boot up i waited today for literally 30 minutes it still didnt start up so i said F it, did a soft reset went back into safestrap wiped and flashed my old rom back and booted up no problem..i do understand that the Cyanogenmod first boot up tends to take longer then other roms but 30 mins with no luck just doesnt seem right to me...any idea what the problem could be? am i missing something? not being patient enough? ive had no issue with any other rom but this one, and from what ive heard and seen Cyanogenmod seems to be the way to go, any insight would be greatly appreciated
Posted 13 May 2013 - 12:10 PM
I am bootloader unlocked, TWRP installed, running stock rom on consumer. Can I flash this, and which version should I use?
Posted 13 May 2013 - 12:23 PM
Should work fine, Im on CWM (I personally like CWM better) but it should work on TWRP. Download the newest verion from Mic321 build 05-09-13. His best build yet. Make sure you get the right GApps
ROM
GApps
Wipe eveything (Data, cache, dalvik cache, and system) Twice
Install Rom, Install GApps, Reboot
Posted 13 May 2013 - 01:51 PM
ROM
GApps
for whatever reason i had no problem getting this to work, not sure what the issue was with what i was doing before, thanks!
Posted 13 May 2013 - 05:18 PM
Posted 14 May 2013 - 04:31 AM
Quick tip for newbies on this ROM. When wifi won't connect or says avoided poor Internet connection.... This is how to fix it. Just run this app.
Posted 14 May 2013 - 07:42 AM
Here's a new CM10 build
- Added back adjustable nav bar height
- Added intellidemand, lagfree, and smartassv2 cpu governors
- Fixed NFC (Test and let me know how its working)
- Removed Trebuchet launcher and replaced with Apex Launcher 2.0.0
- Removed CM10 Camera and replaced with 4.2 Camera
CM10 -
CM10 for GSM Users -
going to try flashing this soon. looking forward to the results
Posted 14 May 2013 - 09:54 AM
Posted 14 May 2013 - 10:05 AM
Dhacker has a brand new aosp rom <br /><br />Sent from my SCH-I535 using Tapatalk 2<br /><br />
Where is it? Can't seem to find it anywhere.
Posted 14 May 2013 - 10:17 AM
Posted 14 May 2013 - 12:32 PM
Whats your twitter handle?
Follow the site @DroidRzr
Oh and follow me @cassdroid
Posted 14 May 2013 - 01:38 PM
Hmmmmm getting a status 7 error trying to install this on cwr
I use cwm also. Never had that problem, could be a bad download. Check the md5 sum. They must match. Do the same with the gapps.
Posted 14 May 2013 - 01:46 PM
Any list of bugs and what don't work? No official thread from Dhacker29?
Posted 14 May 2013 - 02:31 PM
