Nothing, what did you wipe?
I wiped everything. In CWM..... Factory reset, cache, dalvik cache, system (everything twice). Then installed. I noticed people taking about mounting the system before installing, that I did NOT do.
Posted 23 April 2013 - 12:17 PM
Need Help? Send me a message
Posted 23 April 2013 - 12:27 PM
CM comes with its own kernel so you shouldn't need to mount /system. After all the wiping try rebooting recovery, than flash rom then gapps.
Posted 24 April 2013 - 04:54 AM
Tried it, still no GPS any other ideas?
Posted 24 April 2013 - 05:01 AM
Posted 24 April 2013 - 05:15 AM
Try downloading GPS status from the play store...also...go to location/gps source/internal and select it. Reboot
Downloaded that and gpsfix. Changed the setting to internal gps. Rebooted, tried to get a lock. Still refuses to lock.
Posted 24 April 2013 - 02:16 PM
Here's a new sync of CM10, had to re download source and didn't add the adj nav bar height back yet, but still has Expandable desktop.
- Added smartassV2, interactiveX, ondemandX, and lagfree governors to kernel (Been using the interactiveX and getting improved battery)
Posted 25 April 2013 - 04:40 AM
Anyone know how to fix my gps problem? Maybe it will work in the new update?
Posted 25 April 2013 - 06:01 AM
- CM10
- CM10 for GSM Users (with build.prop and apns-conf.xml changes)
Thanks,
I've been experiencing many phone.apk force closes with previous version (on gsm), downloading to see if this helps.
Posted 25 April 2013 - 10:51 PM
I love this; the only issue, if you can call it that, that I'm having is that the phone must be in USB Debugging mode in order to charge from a computer. AC charges fine either way. Pretty sure it was Mic's build. Also have not tested the GPS yet.
Posted 26 April 2013 - 12:47 PM
- CM10
Thanks for the builds! we need more roms for the M now that the bootloader is unlocked!
Posted 26 April 2013 - 01:38 PM
Posted 28 April 2013 - 09:21 AM
I read on the xda thread that before flashing cm you had to enable all your gps settings in stock first. That may have been a safestrap thing though....
Thanks for the info but I'm unlocked and SS removed. Anyone else have anything that might fix GPS not locking? Let it sit an hour with no lock.
Posted 28 April 2013 - 09:24 AM
Thanks Mic for the new updates. Be nice to see a CM10.1 stable build.
Posted 28 April 2013 - 10:27 AM
Posted 28 April 2013 - 01:42 PM
Dhackers gotta new 10.1 build over on xda
Posted 29 April 2013 - 06:50 AM
Posted 29 April 2013 - 08:43 PM
Here's a new sync of CM10. I made some changes to the build.prop that improves graphics performance. Let me know how its working.
Posted 29 April 2013 - 08:46 PM
Here's a way of fixing GPS I read on this site (Been testing it to see if it actually worked). I had to install a stock based build and get the GPS to get a lock. Then I reinstalled CM10 after getting the lock and I've tested GPS repeatedly and GPS is working perfect. Not sure why it works like that, but it worked for me. Haven't had a problem since doing the lock on the stock build, and I've been flashing alot of builds I been testing out on my phone.
Posted 29 April 2013 - 08:53 PM
Posted 30 April 2013 - 10:09 AM
So I install a stock based ROM, get gps to lock, keep it on and then flash cm10 normally? Wipe data, system, cache, dalvik cache. Then gps will work on cm10? Just making sure I'm reading this right.
