CM10 UNOFFICIAL (BETA) for Droid Razr M (XT907) - Consumer and Developer Edition
162 replies to this topic
#61 brandon71
brandon71
  • 553 posts
  • Google+:tbd7171@gmail.com
  • LocationKodak, TN
Posted 15 April 2013 - 07:20 PM
Just noticed there's not a thread for cm10.1 randomly thought about it walla go anybody know if there's any new development for it it was pretty buggy last I checked
#62 Noigel
Noigel
  • 197 posts
  • LocationUkraine, Ivano-Frankivs`k
  • Current Device(s):Motorola Razr M XT907 / Motorola Razr I XT890
Posted 16 April 2013 - 12:46 AM
Here's a new CM10 build with the cherry pick to fix the sim toolkit message. Let me know if you still have the issue.
Thats perfect! But:
I have a problem with sending SMS - I can receive it, but can`t send...
And what about 2G/3G only toggle? Why it inactive?
How I can setup my APN for mobile data?
Motorola Droid Razr M XT907 / ROM: KitStalk by GraberRoms
post-103018-0-11429500-1388984908_thumb.
#63 mic213
mic213
  • 23 posts
Posted 16 April 2013 - 10:07 AM
Here's another CM10 build sync. I added expanded desktop, and adjustable nav bar height to the build. Let me know how it's running.
Also, for those using GSM (I use T-Mobile US), here's a GSMFix that includes a couple changes to the build.prop and the CM10 GSM APN list.
Flash after flashing the build.
*When using the expanded desktop, check disable hw overlays in develop options for best performance (*Tip for LMT Launcher users out there*)
  • Noigel likes this
#64 Noigel
Noigel
  • 197 posts
Posted 16 April 2013 - 11:30 AM
Thanx!!!!! It`s perfect!!!!
It have no any problems for my GSM!!
#65 brandon71
brandon71
  • 553 posts
  • LocationKodak, TN
Posted 16 April 2013 - 02:52 PM
Can I flash that on top or wipe everything first?
#66 dhacker29
dhacker29
    CM Master
  • 49 posts
  • Twitter:dhacker29
  • Google+:davidhackerdvm@gmail.com
Posted 16 April 2013 - 03:04 PM
no I always got the unlock sim card msg I've never seen that I'll flash this new version in a few and see if i get that too
Edit: getting the same thing after flash and it pops up multiple times in a row on me
There are a couple of abandoned patches in cm review that fix this issue
#67 timpohladthomas
timpohladthomas
    OSE DEVELOPER
  • 1,428 posts
  • Twitter:@timpohladthomas
  • Current Device(s):MOTO X
Posted 16 April 2013 - 03:58 PM
Best build yet! Keep them coming!
Can't seem to switch governor however...no biggie.
#68 brandon71
brandon71
  • 553 posts
  • LocationKodak, TN
Posted 16 April 2013 - 04:11 PM
i coudnt switch my governor either i use rom toolbox for that though
#69 RikRong
RikRong
    Cap'n Slow
  • 2,117 posts
  • LocationNoDak
  • Current Device(s):Pixel 7
Posted 16 April 2013 - 08:09 PM
Nice to see this coming along.  I might have to give it a try.
#70 nprevette420
nprevette420
    BlissPop Maintainer
  • Banned
  • 1,626 posts
  • LocationNC
Posted 17 April 2013 - 05:55 AM
I'm on build 4/14, Gapps 20121011, unlocked bootloader, SS removed, used CWM recovery to install and having no issues changing the governor. Using No-frills CPU Control.
Need Help? Send me a message
#71 timpohladthomas
timpohladthomas
    OSE DEVELOPER
  • 1,428 posts
Posted 17 April 2013 - 06:23 AM
Yeah, it changes fine with a third party cpu control app.  It does not change when I am using the performance section in settings.
#72 nprevette420
nprevette420
    BlissPop Maintainer
  • Banned
  • 1,626 posts
  • LocationNC
Posted 17 April 2013 - 06:32 AM
I see, well the option under performance section has NEVER worked for me on CM10 on any of the builds ever made for this phone. I've always used a third party app.
#73 ndarmr
ndarmr
  • Current Device(s):droid 2 droid 3 lg ally og razr droid razr maxx
Posted 17 April 2013 - 09:50 PM
is anyone else having issues getting the gsm fix to flash or 4g to appear
#74 etal
etal
  • Current Device(s):Razr M
Posted 21 April 2013 - 12:20 AM
I could not get the gsm fix to flash using twrp or cwm. I ended up manually copying the build.prop file from the gsmfix zip into the system folder using a root browser, it works just fine this way. Make sure to correctly set the permissions and group ownership on the file and then reboot.
Don't have 4G round here so I can't test that...
#75 nprevette420
nprevette420
    BlissPop Maintainer
  • Banned
  • 1,626 posts
  • LocationNC
Posted 23 April 2013 - 05:59 AM
Is there a GPS fix that can be flashed or baked into this ROM?
#76 brandon71
brandon71
  • 553 posts
  • LocationKodak, TN
Posted 23 April 2013 - 06:17 AM
I haven't had gps issues with this whenever I play around with it
#77 nprevette420
nprevette420
    BlissPop Maintainer
  • Banned
  • 1,626 posts
  • LocationNC
Posted 23 April 2013 - 06:22 AM
Not sure why but all cm10 ROMs I've tried have never gotten a gps lock. Stock based ROMs work fine. I guess it's just me. Does anyone else have gps issues with cm10?
#78 RikRong
RikRong
    Cap'n Slow
  • 2,117 posts
  • LocationNoDak
Posted 23 April 2013 - 07:36 AM
I had GPS and BT issues when I was running Trippin' Bean.  However, that was on SS, over the stock ROM.  Running a CM ROM over a stock base is just asking for trouble.  I've heard there have been far less issues running CM on an unlocked phone, provided that it was installed correctly.
  • brandon71 likes this
#79 nprevette420
nprevette420
    BlissPop Maintainer
  • Banned
  • 1,626 posts
  • LocationNC
Posted 23 April 2013 - 09:46 AM
Never had problems with BT. I am unlocked, SS removed and using CWM recovery. What is the proper way to install? I am just wiping everything and installing rom plus gapps. What am I missing?
#80 timpohladthomas
timpohladthomas
    OSE DEVELOPER
  • 1,428 posts
Posted 23 April 2013 - 12:06 PM
Nothing, what did you wipe?
