CM10 UNOFFICIAL (BETA) for Droid Razr M (XT907) - Consumer and Developer Edition
162 replies to this topic
#41 slogar25
slogar25
  • 43 posts
  • Current Device(s):Motorola Droid Razr M
Posted 13 April 2013 - 03:19 PM
Sorry here is the screen shot
Sent from my XT907 using Xparent BlueTapatalk 2
#42 brandon71
brandon71
  • 553 posts
  • Google+:tbd7171@gmail.com
  • LocationKodak, TN
Posted 13 April 2013 - 04:28 PM
no I always got the unlock sim card msg I've never seen that I'll flash this new version in a few and see if i get that too
Edit: getting the same thing after flash and it pops up multiple times in a row on me
  • neckchop likes this
#43 brandon71
brandon71
  • 553 posts
  • LocationKodak, TN
Posted 13 April 2013 - 08:34 PM
Getting the same problem with wifi again get an error connecting to network have to use wifi fixer to fix it
#44 mykalmunlight
mykalmunlight
  • 88 posts
  • Current Device(s):XT907 (DROID RAZR M)
Posted 13 April 2013 - 11:18 PM
Could not even start wifi on either buid. :angry:
#45 mic213
mic213
  • 23 posts
Posted 13 April 2013 - 11:24 PM
Having an issue connecting to vzw and also getting sim toolkit default message message. Any ideas? I do appreciate the work
I saw a cherry-pick to add thats should fix the issue. I'll add the fix and compile it again and upload it tomorrow. As far as the wifi, are you all using it with safestrap or with phone with unlocked bootloader?
#46 mykalmunlight
mykalmunlight
  • 88 posts
Posted 13 April 2013 - 11:28 PM
Unlocked, CWM to flash. I hit wifi on and it says initializing and flips back to off.
#47 brandon71
brandon71
  • 553 posts
  • LocationKodak, TN
Posted 14 April 2013 - 06:22 AM
unlocked bootloader here it's weird when I used to use cm10 it would go weeks without messing up then all of a sudden it stopped working but wifi fixer fixes it for a while
#48 brandon71
brandon71
  • 553 posts
  • LocationKodak, TN
Posted 14 April 2013 - 07:48 AM
Just noticed I have zero signal but I still get data and voice just shows no bars
Edit: for some reason it will turn blue with bars if I get a 3g signal but it acts like there's no service if I hook up to 4g
#49 brandon71
brandon71
  • 553 posts
  • LocationKodak, TN
Posted 14 April 2013 - 09:12 AM
  36.24KB   24 downloads
#50 hillmom
hillmom
  • 131 posts
  • Twitter:whillmom
  • LocationIdaho
Posted 14 April 2013 - 10:45 AM
Now that the bootloader has been unlocked I would assume things will pick up...I hope!
I hope so too. I really enjoy CM10 and would love to CM10.1 for the M (definitely willing to donate to help development).
#51 mic213
mic213
  • 23 posts
Posted 14 April 2013 - 12:19 PM
Here's a new CM10 build with the cherry pick to fix the sim toolkit message. Let me know if you still have the issue.
  • neckchop, hillmom and brandon71 like this
#52 silence1
silence1
  • LocationVero Beach Florida
  • Current Device(s):Droid M
Posted 14 April 2013 - 03:45 PM
After flashing the CM 10.1 build, previously having unlocked and installed CWM, I too got the sim and toolkit messages. The Sim messages soon stopped, and they're really no problem in any case, but the toolkit message was a pain in the neck. My way out of it was to go into File Manager/System/App and delete toolkit. and that was that. It was labeled tkb (or something like that), but I'd recognized the symbol for toolkit in my Apps bin, although in Apps, the toolkit app could only be force stopped, which did not stop the messages. So, other than the message issue, the build is quick and all works well-no wifi problems, and you have to be sure to use the 20121211 GAPPS, and nothing newer.There do seem to be less bars in my 3G signal (I live in areas where 4G is rare in Vero Beach Fl.), than my Eclipse rom previously had in the same areas in my house. Does your new build offer anything else, besides the fix?
#53 nprevette420
nprevette420
    BlissPop Maintainer
  • Banned
  • 1,626 posts
  • LocationNC
Posted 14 April 2013 - 04:35 PM
Actually, we do have source. Not sure where you've been looking... But anyway, here's a new CM10 build I compiled for everyone to enjoy. No NFC or Wifi Direct, but everything else (wifi, camera, etc.) works. There's gonna be alot more development now that the bootloader is unlocked.
What all is different or changed in the one you compiled other than the cherry pick for sim toolkit?
Need Help? Send me a message
#54 slogar25
slogar25
  • 43 posts
Posted 14 April 2013 - 05:26 PM
The build today works great man. Thank you
#55 brandon71
brandon71
  • 553 posts
  • LocationKodak, TN
Posted 14 April 2013 - 07:39 PM
This fixed my signal issue too thanks man
#56 jbaumert
jbaumert
  • 18 posts
Posted 15 April 2013 - 03:02 AM
@mic213 - Thanks for "waking up" the Razr M CM10 ROM development.  I have a Electrify M that I recently rooted and installed SafeStrap.  Your current ROM (4/14) seems to be working well, but I can't seem to get the camera to work.  Just curious if you would have any insight as to what I should look for to fix it?
#57 nprevette420
nprevette420
    BlissPop Maintainer
  • Banned
  • 1,626 posts
  • LocationNC
Posted 15 April 2013 - 06:07 AM
I never use the stock camera, I've always used Camera ICS and its working fine on this ROM (4/14 build)
#58 jbaumert
jbaumert
  • 18 posts
Posted 15 April 2013 - 08:54 AM
Gave "Camera ICS" a try and no go.  If I understand correctly, SafeStrap is still using the "stock" Electrify kernel.  I suppose it's a problem with the camera modules or libs?
#59 brandon71
brandon71
  • 553 posts
  • LocationKodak, TN
Posted 15 April 2013 - 09:22 AM
Cm10 acts weird in ss it's better if your bootloader is unlocked
  • nprevette420 likes this
#60 nprevette420
nprevette420
    BlissPop Maintainer
  • Banned
  • 1,626 posts
  • LocationNC
Posted 15 April 2013 - 05:55 PM
I've run Camera ICS on stock, stock rooted, FlyingJelly and on different CM10 ROMS (all on SS) and had no problems. After installing it, I deleted the stock camera via TitaniumBackup. Not sure why you are having issues with it but I'm sure someone has the answer to fix it. Maybe unlock the bootloader and install via CWM instead of SafeStrap.
Unlock Bootloader
Fix Boot logo
Custom Recovery
  • brandon71 likes this
