CM10 UNOFFICIAL (BETA) for Droid Razr M (XT907) - Consumer and Developer Edition
162 replies to this topic
#1 dhacker29
dhacker29
    CM Master
  • 49 posts
  • Twitter:dhacker29
  • Google+:davidhackerdvm@gmail.com
Posted 04 December 2012 - 08:14 AM
Well I have been working since release pretty much on getting this to a semi functional state....So here it is CM10 (4.1.2) for the Droid Razr M. This will work on both the retail consumer edition with SafeStrap3 and on the developer edition with CWM or TWRP recovery.
Thanks as always to:
Hashcode for always answering my questions
DroidTh3ory for getting me into this
Epinter for helping me get the ball rolling and fixing wifi and other things
Google for the source and awesome android
CM for all the mods and code fixes
OK first things first:
SafeStrap Version 3 for Consumer edition can be found here:
Follow the install and use instructions here:
Developer Edition:
CWM Recovery:
TWRP Recovery:
Working features:
Data: Should come up in 4G now
Voice Calls: Both speaker phone and handset speaker now
SMS/MMS: You may get random texts from VZWNMN Google for instructions to disable this
WIFI: Working in SafeStrap too thanks to some init*rc magic
Wifi Hotspot: Working
Bluetooth: Appears to work fine tested with headset for calls
Camera: Fully funcitonal
What doesn't work (that I know of):
Wifi direct, NFC
Download link:
GAPPS:
All source modifications can be found at:
As always enjoy and have fun!
  • mattlgroff, neckchop, Trylek09 and 1 other like this
#2 mattlgroff
mattlgroff
    The Dark Knight
  • 2,298 posts
Posted 05 December 2012 - 01:07 PM
Thanks David, I will move this over to ROMs for you lol.
#3 dubsx
dubsx
  • 400 posts
  • Twitter:dubs_x
  • LocationThe OH
Posted 05 December 2012 - 01:13 PM
when you're dhack you just put that sh** wherever you want, let the admins deal with it lol #bigpimpin
#4 dhacker29
dhacker29
    CM Master
  • 49 posts
  • Twitter:dhacker29
Posted 05 December 2012 - 01:30 PM
OK you're the boss sir :)
Yeah that's what I thought :D
  • mattlgroff likes this
#5 zachjeep
zachjeep
  • 172 posts
Posted 06 December 2012 - 01:55 PM
Very smooth, everything that is working is working nicely. Looking forward to future builds.
#6 jvasquezhhi
jvasquezhhi
    Frankensteiner
  • 330 posts
Posted 07 December 2012 - 07:17 PM
with this ROM each an everytime there is update do we need to do the usual wipe clean thing or we can just dirty flash?
#7 dhacker29
dhacker29
    CM Master
  • 49 posts
  • Twitter:dhacker29
Posted 09 December 2012 - 01:15 AM
Cache and dalvik should be fine
#8 marxman3
marxman3
  • 290 posts
Posted 10 December 2012 - 06:31 AM
Thank you for all your work!
Sent from my XT907 using Xparent Blue Tapatalk 2
#9 sunny757
sunny757
  • 16 posts
  • Twitter:sunnymallick
  • Google+:sundaram.mallick@gmail.com
Posted 21 December 2012 - 12:18 PM
rom is working great for me so far - thanks for your work
#10 sunny757
sunny757
  • 16 posts
Posted 23 December 2012 - 03:41 AM
Curious if anyone has bluetooth media working? The device is connecting, but the media still streams from the phone and not the car.
I tried rebooting the device as well as turning the car off as well.
#11 roboton
roboton
Posted 25 December 2012 - 02:53 AM
Also having the same troubles with bluetooth media. Apt-X would be great too. The stock firmware supports Apt-X a2dp bt media streaming.
#12 jrodri64
jrodri64
Posted 28 February 2013 - 10:01 AM
Is anyone else having problems with WiFi? I have spent weeks searching for a fix and all I get is "use WiFi connection fixer" from the Play store. WiFi connection fixer, worked once, but it seems if my WiFi gets turned off at all, it becomes broken again, repeating a Connecting... Authenticating... loop. I like this phone, and I'd love to play with CM10 more, but this WiFi problem is holding me back from using the phone day-to-day as more than just a phone. Any help or suggestions are welcome.
#13 RikRong
RikRong
    Cap'n Slow
  • 2,117 posts
  • LocationNoDak
  • Current Device(s):Pixel 7
Posted 28 February 2013 - 08:44 PM
I think it's still a known issue on this CM10. However, if you want CM based ROM, check out Trippin' Bean. I've been using it for nearly 2 weeks and have not had a problem with wifi.
#14 nprevette420
nprevette420
    BlissPop Maintainer
  • Banned
  • 1,626 posts
  • LocationNC
Posted 01 March 2013 - 12:35 PM
Is this the app you were using?
Need Help? Send me a message
#15 jrodri64
jrodri64
Posted 01 March 2013 - 12:44 PM
Thanks. I've got it on my phone now, and everything seems to be running fine. Still have to test it on my home Wifi though (my work doesn't provide a good signal ;-P )
If it works well, I might have to buy somebody(ies) a drink.
Yes, that is the app I used to try and fix the Wifi problems. It's been linked everywhere when a wifi problem is mentioned for unofficial CM10
#16 brandon71
brandon71
  • 553 posts
  • Google+:tbd7171@gmail.com
  • LocationKodak, TN
Posted 02 March 2013 - 12:06 PM
any new builds coming out? really want a 10.1 haha
#17 jrodri64
jrodri64
Posted 06 March 2013 - 07:57 AM
It occurs to me, that we may have a different understanding of what I meant by "Wifi connection fixer doesn't work for me." What I mean is that my wifi connection is not permanently fixed by this app. When wifi is not working, this app works and I can connect to wifi just fine. If the wifi gets shut off, or the phone sleeps for a certain amount of time, the wifi connection goes bad again and I would have to run the wifi connection fixer app to get working wifi again. To me, this is annoying and I would think is a fixable problem. Does anyone have any input about this? Or is everyone just satisfied with using the wifi connection fixer app each time they turn wifi on?
#18 brandon71
brandon71
  • 553 posts
  • LocationKodak, TN
Posted 06 March 2013 - 09:51 AM
Mine worked great for a day or so then it started acting weird and doing what you said it would turn off the but sometimes it wouldn't turn it back on I got tried of it and switched to flying jelly lol
#19 nprevette420
nprevette420
    BlissPop Maintainer
  • Banned
  • 1,626 posts
  • LocationNC
Posted 06 March 2013 - 12:28 PM
All you need to do is run wifi connection fixer when wifi acts up. Its only a temporary fix, but it works. But FlyingJelly is beast :)
#20 jrodri64
jrodri64
Posted 06 March 2013 - 12:37 PM
See, to my understanding that is not a FIX. It is a temporary patch, and it is annoying to constantly have to use the fixer app. Are you saying that FlyingJelly does not have this same problem for this phone (xt907)?
