[ROM][GSM/CDMA][AROMA][Pdroid] D-WiZ 3.0.1 / D-WiZ 2.0.5 [Safestrap 3]
razr rom jelly bean battery d-wiz dwiz inverted cm10 gsm
41 replies to this topic
#1 dtrail
dtrail
  • 94 posts
Posted 02 December 2012 - 04:42 PM
D-WiZ 3.0.1 [AROMA-BMM] / D-WiZ 2.0.5 [Safestrap 3]
D-WiZ Dev Team Presents:
This rom is a try to provide a rom with less battery drain. Most roms are coming without real battery saving tweaks. So we created our own rom with lots of special tweaks. Some tweaks are based on already existing ones, but we wrote most of them ourself to get the most out of the Razr battery.
- STOCK-Kernel-Version -
Changelog 3.0.1
- Fixed a big bug which was causing battery drain
- Fixed Clock Daemon which caused CPU to stay on higher frequencies
- Added Powertop 2.1
Changelog 2.0.5
- Fixed all bootloops issues - REALLY^^
- Updated source
- Fixed CPU Clock Daemon
- Fixed zipalign, sqlite vacuum
- Fixed kernel parameters
NEWS:
You can flash D-WiZ now directly to your Stock Slot (BMM ONLY for now).
NOTE: Just to be safe, when Aroma finished the installation DON'T reboot!! Untick the box "Reboot device" and click "Finish". Then go back to the main menu, got to "System Keeper" and select "Install Bootmenu to Stock Slot"!!!
D-WiZ is now available with AROMA Installer! Only for use with Bootmenu Manager 0.3.0f
A tutorial for BMM is below
There are several reasons to switch to BMM 0.3.0:
  • Much more tweaks - On virtual slots (e.g. SS3 Rom Slots, BMM System 3-6) some tweaks are causing bootloops and freezes
  • Better battery life
  • Better performance
  • Faster boot process
  • Aroma Installer
Because of that D-WiZ is now available in two different versions: One for Safestrap 3 and one for Bootmenu 0.3.0. The SS3-Version is kind of a "lite-version" because I had to remove several tweaks (were causing lots of issues).
The BMM-Version includes all tweaks, mods and advantages of D-WiZ, but please note that this version will only run on non-virtual slots!
There are several Patches and Add-Ons available in UpdateMe! You can find UpdateMe in the App Drawer.
  • The current version 2.0.3 can cause Bootloops on some devices. If you have that issue, please reboot (2-3 times) until it boots up completely, then open UpdateMe in the App drawer and download the D-WiZ-Init-Patch from Patches section. Flash it in recovery!
  • NOTE: If you are using the Undervolt-Patch: The voltage values will be overwritten by the Inid-Patch! You have to flash the Undervolt-Patch again after applying the init-Patch!
  • D-WiZ is undervolted by default. But you can set lower values for more undervolting. Just download the Undervolt-Patch from UpdateMe patches section and flash it in recovery.
  • NOTE: The values from the Undervolt-Patch values can be too low for some devices and causing crashes and freezes! If you get problems after flashing the Undervolt-Patch, just flash the Init-Patch to reset the undervolt settings. Now you can edit the 70uvoltc file inside the Undervolt-Patch zip Archive and try it out until you find good settings for your device.
The 70uvoltc file inlcudes some line which looks like the following:
0 100 825 > /proc/cpu_control/tweak_cpu
1 200 850 > /proc/cpu_control/tweak_cpu
2 300 875 > /proc/cpu_control/tweak_cpu
3 400 900 > /proc/cpu_control/tweak_cpu
4 600 950 > /proc/cpu_control/tweak_cpu
5 800 1000 > /proc/cpu_control/tweak_cpu
6 1000 1088 > /proc/cpu_control/tweak_cpu
The red numbers are voltage values in mV. Just play around with +25 mV (or +50 mV) and test it. When it works without freezes or crashes you are good to go.
How to use Bootmenu Manager 0.3.0f
  • Download BMM from
  • Download
  • Boot into your Main Rom /Stock Rom
  • Open Safestrap 3 App and tick "uninstall recovery" <--- If you were using SS3
  • Unpack the BMM package on your computer
  • Plug in your device (USB with Debugging enabled)
  • Run the install.bat from BMM folder
Note: If there are displayed some errors while installation, doesn't matter. Just reboot and if you see BMM, it's ok. But if there is no BMM splash screen you have to install BMM again like described above (you may rstart the adb server before to prevent error)
  • Now you have to prepare your rom slots:
  • Reboot and when the BMM screen appears, tick "Settings".
  • Now Select a slot you want to use, open "Boot Mode" and untick: "2nd-Boot", "Kexec", "Overclock".
  • If you want to use rom slot 2, please follow the instructions at the end of this quote (How to protect your 2nd Slot Cache)!
  • If you want to use the rom on your stock slot:
  • If you are coming from another rom, please perform a full wipe, wipe dalvik cache and formant system (in "mounts & format")
  • flash it directly to stock slot!
  • NOTE: Just to be safe, when Aroma finished the installation DON'T reboot!! Untick the box "Reboot device" and click "Finish". Then go back to the main menu, got to "System Keeper" and select "Install Bootmenu to Stock Slot"!!![/B]
  • Continue here when you want to use another Slot (Slot 3-6):
  • Go back and open "Partition Setup".
  • Create the slots (System, Datam Cache) with your preferred sizes.
  • Now go back to boot screen and select recovery.
  • In recovery switch to your created slot (under Recovery Switch)
  • Now flash the rom (as usual: "Install zip...") and enjoy AROMA ;)
  • Now it reboots, hold on in splash screen (select settings or sth like that)
Now you have several options:
  • You can boot into the slot where you installed the rom.
NOTE: There can be bootloops for some reason only after first installation (still have to figure that out) so I would recommend you to use the rom on Stock or second slot.
To set the default slot to boot, boot into rom, open /system/etc/bmm with root browser and edit "bootmenu.prop":
#bootmenu
default=1 <--- Number for your rom slot!
How to protect your 2nd Slot Cache (otherwise it doesn't boot after first time boot)
  • Reboot into recovery
  • Switch to slot 2
  • Flash the rom
  • Download this:
  • Plug in the device and select in recovery. "Advanced Options" --> "Mount as USB storage"
  • Rename the file to "Aromafm.zip" and place it on your internal storage in: /clockworkmod/
  • Plug off the device
  • Select "Filemanager"
  • Now press Menu button in right lower corner
  • Select "Open Console"
  • type in the following
Now you are ready to go with Slot 2!
Please try around and report issues here!
[WIP...] = Work In Progress
Features
- CM10-Based
- tweaked:
  • Auto brightness a bit darker than default JB [WIP...]
  • System-Tweaks for RAM-Management, SD-Card-Boost
-- Hotplug-Governor reconfigured:
  • set as default governor
  • aggressive downscaling
  • 2. Core wake up only if really needed
  • 2. Core sleep faster
  • upscaling more slow
  • scales to higher frequencies if really needed
-- CPU-Tweaks
  • Undervolted
  • Underclocked
  • CPU-Frequecy table: 100, 200, 300, 400, 600, 800, 1000 mhz
  • "CPU-Clock-Daemon" - sets the CPU back to minimum freq of 100 after kernels QoS request (takes a few minutes sometimes / doesn't prevent device from deep sleep)
-- System Tweaks
  • fast and stable UI also on very low CPU frequencies
  • prevent Dirty Writeback Timeout
  • ram management
  • SD-Boost
  • Wifi Power Management On (saves battery, in case you're at home it will set to lower signal strengh but really enough for good signal)
-- Kernel Tweaks
  • for better memory usage
  • faster System
  • power usage
  • default scheduler SIO
- SystemUI: Razr I Launcher & 3DCircle
- OTA Updates (Updates from my Server)
- GAPPS blacked out
- 4.2 Camera
- 4.2 Gallery
- 4.2 Gmail
- 4.2 Keyboard
-- Full automatic and location based power-controll via integrated Llama (WITH finished profiles):
  • automatic switch 2G/3G (Browser or Play Store On: 3G Preferred)(Browser or Play Store or Screen Off: 2G)
  • if connected to WLAN: 2G
  • if entering home: WLAN ON, Data Off, 2G
*profiles can be customized and extended of course
- CM10- & AOKP-Features
- Root & Permissions-Security included
- Modified, improved Version of Google Now
NOTE: This Rom was made for saving battery!!! No overclocking and no super-fast-as-hell-tweaks! If you are looking for sth like that, take another rom! I managed it to get this rom fast and stable also on low CPU usage, just try it!
Llama-Profiles:
Here are Instrucions how to use Llama:
  • Download Zip File:
  • Extract it and copy its content (the folder) to your EXTERNAL SD-Card.
  • Open up the Llama-App and press the "Menu-Button".
  • Select "Import/Export Data" and choose "IMPORT from SD-Card".
  • The profiles are now activated
  • Now you have to select your home Area on the LEFT tab. Press and hold on "Home" and select the option to detect your home location (some minutes should be enough)
  • Last thing is to select you home Wifi. Press the menu button and select settings (or options, dunno how its in English). Scroll down to experimental stuff, then choose check for Wifi Networks". Go back into Llama menu and select tab "Recent", search for you Wifi Network and press and hold it, now choose "Add to area" and select home.
  • IMPORTANT: Now go back into experimental stuff settings and DEACTIVATE the search for Wifi Networks option!
  • There are some "sync-Rules" in the Llama Profiles, they are experimental (background data sync on for 1 minute everx 20 minutes). Just deactivate or delete them if not needed (maybe they are causing partial wakelocks). But before you delete them, just have a look into them, so you'll see how complex this app can be customized!
  • Llama is now configured and active! Now you can add your own rules if you want.
Llama is VERY powerful! Have a look into its options and you'll find an option called "Llama Variables". They can be set to whatever you want. So there are very very complex rules possible! If configured the right way, Llama can also help saving battery a lot! Take you some time to learn how it works.
CAUTION: The profiles are made on a German device!! That means for any users from different countries, you must rename the area names in EVERY rule to your areas location names, or you rename your location areas to German: home = "zuhause", etc.., just look for the names inside the rules.
What works
- almost everything
Camera
Full HD Video Recording
Camera Flash (temp. solution)
Wifi
Data
Bluetooth (almost)
Google Now
Bugs
- Screen Rotation (zooms out shortly)
- No sound in calls while activated Bluetooth (WIP)
- Sound weird bahaviour when using a BT-Headset
- Installation for Safestrap -
  • Safestrap 3
  • Wipe Data, Cache & Dalvik, Format System
  • Flash Rom
  • load the Llama Profiles (above) or make some by yourself
*GAPPS are integrated
If you are updating from prior D-WiZ version, usually just flash the zip WITHOUT ANY wipe - except for update from < 1.0.5, there you MUST perform a full system & data wipe!!
If you are using BMM check the how-to on the top of this post!
This rom runs best when you DON'T change any CPU-related settings!
Please DON'T change any kernel parameters if you are not familiar with this stuff!
NOTE: after the each reboot all CPU settings will be restored to default (NOT Kernel- and other Tweaks!)
Sometimes the kernel sets the CPU to 300 min. If you should notice that, just let it be, the rom will set it back to 100 after some minutes. Also ALL frequencies are undervolted, so it won't eat much battery anyway.
Some suggestions:
  • Go to display and brightness settings, select auto brightness, customize and add 2 or 3 more steps (fill the values continuing)
--- G S M || C D M A ---
[Flash Kernel and Baseband]
Download Kernel / Radio Flasher:
Donation
If you like our work we would appreciate it if you would send us a small donation. Donations make sure that we can go on providing you Roms and other stuff. We are doing all this in our spare time, but thereby resulting cost. We use this money to buy equipment or pay our servers and workspace environment.
If you want to donate use the Donate Button below my name (below Thanks Meter)
Contributors:
Many thanks to all those who donated to us!
  • Jack'o (xda)
  • Wombatino (xda)
  • Palmin (Handy-Faq)
  • nischalnischal (xda)
  • Spectral1991 (xda)
  • blackhawk_LA (xda)
  • Gombi123
  • Drais
  • BlaXXuN/picz (xda/Handy-Faq)
  • HornetRider (Handy-Faq / XDA)
  • maarawoe (XDA)
  • Ferhat
  • Mirko
  • Robert O.
  • Jan B.
  • Burnfaker / Xantian
  • Dennis D.
  • Rafael P.
  • Bopp77
  • Uwe D.
  • Lukas S
  • Torsten V.
  • Faekie
  • inVi
  • Sp_Ark
  • Todi
  • gorgon
  • TM4rkuS
  • Stefan M
  • Jan S
  • Slipi
  • Nizen054
  • prohto
  • gelete
  • Palmin
  • Stefan K.
  • Master__p
  • Ming S. A.
  • Benjamin
  • Saratoga79
D-WiZ Dev Team:
  • dtrail
  • Brunomau
  • Silentjet
  • DumbleCore
  • avalakvista
  • runakai42
  • Xantian
*Thanks to:
  • Whirleyes for his awesome work and kernel modules!
  • Frasertag for answering all my questions!
  • STS-Dev-Team for their work on the Base-ROMs and making them compatible with our hardware!
  • XDA and its great community!
  • XlightwaverX for his awesome development social network site and help!
  • 34muhammet, DerBoris, heblu and 2 others like this
#2 dtrail
dtrail
  • 94 posts
Posted 02 December 2012 - 04:43 PM
Upcoming within the next releases:
Because of our great team, you will get a new level D-WiZ within the next update!
  • System themed (D-WiZ Theme: Really Dark Experience)
  • new mods & tweaks (faster data speed in 2G, 3G and WIFI, less battery consumption)
  • really better performance
  • new apps for special features
  • updated Framework
  • renewed CPU set
  • hopefully it will include our own Tweaks-Manager App for fast profile switching (Performance Mode & Battery Mode)
  • Pdroid (if not in this update, wait for the next one. I am in touch with the Pdroid Dev)
  • Not for sure, but: Stock kernel mod (in progress, that's a surprise Posted Image)
#3 dtrail
dtrail
  • 94 posts
Posted 03 December 2012 - 06:28 PM
Update:
Changelog 1.0.8
- Updated Source
- Fixed boot loops and boot time
- Fixed some bugs which were causing lags
- Fixed a bug with cache
- Fixed memory bugs
- Fixed settings in framework and UI for great performance for ALL launchers!
- Themed framework to D-WiZ-Theme
- Added beats audio engine
- Added Sony Walkman
- Added new bootanimation
- Removed TouchWiz Launcher because of too many FCs (all other launchers have good performance now)
- Updated inverted 4.2 Gapps:
  • AnyDo
  • Gmail 4.2
  • Camera
  • Gallery
- Added lots of new tweaks:
  • Zipaligning user apps onboot
  • set values to great UI performance
  • new kernel parameters for performance and battery life improvement
  • filesystem read/write improved
  • governor values changed to improve battery life
  • Fixed SIO scheduler on startup
  • Sqlite3 database defragmentation on startup
    [']Tweaks for faster data speed especially on 2G (lets you use more 2G to improve battery life)
  • Freeup memory on boot / drop caches for better performance
- Changed Kernel version (Built May 22)
better battery life
better performance
less battery "charging jumps"
faster wakeup
keeps frequencies better than other kernels
Please you ONLY THIS kernel from now! (Download above)
#4 rickw
rickw
    corvette dude
  • 1,951 posts
  • Google+:rickwebb001@gmail.com
  • LocationDelaware
  • Current Device(s):S4 dev edition,moto x dev,Nexus 6
Posted 04 December 2012 - 06:21 AM
Thank you,glad to see new roms coming in
#5 dtrail
dtrail
  • 94 posts
Posted 04 December 2012 - 01:40 PM
The kernel/radio flasher provides you several kernels and Basebands to try. Each one of you should download it and get his personal best combination of Kernel / Baseband. The flash tool icludes a menu selection where you can easily chose your prefere stuff. It also suggests you the recommended choice. So, just go and try! :)
#6 dtrail
dtrail
  • 94 posts
Posted 07 December 2012 - 12:59 PM
First 4.2 Version is ready to go.
Working
  • Data/Wifi
  • Inverted Gapps
  • D-WiZ theme not ready yet, but default wallpaper included
  • Stock Browser doesn't work, but Chrome does and preincluded
  • Camera working with Full HD video recording (no flash)
  • CPU tweaked the same like in default D-WiZ
  • GPS believed to work
  • Screen Rotation
  • Accelerometer
  • Clock / Alarm
  • Good Battery
Not Working
  • No Bluetooth
  • Battery displayed in 10% Steps (trying to fix it by myself)
  • You may find more
Nearly usable as a daily driver :)
Big thanks to the STS-Dev-Team for their work here!!!!
Now testing and then upload...
#7 rickw
rickw
    corvette dude
  • 1,951 posts
  • LocationDelaware
Posted 07 December 2012 - 02:06 PM
great job again,you guys are rockin,lol
#8 dtrail
dtrail
  • 94 posts
Posted 07 December 2012 - 05:43 PM
Link just updated, because there were some issues before...4.2 is just a test phase, so just try aroung with settings.
#9 dtrail
dtrail
  • 94 posts
Posted 07 December 2012 - 07:02 PM
I could use these modules which quarx posted for 4.2 also to fix the camera in D-WiZ 2.0.0 (which is 4.1.2). That means:
- 4.2 Camera fully working (except sphere)
- Video Recording Quality increased (no HD but around 768x576 px, that's much better than before!)
- Front Camera working (1,3MP)
To update it, just download and flash the rom again.
#10 shohag_prince
shohag_prince
Posted 08 December 2012 - 04:55 AM
downloading now . . .
#11 dtrail
dtrail
  • 94 posts
Posted 08 December 2012 - 09:56 AM
sorry guys, 4.2 version was broken....needs some more days
:( But 2.0.0 ist stable and fast
#12 ZackDark
ZackDark
  • 5 posts
Posted 09 December 2012 - 06:12 PM
Awww, just as I was about to give it a spin...
Any words on how the touch-stability is? Last CyanogenMod 10 offshoot I tried had a very wonky accuracy...
#13 dtrail
dtrail
  • 94 posts
Posted 10 December 2012 - 10:58 AM
Touch responsibility is good. Just test it, sorry for the late answer :) There were problems with the current version. On some devices it seems that it undervolted too strong so there were crashes. If you have crashes, please download the rom zip file again and install it, no wpies needed.
#14 ZackDark
ZackDark
  • 5 posts
Posted 10 December 2012 - 06:14 PM
Oh, I will. Thanks for the answer anyway.
Also, what about the 4.2 test? Need any more testers?
#15 dtrail
dtrail
  • 94 posts
Posted 11 December 2012 - 09:15 AM
It's not ready yet...
XT910 - D-WiZ 2.0.0
#16 dtrail
dtrail
  • 94 posts
Posted 11 December 2012 - 04:42 PM
Renwed 2.0.2. There was an error with AC!D, so I removed it. Redownload the rom if you have an issues.
And if you use the undervolt patch and you get issues or crashes and freezes, then edit the included file inside the patch. Compare it to the init.d script 70uvoltc and then test your voltage using small steps about +/- 25mV unitl it runs stable.
To reset it, just flash the rom zip again without any wipes. The default values are stable for all users.
#17 ZackDark
ZackDark
  • 5 posts
Posted 11 December 2012 - 06:25 PM
Thanks, dtrail!
Will try it out as soon as I can (probably flashing it on friday or so).
#18 dtrail
dtrail
  • 94 posts
Posted 19 December 2012 - 06:55 PM
Update online..
Changelog 2.0.3
- Re-Added many tweaks (now without bootloops etc.)
-- Zipalign user apps (improves performance and RAM)
-- sqlite database optimization
-- SDCard wirte/read speed
-- Kernel Seetings completely new!
-- partitions noatime remount
-- renice of processes
-- background Google Spy disabled!
-- net speed improved
- Updated Camera drivers
- Updated Gapps (Play Store, Google Now, Talk)
#19 dpvaldes
dpvaldes
Posted 22 December 2012 - 09:24 AM
Hello,
I just installed the rom, and when I try to restart the cellphone it gets stuck at the X while loading. Colors flash and looks like it's working but it's been like 15 minutes and no response, can't turn of or do anything with the phone.
#20 RazrJ
RazrJ
  • 19 posts
  • Current Device(s):Motorola Razr XT910
Posted 24 December 2012 - 04:29 AM
Hard reset, open recovery, load stock rom. try again if you'd like.
Sent from my XT910 using Tapatalk 2
Also tagged with one or more of these keywords: razr, rom, jelly bean, battery, d-wiz, dwiz, inverted, cm10, gsm
