[ROM] Batakang ROM for DROID RAZR HD - 12/13/2012 - Release 1.00
199 replies to this topic
#161 mattlgroff
mattlgroff
    The Dark Knight
  • 2,298 posts
Posted 03 January 2013 - 07:59 PM
Unless we can raise some money to get matt the device to develop, its always easier if you have the device to test on
Sent from my MZ609 using Tapatalk 2
Much better developers than I could use RAZR HD though. I do scripts and such just sometimes ROMs.
#162 Guest_DirtyDroidX_*
Guest_DirtyDroidX_*
Posted 04 January 2013 - 05:15 AM
That's a good idea! You should start spreading the word. I got 20 on it.
#163 originaldobo
originaldobo
  • 18 posts
  • Twitter:@originaldobo
  • Google+:dobo122884
  • LocationLakeland F.L
  • Current Device(s):Razr HD
Posted 04 January 2013 - 05:22 AM
And if not Matt , nitroglycerin could use one
#164 chazall1
chazall1
  • 35 posts
Posted 04 January 2013 - 06:33 AM
I am in for $25
Believe In "Open Source"
#165 originaldobo
originaldobo
  • 18 posts
Posted 04 January 2013 - 09:16 AM
I started a thread but don't think it was a welcome idea lol
  • heffzilla likes this
#166 dhyamato
dhyamato
  • 94 posts
  • Twitter:dhyamato
  • Google+:+DwayneYamato
  • LocationOrange County, California
  • Current Device(s):Razr Maxx HD, Raspberry Pi
Posted 15 January 2013 - 08:18 PM
Anyone know of any mods for this rom? I'm looking for a "center clock" and "circle battery" icon for the top bar. Thanks for any information.
#167 johnpaul12
johnpaul12
  • 38 posts
Posted 21 January 2013 - 08:10 PM
Does this ROM have any features to customize the size or transparency of the NavBar, or disable it altogether? This is a great phone but the small screen (actual usable size) is a big problem. After always flashing with a DroidX I really wanted to stay stock. However it looks like my choices or flash a custom ROM that allows you control of the NavBar or exchange the Razr Maxx HD for a Galaxy S3.
What ROMs do allow control over the NavBar. I understand CM10 or 10.1 does, but not everything works on that.
Thanks.
I had the same problem. Luckily for you, this guide works for this ROM (i tried it before).
If its too complicated for your. I can send you a flashable one i made (i think i made mine 30 or 32 DPI).
#168 zooyork0721
zooyork0721
    All Around Man
  • 979 posts
  • LocationNew York, NY
Posted 21 January 2013 - 08:14 PM
can you exactly put a link to the one you made? i dont have my computer and forced to use a macbook for the next week <_< so dont think this would work on mac os
#169 johnpaul12
johnpaul12
  • 38 posts
Posted 22 January 2013 - 12:13 AM
I noticed that after you flash, there won't be any status or navigation bar. Reboot again and it should work. Just to be safe, use a ROM Slot to test that it doesn't blow up your phone.
Let me know if this works!
  • afmracer6 likes this
#170 afmracer6
afmracer6
  • 58 posts
Posted 29 January 2013 - 05:19 PM
Thanks for this. This was my one major complaint with the razrhd.
#171 johnpaul12
johnpaul12
  • 38 posts
Posted 29 January 2013 - 08:49 PM
did you use the flashable one or followed the steps? Just want to know if it worked or not!
#172 afmracer6
afmracer6
  • 58 posts
Posted 30 January 2013 - 07:23 AM
I used the flash able one. Works on batakang and on stock rooted no problems. Thanks !
#173 kungpowchicken
kungpowchicken
  • 23 posts
  • Current Device(s):Droid X, Droid RAZR HD
Posted 31 January 2013 - 08:20 AM
For some reason I can't make or take any calls anymore. Texting and internet work just fine but not calling. Any ideas?
#174 oneoutofexile
oneoutofexile
Posted 04 February 2013 - 03:26 PM
After installing this rom, I get the dreaded "Preparing SD Card checking for errors" message, but the SD card is never actually prepared/recognized/mounted in Batakang. I can boot back into Stock Rom, and it appears fine, or even in Safestrap, it shows up fine, so it appears there is nothing wrong with the card, nor the phone hardware. I can also remove the sd card from the phone and see "SD card safe to remove" message, then plug it back in and get the above message. It just never gets mounted. Help me Obi Wan.
#175 kungpowchicken
kungpowchicken
  • 23 posts
Posted 04 February 2013 - 05:50 PM
Well, I figured out what was wrong. My coworker knocked my phone out of my hand so the 1x antenna was damaged. Yay for exchanges!
Now my issue seems to be inconsistent 4G connections. Any ideas?
[EDIT] And this is on a brand new device.
#176 mattlgroff
mattlgroff
    The Dark Knight
  • 2,298 posts
Posted 05 February 2013 - 09:56 PM
might need a new SIM.
If she knocked your phone it could have been damaged.
#177 thecameraman
thecameraman
  • 14 posts
Posted 07 February 2013 - 07:52 PM
So I booted this up with Safestrap and noticed it has SuperSU installed to deal with root permissions. On my stock JB slot I am using Superuser to manage root, and I remember reading somewhere that there can be issues running both at the same time if they aren't configured exactly the same way. Does this make a difference if they are on separate Safestrap slots or does it only matter when they are both installed on the same ROM and active simultaneously?
Thanks for the ROM, I'm excited to try it out.
  • Nubia1 likes this
#178 mattlgroff
mattlgroff
    The Dark Knight
  • 2,298 posts
Posted 07 February 2013 - 08:47 PM
No they are 2 different systems.
#179 undagullu
undagullu
  • 14 posts
Posted 09 February 2013 - 07:15 AM
I'm getting an ota updater notificattion, but when i try to download it it says that there was an error with the download, any help?
#180 wooddale
wooddale
  • 936 posts
  • Twitter:benuti1
  • LocationIl & WI
Posted 09 February 2013 - 11:38 AM
If you are on this ROM it shouldn't let you update In believe you have to be stock rooted
