[ROM] Batakang ROM for DROID RAZR HD - 12/13/2012 - Release 1.00
#21
Posted 02 December 2012 - 06:24 PM
Half tablet UI, half visual disaster.
#22
Posted 02 December 2012 - 06:43 PM
'newskate9', on 03 Dec 2012 - 02:13 AM, said:
I have good eyesight, sue me lolAll, I only did two things: created a new slot, flashed the rom. Reboot / enjoy. OK, that's 4 things, but ya get the pernt!
Matt - tablet UI ROM - I flashed that one in slot 2. No issues, other than I couldn't see it the small print. What's the objective of the tabletUI version? Am I missing something?
Sent from my MB886 using Tapatalk 2
- andlaw likes this
#24
Posted 02 December 2012 - 11:19 PM
'newskate9', on 03 Dec 2012 - 02:45 AM, said:
In the meantime... Tablet UI for meYou too, shall grow old........................................
Test 13 is out now.
#25
Posted 03 December 2012 - 04:40 AM
Test 13 is out now.
Man you're awesome! What are your immediate plans for this rom? I'm guessing with OTA support it'll be easy to get to the newest version? I haven't used a rom with that builtin support yet.
Does this rom have the 4.2 clock with it? It's easy enough for me to install it if it isn't there, but I thought I'd ask.
#26
Posted 03 December 2012 - 05:01 AM
#28
Posted 03 December 2012 - 06:00 AM
#29
Posted 03 December 2012 - 10:06 AM
'koftheworld', on 03 Dec 2012 - 12:40 PM, said:
Yup.Man you're awesome! What are your immediate plans for this rom? I'm guessing with OTA support it'll be easy to get to the newest version? I haven't used a rom with that builtin support yet.
#30
Posted 03 December 2012 - 01:27 PM
Any ideas?
Sent from my DROID RAZR HD
#31
Posted 03 December 2012 - 02:04 PM
#32
Posted 03 December 2012 - 02:17 PM
Creates system.img and writes it.
Creates userdata.img
Writes filesystem on userdata
THEN....
" Error creating data partition! "
Thanks!
#33
Posted 03 December 2012 - 02:49 PM
'chazall1', on 03 Dec 2012 - 10:04 PM, said:
Only issues I can see is the mounting syntax in the updater-script, should be easy enough to fix.Can I install this on the Dev HD edition with TWRP?
#34
Posted 03 December 2012 - 03:17 PM
#35
Posted 03 December 2012 - 03:27 PM
I have tried all basic troubleshooting and no dice.
#37
Posted 03 December 2012 - 04:40 PM
#38
Posted 03 December 2012 - 05:42 PM
'braves10', on 04 Dec 2012 - 12:40 AM, said:
i have the same thing but i dont boot to much so doesnt bother meAfter every reboot, my Razr Maxx HD runs the "android is upgrading" process, and I was wondering if there was something I could do about that. The ROM works fine, it's just that makes the boot time longer. Anyone else having this happen? It's on ROM slot 1 using SS 3.05.
#39
Posted 03 December 2012 - 06:02 PM
Same. I demand a fix!!! Just kidding. Keep up the good work
My Google Play wasn't letting me download apps or updates, but I cleared data for the Google Services Framework, Google Play, and Google Play Services, and after a reboot, all is well.
Feature Request? Option for Reboot under the power menu
#40
Posted 03 December 2012 - 10:37 PM
'seryniti', on 04 Dec 2012 - 02:02 AM, said:
Honestly I have no idea why it does that, and nor do I plan to try to fix it lol. Not broken enough to warranty a fixSame. I demand a fix!!! Just kidding. Keep up the good work
These are indeed 4.2 Gapps on here so we can always expect some weird bugs like that.
It is VERY easy on my ROM to replace the gapps used. Simply replace them in the /gapp/ and /optional/ folder of the ROM zip, and fix updater-script is necessary. I know some people like to switch things out and do custom gapps... so there ya go.
As for Google Now... anyone else experiencing issues?
