[ROM] Batakang ROM for DROID RAZR HD - 12/13/2012 - Release 1.00
199 replies to this topic
#181 mattlgroff
mattlgroff
    The Dark Knight
  • 2,298 posts
Posted 09 February 2013 - 11:45 AM
I'm getting an ota updater notificattion, but when i try to download it it says that there was an error with the download, any help?
Well...there isn't any update for it...*shrug*
#182 kungpowchicken
kungpowchicken
  • 23 posts
  • Current Device(s):Droid X, Droid RAZR HD
Posted 09 February 2013 - 02:37 PM
Is anyone else getting inconsistent 3G/4G connections? I've had the same issue on two different HD's
#183 undagullu
undagullu
  • 14 posts
Posted 10 February 2013 - 06:16 AM
If you are on this ROM it shouldn't let you update In believe you have to be stock rooted
yeah the notification would keep reappearing every 5 mins but it seems like it stopped now
#184 mrellsworth
mrellsworth
  • LocationMinnesota
  • Current Device(s):Droid RAZR MAXX HD
Posted 28 February 2013 - 06:19 AM
Forgive me for asking something that has probably already been asked. Every time i do a search for something I never seem to find what I want.
I would like to get your ROM installed but I'm not sure about the creating the slots etc...
I just had to downgrade back to stock and re root using the droid_razr_hd_utility1.10.zip then apply the 0.7.2 update and restore root. I originally was going to try and get the stock JB ROM and keep root after but was unable to find it and the OTA wont install.
Can you point me to some instructions that go over how take a rooted maxx HD with the 0.7.2 update and install your ROM that I just downloaded. I assume the different slots that I see mentioned are for dual booting, I would be interested in knowing how to do that also.
Any assistance would be much appreciated and I apologize for probably breaking every known forum rule by asking something that I'm sure I could find if I had enough time to read a million posts.
Thanks,
Nick
#185 wooddale
wooddale
  • 936 posts
  • Twitter:benuti1
  • LocationIl & WI
Posted 28 February 2013 - 06:33 AM
Try reading here
  • mrellsworth likes this
#186 mrellsworth
mrellsworth
  • LocationMinnesota
Posted 28 February 2013 - 07:19 AM
Ok,
I think I have the slot thing now. In these instructions from way above it says I need to be on JellyBean already. I can't seem to find a download for this can you give me a link to one please.
Be on Jellybean on the DROID RAZR HD (Non-Dev Edition). This can be the leaked or official.
Make a ROM Slot in any ROM slot.
Please go to SS3 main menu.
Choose 'Wipe' and then 'Factory Reset'.
Install the .zip (flash it!) :)
Then flash the latest
Reboot into the ROM.
Thanks,
Nick
#187 razrallday
razrallday
  • LocationUSA
  • Current Device(s):XT926
Posted 28 February 2013 - 07:56 AM
Ok,
Thanks,
Nick
(ICS incremental update)
(JellyBean update)
The OTAs have been having a problem downloading as of late. Credit goes to Satman80 for those files, both flashable in recovery from rooted ICS. Don't forget to temp unroot/restore root between flashes. Happy roming. If you've already got the 6mb ICS update OTA then you don't need to flash it again go straight to JellyBean.
#188 mrellsworth
mrellsworth
  • LocationMinnesota
Posted 28 February 2013 - 09:44 AM
Thanks for these.
I have tried to install them and can't seem to get them to work.
Any suggestions?
The other day I used reverted back to stock ICS then used the Droid Rzr 1.10 utility and reobtained Root. I then temp unrooted and allowed the 0.7.2 update to install then reobtained root to make sure I still had it. Then the instructions I had said to temp unroot and allow the JB OTA to install. I can't get passed that and all other JB roms seem to require that I be on a rooted copy of JB before trying any of them. Do I need to wipe everything from my maxx first? In between I did run setup for market etc... and have been using it.
thanks,
Nick
#189 mrellsworth
mrellsworth
  • LocationMinnesota
Posted 28 February 2013 - 12:48 PM
Ok, I got it.
I went back to the beginning and wiped and flashed back to ICS.
Obtained root with the droid razr 1.10 utility
installed Voodoo OTA keeper and temp unrooted
installed flashed ics incremental update from posting above
restored root (just to make sure I still had it) then temp unrooted
installed the delta ota blur from link above
restored root with Voodoo
installed safestrap 3.05.17
installed recovery
booted to recorvery
created slot
installed custom rom
awesome!!!
I made the slot 3Gig. Do I really need to make it that big or can I get away with 2Gig?
thanks razrallday for the links etc...
thanks wooddale for pointing me in the right direction for slot info
Nick
#190 michael7168
michael7168
  • 11 posts
  • Current Device(s):Droid Razr HD, Samsung Galaxy Nexus
Posted 03 March 2013 - 05:24 AM
I made a couple rim slots; each slot is 1gb. As far as I know it is just for data. For instance when I make a backup the data size is close to 900mb with 58 apps installed with a couple huge sized games. The entire backup size is 1.3gb so that is why I assume the size allocation is just for user data.
#191 smeekteek
smeekteek
  • 224 posts
Posted 26 March 2013 - 06:56 AM
So far, buttery smooth. Great work as usual. Thanks!
#192 seryozha
seryozha
  • Current Device(s):RAZR HD, GSM GNEX
Posted 01 April 2013 - 12:44 PM
will this work if im the stock latest OTA? Unrooted
#193 Memnoch73
  • 5,016 posts
  • Current Device(s):Pixel 3XL
Posted 01 April 2013 - 01:02 PM
You will need to be rooted. That and safestrap are the only way to install custom roms. But if you are on the latest ota and unrooted you are stuck there til a new root method is found
#194 power9999
power9999
  • 36 posts
Posted 09 April 2013 - 05:45 PM
Hi installed the gapps as ¿
can be installed TWRP fails me
Or how you have to install?
Thank you!
#195 smeekteek
smeekteek
  • 224 posts
Posted 10 April 2013 - 03:01 PM
It doesn't say it in the OP so I just wanted to verify that I can install this on a SS slot if I'm running 4.1.2?
#196 Memnoch73
  • 5,016 posts
Posted 10 April 2013 - 03:03 PM
Yup... That's how it was done before last Sunday. :P :)
#197 BladeRunner
BladeRunner
    Chatroom Tech Support
  • 347 posts
  • LocationMaine
Posted 10 April 2013 - 04:38 PM
Thank you!
mount system in twrp before flashing
#198 mattwheat
mattwheat
  • 86 posts
Posted 17 April 2013 - 08:41 AM
Hey Matt, I found a post you made with a link to your new RAZR HD utility 1.2 I think on another guys post with his utility in Spanish , you posted and said test ..... well I did .... worked freaking great and the fastest I've used yet.
I was unlocked, rooted on 4.1.2 and had flashed and backed up and flashed till I felt as if my phone was lagging to much. So I downloaded your new utility and ran it.... worked great. I'm still unlocked, I ran the install TWRP option and it rebooted stock and then it booted into TWRP. I then backed up then flashed a ROM and it asked me if I wanted to install Super SU since I was not rooted yet. Of course I did and then it booted fine. I'm still unlocked, rooted on 4.1.2 and running stock with BIG DX jelly extreme theme.
NO LAG.
MUCH APPRECIATION FOR ALL YOUR WORK...
#199 mattwheat
mattwheat
  • 86 posts
Posted 17 April 2013 - 08:43 AM
Oh and I can't find the post again so if you could post that utility for every else to profit I'm sure it would be appreciated.
#200 blackrayne
blackrayne
  • 22 posts
  • Current Device(s):razr maxx hd
Posted 02 August 2013 - 10:33 AM
Can you flash this ROM if on 4.1.2??
