{ROM-RETAIL} Stock Debloated Deodexed JB
23 replies to this topic
#1 jvasquezhhi
jvasquezhhi
    Frankensteiner
  • 330 posts
Posted 29 November 2012 - 07:08 PM
THIS IS MY FIRST TRY
This is my first ever ROM. Also lot of Googleing and asking questions in numerous farums. it is Stock and could be a good base for anyone Themer or ROM builder with more knowledge than me.
Features
Working 4G at boot
Deodexed
Deboated
SuperSU
Inverted Facebook (thanks to
over at The MIK MIK )
Inverted Dropbox (thanks to rujelus22 over at rujelus22.com)
Inverted Google Music ( thanks to rujelus22)
Inverted Play Store (thanks to Travp624 over at the rootzwiki.com)
Inverted Google Now (thanks to Travp624)
Inverted Youtube (thanks to Travp624)
Inverted Google Voice (thanks to Travp624)
Google Gallery (syn your pictures from picasa)
BUGS
It don't have root (just root it again)
Sorry about that I don't know how to add Root to a Custom ROM
None that i know of as yet please report any
Flashing
Must be using safestrap 3.05.20
JV1.0.1 Download link
just learned how to root it so trying it out post new link tomorrow now going to work sorry
Boot into safestrap press Boot Options
Press ROM-Slot-1
1GB be enough for most people
Press Wipe and Wipe Cache, Dalvik Cache, Factory Reset, System
Press Install and find the BadAssJV1.01.zip in your external sd card
Confirm Flash
Enjoy
It takes about 90 sec to flash and about 3 to 5 mins to boot first time
Screenshot
Edited by jvasquezhhi, 30 November 2012 - 08:15 AM.
  • neckchop and minimalistdave like this
#2 jvasquezhhi
jvasquezhhi
    Frankensteiner
  • 330 posts
Posted 29 November 2012 - 07:09 PM
Change log
JV1.0.1
Hopefully added root
Added Custom Bootanimation
Added City ID
JV1.0
First release
  • mykalmunlight likes this
#3 jvasquezhhi
jvasquezhhi
    Frankensteiner
  • 330 posts
Posted 29 November 2012 - 07:10 PM
the files is still uploading just wanted to get the thread started
#4 lownslow200sx
lownslow200sx
    OSE-DEV/THEMER
  • 355 posts
  • Google+:Lownslow200sx
  • LocationRocky Mount, NC
Posted 29 November 2012 - 08:16 PM
BUGS
Did you add the su binary for Superuser to xbin?
#5 jvasquezhhi
jvasquezhhi
    Frankensteiner
  • 330 posts
Posted 29 November 2012 - 09:42 PM
I added it to the wrong folder :unsure: i added it to bin not xbin well i learned now thank you! will be fixing it and uploading it soon
#6 lownslow200sx
lownslow200sx
    OSE-DEV/THEMER
  • 355 posts
Posted 29 November 2012 - 09:49 PM
No problem, let me know if you need anymore help I don't mind at all.
  • jvasquezhhi likes this
#7 jtommyj
jtommyj
  • 181 posts
Posted 01 December 2012 - 12:07 PM
Im new to the Motorola / Safestrap setup coming from a Samsung fascinate. so if i install this rom in slot 3 or whatever can i delete the stock rom or is that a no-no ?
Thanks,
Tom
#8 jpnestel
jpnestel
  • 15 posts
  • Twitter:@jpnestel
  • Google+:jpnestel
  • LocationLas Vegas, NV
Posted 01 December 2012 - 12:32 PM
Yeah don't delete the stock. Not even sure if you can but that's gonna be your safety net.
#9 jtommyj
jtommyj
  • 181 posts
Posted 01 December 2012 - 12:56 PM
Ok thanks // so then if i need to keep it i should make it as small as possible since as soon as i added this rom i get the error msg. running out of space. Is that correct. just keep a stripped down stock for emergency ? thanks for your help
#10 jvasquezhhi
jvasquezhhi
    Frankensteiner
  • 330 posts
Posted 01 December 2012 - 11:47 PM
Thanks,
Tom
ya dont delete the stock ROM.. but what you could do to save space and RAM speed... is do a factory reset.. (which will delete all you apps that are not stock) and thand flash any rom you want... it improves on speed..
  • jtommyj likes this
#11 jtommyj
jtommyj
  • 181 posts
Posted 02 December 2012 - 12:05 PM
Ok thanks much for the advice
#12 LarrysAndroid
LarrysAndroid
  • 62 posts
  • Current Device(s):Motorola Droid Razr M
Posted 06 February 2013 - 07:05 PM
Can we install Play Books, Play Magazines, Play Movies&TV, and My Verizon Mobile back onto this? Where are those apps?
And does this ROM work with the official JB. I currently run stock JB 4.1 ROM. Yes I am rooted. Just asking about the current status of this ROM.
Thanks! :)
#13 clienterror
clienterror
  • 75 posts
Posted 06 February 2013 - 09:58 PM
Thanks! :)
I'm not sure about the Verizon stuff but all the Google apps can be installed from the play store np.
#14 RikRong
RikRong
    Cap'n Slow
  • 2,117 posts
  • LocationNoDak
  • Current Device(s):Pixel 7
Posted 07 February 2013 - 02:41 AM
I used Root Explorer to make copies of all the Verizon apps and saved them on my external SD, in case I decide to load a debloated ROM that does not have these. I have yet to load a custom ROM and find out if these copies work, but it's just a something I thought might work to be able to use the Verizon apps, especially Backup.
#15 LarrysAndroid
LarrysAndroid
  • 62 posts
Posted 07 February 2013 - 03:49 PM
Features
Working 4G at boot
Deodexed
Deboated
SuperSU
BUGS
Flashing
Press ROM-Slot-1
Confirm Flash
Enjoy
Screenshot
Do we NEED to have an external SD carD?
#16 RikRong
RikRong
    Cap'n Slow
  • 2,117 posts
  • LocationNoDak
Posted 07 February 2013 - 08:35 PM
It saves room if you save the zip to your external SD. It also makes it easier to find and flash if you save it in the root folder of your external SD.
#17 Blahman
Blahman
  • 24 posts
Posted 09 February 2013 - 01:23 PM
Easier if you use Titanium Backup
#18 jvasquezhhi
jvasquezhhi
    Frankensteiner
  • 330 posts
Posted 10 February 2013 - 12:57 AM
I think i would answer all 3 with this... if you want to ever flash it to stock than yes... sd card is a must... since you would have to wipe the internal sd card to flash this into stock.
#19 proteus12
proteus12
  • Current Device(s):Razr M
Posted 13 February 2013 - 10:43 PM
Are the Verizon apps included in this rom or they have been removed ?
#20 jvasquezhhi
jvasquezhhi
    Frankensteiner
  • 330 posts
Posted 14 February 2013 - 08:34 AM
which verizon app you need? most of verizon apps can be downloaded from play store... smart actions is intact...
