Need some help with XT910 - can not access recovery
1 reply to this topic
#1 darko1515
darko1515
  • LocationMontreal
Posted 08 October 2014 - 07:59 PM
Hy. I have a razr Maxx XT910. Today I tried to restore a backup of a partition that I made with safestrap to my stock partition. After restoring was finished, I reboot my phone and it will not start. I can not go into recovery, the only thing that it does is: if I long press power button the red Motorola logo appears for 10 sec. and  the phone does nothing, it shows like it is turned off.
Any suggestions?
I tried volume up + power, volume down + power, volume up+volume down+power but no luck. I do not have any more buttons to push frown.gif.
Edit1: I manage to connect my phone to rsd light (with my screen still off) and when I tried to flash a sw.xml, I get an error 'The phone failed to switch to fastboot mode' - result 'FAIL'.
I have no idea what to do next.
#2 livinginkaos
Posted 09 October 2014 - 05:55 AM
Hold vol - and then press and release the pwr button while continuing to hold the vol - button, then release. That should put you in fastboot. If you are using rsd, be sure you are using at least a 6.1.X version and that the fxz is from the build you were on or newer. The xml from the fxz requires modification. The easiest thing if you do not know how to do so is to just use SamuriHL's RSD flasher and it will do that for you.
sent from my G3
