[ROM] [Bionic] Blurry_Maxx_v4.4.1 + [Theme] Silverized (updated 4/5/13)
1300 replies to this topic
#1 eye__dea
eye__dea
    Developer
  • 814 posts
  • LocationWisconsin
Posted 24 November 2012 - 08:13 PM
The Blurred 3ffectz Team Presents:
Blurry_Maxx_v4.4.1
Features:
-Debloated
-Deodexed
-init.d Support at Boot
-init.d Scripts (thanks timmy10shoes, sparkman216 and Nitroglycerin33)
-Overclocked at Boot - both 4 and 5 slot devices
-Extra Modules - Governors and Schedulers
-1% Battery Icon
-Center clock
-Modified Extended Toggles (thanks superdallas and t3t3droid)
-Reboot power options (thanks rootuser and timmy10shoes)
-New Boot Animation
-Blue Notification Light (thanks vtwinbmx)
-Blurry Settings (thanks sparkyman and teamfuzion)
-Native WiFi Tether Hack (thanks TeamLiteSpeed)
-Apps2sd (thanks Timmy10shoes and Nitro)
-4.2 Keyboard
-Inverted Apps
-Moved some apps to /data partition
-Google Now
-Changed default wallpaper
-Beats with modified DSP Manager (thanks BigDaddyHicks)
-Added a few apps (thanks timmy10shoes)
-Blurryzips on /sdcard
-Added Wallpapers
-Added Tones
Screenshots:
Blurry 4.3.1 Overclocked ROM Link:
Blurry 4.3.1 Non-OC ROM Link:
Blurry 4.3.2 OC Patch Link:
Blurry 4.3.2 Non-OC Patch Link:
Blurry 4.4.1 Patch via the OTA Updater
***To flash 4.4.1--make sure you have flashed 4.3.1 and rebooted at least once, then flash 4.3.2, and finally take the OTA update to 4.4.1 or if your already on 4.3.2, just flash the OTA.
How to Install Blurry Maxx:
Boot into Safestrap v3.11
Wipe Data / Factory Reset
Wipe cache and dalvik cache
Wipe System
Install Blurry_Maxx.zip
Reboot System
Initial install takes some time
Let the 1st boot settle for 5 minutes
Reboot phone
Go to developer options...turn on GPU rendering
Blurryzips - Read the Readme file in /sdcard/Blurryzips
Enjoy
Things to know:
-Governors and Schedulers are loaded and optimized to the extreme.
-Built for performance and battery life.
-ROM Mods will be included in 2nd post. Check back often.
-Animation Manager: With this app you can change your window and keyboard animations. Instructions: pick what animations you want to change, make the zip and try to get back to the lockscreen before it reboots (if not, you go to stock recovery...just reboot system to safestrap). In safestrap, flash the new zip you made...it will be on the root of the sd-card.
Known Bugs:
-none
*Changelog for Blurry_Maxx_4.3.2 (3.24)*
-Bug fix
*Changelog for Blurry_Maxx_4.3.1 (2/24)*
-Edited the theme
-Added some apps
*Changelog for Blurry_Maxx_v4.1.2 (2/11)*
-Edited some scripts
-Added some apps
-Few minor changes
*Changelog for Blurry_Maxx_v4.1 (2/8)*
-Tweaked framework-res
-Tweaked Systemui
-Tweaked keyboard
-Tweaked lockscreen
-New Boot Animation (thanks jaekar99)
-Edited and added some scripts
-New apps
*Changelog for Blurry_Maxx_v3.8 (1/7)*
-New 1% battery Mod
-New system settings (thanks TeamFuzion)
-New Blurry Settings
-New Inverted apps (thanks darkhorse and Nitro)
-Themed Dialer (thanks ZKK007)
-Apps2sd works (thanks Timmy10shoes and Nitro)
-Deleted some apps
-Added some apps
-Added Blurryzips to sdcard
-Updated all apps
*Changelog for Blurry_2.5 (12/19)*
-Modified a few init.d scripts (thanks sparkyman and timmy10shoes)
-Modified Build.prop (thanks sparkyman)
-Added extended toggles
-Added center clock
-Deleted a few apps and added a few
-Improved battery life
-Cleaned up the lag wake up issue
-Few other minor things
*Changelog for Blurry_1.4 (12/1)*
-Modified a few init.d tweaks (thanks sparkyman216 and timmy10shoes)
-Added Reboot power options (thanks rootuser and timmy10shoes)
-Deleted a few apps and added a few apps
-Changed a few icons to JB
-Battery life has improved without hindering performance
-Absolutely no lag noticed
-Fixed a few bugs
*Big thanks to Hashcode for everything he does*
**Thanks to timmy10shoes and deduct for all the support and testing**
**Thanks to team noctural...
***Blurred 3ffectz Team Members: eye__dea and Timmy10shoes***
  • karthakon, vtwinbmx, brainwash1 and 8 others like this
#2 eye__dea
eye__dea
    Developer
  • 814 posts
  • LocationWisconsin
ROM Mods:
Theme: Blurry_Silverized
Blurry_Silverized_Maxx Link:
Screenshots:
Blurry_Maxx_stock Theme (Erases Silverized):
Inverted Gtalk (thanks nitro) - Delete old Gtalk first:
How to Flash the Theme / Gtalk:
Boot into Safestrap v3.11 (Thanks Hashcode)
Select Blurry Rom Slot
Wipe Cache and Dalvik
Install the Blurry_silverized.zip file you downloaded
Reboot system
What is Themed:
-Browser
-Contacts
-Messaging
-Phone
-Settings
-Systemui
-Framework-res
-JB Font
-Boot Animation (thanks JaeKar99)
*If running Nova launcher: you need to go into Nova
, Look and feel,
theme, select stock jellybean first, then select Default. This will make sure all the themed icons turn silver / blue.*
**Thanks to dubs_x, sparkyman216, and b_boy for their expertise in theming. Thanks to deduct and timmy10shoes for support and testing. Thanks to ZKK007 for his dial icons.**
Battery Mods (flashable zips):
Thin Circles (thanks nbeebe24 & DLuke):
Screenshot:
Link:
Gauge (thanks he_stheone64)
Screenshot:
Link:
Andy (thanks reverepats)
Screenshot:
Link:
Circle Percent (thanks he_stheone64)
Sceenshot:
Link:
Thin Vertical Bar (thanks reverepats)
Screenshot:
Link:
Dotted Circle (thanks reverepats)
Screenshot:
Link:
Thick Circle (thanks pendo)
Screenshot:
Link:
Digital Percent
Screenshot:
Link:
Digital Percent with Green Charge
Link:
Stock Blurry
Link:
Instructions: How to Flash Battery Mods
Install the Blurry_Maxx-xxx.zip file you downloaded
Reboot system
RazrM Mods (flashable zips):
Circle Widget and Launcher (may lag):
Messenger:
*Thanks twinkyz1979*
Visual Voicemail (flashable zip):
Visual Voicemail:
Jelly Bean Font (flashable zip):
Jelly Bean Font:
Right Side Clock (flashable zip):
Right Side Clock (removes center clock):
Soft Key Mod (thanks vtwinbmx)
Link:
Screenshot:
No wipes needed. Just install.
*If for some reason they are not your style...flash Blurry_stock- 2.5 / maxx.*
  • smegun and jmjevomr like this
#3 eye__dea
eye__dea
    Developer
  • 814 posts
  • LocationWisconsin
Posted 24 November 2012 - 08:14 PM
Updates:
11/24/12: Blurry_1.0 uploaded
11/24/12: Added RazrM Mods to Mod section
11/24/12: Added Visual Voicemail Mod to Mod section
11/25/12: Added 6 Battery Mods to Mod section
11/25/12: Added 4.2 Camera to Mod section
11/25/12: Added Inverted Google Now to Mod section
11/26/12: Added HTC Droid DNA Boot Animation to Mod section
12/01/12: Blurry_1.4 uploaded
12/01/12: Pulled Battery Mods for updating to Blurry_1.4
12/01/12: All Battery Mods are updated to Blurry_1.4
12/01/12: Added Jelly Bean font to Mod section
12/06/12: Added Digital Percent Battery Mod to Mod section
12/06/12: Added Wireless Tether Instructions to Mod section
12/12/12: Added Blurry_Silverized Theme to Mod section
12/16/12: Added Silverized Extended Toggles to Mod section
12/19/12: Blurry_2.5 uploaded
12/19/12: All Battery Mods are updated to Blurry_2.5
12/19/12: Uploaded Blurry_Silverized_2.0 Theme to Mod section
12/22/12: Added Stock Blurry Theme (erases silverized theme) to Mod section
12/22/12: Added Right side clock to Mod section
12/23/12: Blurry_maxx uploaded
12/25/12: Uploaded Blurry_Silverized_Maxx Theme to Mod section
12/25/12: Added Stock Blurry_Maxx Theme to Mod section
01/03/13: Added Soft Key Mod to Mod section
01/07/13: Blurry_Maxx_v3.8 uploaded
01/08/13: All Battery Mods are updated to Blurry_Maxx_v3.8
01/14/13: Uploaded Blurry_Maxx3.8-Silverized Theme to Mod section
02/08/13: Uploaded Blurry_Patch_V4.1
  • jmjevomr likes this
#4 rocketsaucev2
rocketsaucev2
  • 447 posts
Posted 24 November 2012 - 08:21 PM
Gotta love safe strap 3. I'll give this a spin
#5 deduct
deduct
  • 234 posts
Posted 24 November 2012 - 08:29 PM
This is exciting! Been using it for awhile now and love the speed and excellent battery life. Highly recommend this rom to those that love stock base. Deodexed so I can flash all of my favorite mods onto it. Excellent work eye dea.
#6 Guest_HOFFA_*
Guest_HOFFA_*
Posted 24 November 2012 - 09:04 PM
Just installed it. Looks good. Took only 45 seconds to boot up. I will give you my test hats in 1 hour of Testing.. So far looks great.
#7 Guest_HOFFA_*
Guest_HOFFA_*
Posted 24 November 2012 - 09:07 PM
Ok Enough said. Solid. Even my Icarus Hd Phonebook works. love it screens coming next.
#8 mrlolli
mrlolli
    Put Member Title Here
  • 763 posts
  • LocationNowhere
Posted 24 November 2012 - 09:19 PM
Looks sweet! Downloading now...
Sent from my DROID BIONIC using Xparent Blue Tapatalk 2
Nice job on the signature, jl90...thanks!
#9 Guest_HOFFA_*
Guest_HOFFA_*
Posted 24 November 2012 - 09:21 PM
lol love the Avatar Glass Joe.
#10 mrlolli
mrlolli
  • 763 posts
  • LocationNowhere
Posted 24 November 2012 - 09:23 PM
Lol thanks...i fight like him in real life
#11 kc69
kc69
    Droid Elite
  • 1,057 posts
  • Google+:kcmj6969@gmail.com
  • LocationEast Bernard TEXAS
  • Current Device(s):RAZR HD
Posted 24 November 2012 - 09:34 PM
DLing now it sounds really cool . im hoping that wifi tether works. think you could add the factory tether mod in the next update eye_dea. it works in icarus and its really much better than the tether app speed wise and foxfi went and got greedy with the last update.any way thanks for another choice in the bionic quiver, soon as it finishes dling on my slow3gconnection ill flash it and give ya a sitrep. thanks, Casey
TEXAS state of mind
#12 eye__dea
eye__dea
    Developer
  • 814 posts
  • LocationWisconsin
Posted 24 November 2012 - 09:41 PM
I don't tether, but the app should work fine. I will look into the factory tether mod and add it to the mod section. Let me know how it goes.
#13 deduct
deduct
  • 234 posts
Posted 24 November 2012 - 09:42 PM
WiFi tether is included and works great.
#14 eye__dea
eye__dea
    Developer
  • 814 posts
  • LocationWisconsin
Thanks man!
#15 eye__dea
eye__dea
    Developer
  • 814 posts
  • LocationWisconsin
Posted 24 November 2012 - 09:43 PM
Wow...45 seconds. That is crazy fast.
#16 mrlolli
mrlolli
  • 763 posts
  • LocationNowhere
Posted 24 November 2012 - 10:03 PM
tibu restored very fast...i also like how you included this with the rom. in fact, everything seems very snappy with this so far. beautiful work, thanks!
#17 deduct
deduct
  • 234 posts
Posted 24 November 2012 - 10:26 PM
My blurry homescreen
#18 Guest_HOFFA_*
Guest_HOFFA_*
Posted 25 November 2012 - 01:41 AM
Screens Not Important. It All looks the same. This rom is Boss. Been Banging I Heart Radio Like I have Never done Before. Love it. 5 Hats Ty and good job Devs.
#19 Guest_HOFFA_*
Guest_HOFFA_*
Posted 25 November 2012 - 01:43 AM
Lol words fans?
#20 Bulldog88
Bulldog88
  • 93 posts
Posted 25 November 2012 - 04:46 AM
Sweet rom I like it so far!!! Excellent work!!
