[ROM][Razr-GSM][4.1.2] Wizzed Bean RLS2- Clean, Fast Light
#21
Posted 23 December 2012 - 09:22 PM
Sent from my XT910 using Tapatalk 2
#22
Posted 28 December 2012 - 01:54 PM
Noob question though, when creating the partition for SafeStrap it only gives the option for 1GB, 2GB or 3GB. Then when the rom is running there is 6GB of unused internal storage and I've run out of space for apps. Is there a way to enable all the internal storage for just this one rom?
#23
Posted 28 December 2012 - 04:12 PM
Make a 3 gb partition in safestrap for it and you should be fine with a decent amount of apps!This rom is working great! So much faster than stock ICS it's unreal.
#24
Posted 29 December 2012 - 10:59 PM
#25
Posted 30 December 2012 - 02:50 AM
What section on SafeStrap should i flash this into?
#26
Posted 30 December 2012 - 02:51 AM
- vampire444 likes this
#27
Posted 30 December 2012 - 02:55 AM
#28
Posted 30 December 2012 - 12:25 PM
U can flash into any ROM slot................I had installed in ROM slot 2..........I hope u shouldn't any issue
Thanks (:
#29
Posted 30 December 2012 - 03:57 PM
First time posting and new in this staff of custom roms, sorry for my lack of experience.
I try to install with Safestrap 3.11 because it is imposible with 3.05 for my XT910 Maxx. I started the flashing. Then an error appear saying "error in /sdcard/wizzed bean"
Status 7
So i dont know what i am doing badly
I hope someone can help.
Thanks in advance
#30
Posted 31 December 2012 - 07:44 PM
Any fix for this?
- nico1234 likes this
#31
Posted 31 December 2012 - 08:23 PM
Try toggling your auto brightnessWith this rom, the buttons aren't lighting up
Any fix for this?
#32
Posted 01 January 2013 - 03:08 AM
That worked, thanks (:
Ne problem -.-
I keep getting the same SMS sent to me every like 5 minutes...is that the rom or the service provider that i'm with
#33
Posted 01 January 2013 - 06:42 AM
Sent from my GT-N8013 using Tapatalk HD
#34
Posted 01 January 2013 - 02:23 PM
Its your carrier
Thanks, it eventuelly stopped (:
Awesome rom and thanks for all the quick responces!!
#35
Posted 01 January 2013 - 06:15 PM
#36
Posted 02 January 2013 - 07:17 PM
#37
Posted 03 January 2013 - 09:10 PM
#38
Posted 06 January 2013 - 05:26 PM
i know i did something wrong but i dont know what, i followed the instruccions but maybe im missing something.
hope someone will know how to fix this.
#39
Posted 08 January 2013 - 06:47 AM
thank you!
#40
Posted 08 January 2013 - 06:49 AM
Hi, i have an issue with the ringtones for calls and notifications, only have 2 options, There's a way to fix it?
thank you!
I don't know how to fix this, but they come and go on my phone when i restart it
