How to Block KitKat 4.4.4 Update
block update avoid update stop update
Best Answer angstrommcd , 29 September 2014 - 09:24 AM
Thanks John,
I couldn't have figured that out without you.
- Ang  :rolleyes
Go to the full post
9 replies to this topic
#1 angstrommcd
angstrommcd
Posted 18 September 2014 - 11:11 AM
I have read too many horror stories about the KitKat 4.4.4 update.  My phone tries to update daily and I keep putting it off.  Does anyone know how to stop or block the update notification?
#2 johnthehillbilly
Posted 18 September 2014 - 11:17 AM
Use titanium backup..... Freeze the updater....:)
#3 johnthehillbilly
Posted 18 September 2014 - 11:18 AM
BTW ... What device do you have.... It may make a difference on what exact "updater" you have to freeze...
#4 angstrommcd
angstrommcd
Posted 22 September 2014 - 02:11 PM
Thanks, John - I'll look into Titanium.  I've got the Droid Razr M
- Ang
#5 angstrommcd
angstrommcd
Posted 23 September 2014 - 01:21 PM
Hi John,
I installed Titanium Backup.  I'm not sure how to find the updater.  I see I will need to upgrade to the pro version to freeze - not a problem.
- Ang
#6 droid-man
droid-man
  • Current Device(s):RAZR Maxx HD (XT926M)
Posted 26 September 2014 - 07:09 AM
My son's XT926m keeps prompting for an update as well. I don't know if it is for the KitKat update or not, but, it's rooted and I don't want to screw it up by taking the update and he doesn't care if it has KitKat or not. It's one of those with that darned locked boot-loader. Anybody no the exact name of the file or app to freeze to stop the annoying update attempts?
Wherever you go, there you are...
#7 livinginkaos
Posted 26 September 2014 - 08:19 AM
As long as you are not updated to the recent builds, you can get that thing unlocked then you don't need to worry about root.  Then if KK doesn't work for him/you, you can downgrade (with specific instructions- don't just flash old firmware).
Follow the thread HERE
#8 johnthehillbilly
Posted 27 September 2014 - 04:02 AM
Hi John,
- Ang
Look for "MotorolaOTA x.x" (under the backup tab)should do the trick for you...:)
  • bigjailerman and angstrommcd like this
#9 angstrommcd
angstrommcd
Posted 29 September 2014 - 09:24 AM   Best Answer
Thanks John,
- Ang  :rolleyes
  • johnthehillbilly and bigjailerman like this
#10 bigjailerman
bigjailerman
  • 31 posts
  • Twitter:Dave L
  • Locationon the hop
  • Current Device(s):razr M, S4 I545
Posted 17 December 2014 - 06:07 PM
Look for "MotorolaOTA x.x" (under the backup tab)should do the trick for you... :)
I, glad I found this..thank you
....its never too late to learn :google
