[How To] Downgrade Motorola Devices
5 replies to this topic
#1 SamuriHL
  • 44,535 posts
Posted 17 September 2014 - 04:27 AM
OMAP : NO
2012 devices (razr hd/m) : Yes, with caveats. Read.
Warning - Must be unlocked
These devices may be downgraded if special care is taken with the FXZ you're downgrading to. Certain partitions can NOT be downgraded, so if you attempt to flash the FXZ as is, you will brick. Yes, even if you're unlocked.
1) Use my RSD Flasher or House of Moto tools with the universal option.
Or
2) Extract the FXZ zip file. Edit the xml file with an editor like notepad++, and remove the lines for flashing the gpt and tz partitions, and save the file. Open the newly modified xml file with RSD Lite, and flash away.
2013 devices (moto x, Droid ultra/maxx/mini) : NO
Attempting to downgrade these devices post 4.4.2 will likely end up with a brick. On certain forums you'll see posts pop up now and again discussing some foolproof way of doing it that totally worked for the person posting it. And that may be true. They may have been able to do so. The thing is, it's like a game of Russian Roulette. For every person that it supposedly works for, there's several more that brick trying it. My advice, don't try.
2014 devices (moto x) : Um what?
What the hell you gonna downgrade to? The things aren't even out yet! Lmao. When they do come out, the answer is almost assuredly NO to downgrading.
  • ibolski, matjmonk, livinginkaos and 4 others like this
#2 androidmaster
androidmaster
  • 9 posts
  • Locationpakistan,karachi
  • Current Device(s):DroidRazr HD XT926 KK
Posted 10 June 2017 - 12:09 AM
 Hello Bro
I HAVE MY MOTOROLA DROID RAZR XT912
I HAVE UPGRADED To OFFICICAL 4.1.2 JELLYBEAN
i want downgrade it...
to 4.0.4 ICREAM SANDWICH  Or 2.3 GINGER BREAD
PLEASE HELP ME HOW I CAN DOWNGRADE MY DROID RAZR XT912 :(
PLEASE REPLY ME BETTER AND FAST :(
#3 SamuriHL
  • 44,535 posts
Posted 11 June 2017 - 12:24 PM
It's not possible unfortunately.
#4 androidmaster
androidmaster
  • 9 posts
Posted 13 June 2017 - 02:40 AM
:( really :(
#5 androidmaster
androidmaster
  • 9 posts
Posted 13 June 2017 - 02:42 AM
i can get page plus 4G or 3G on my jellybean stock 4.1.2 Droid razr XT912 ?
#6 androidmaster
androidmaster
  • 9 posts
Posted 18 June 2017 - 01:16 AM
hello guyz please can you help meee
im using droid razr xt912 running jb official stock
i have otg cable
but its not working on my droid razr
i download OTG SUPPORTED ? APK
so i scan so result = SUPPORTED
i cant understand what i do showing supported and not working any thing
i try another usb not work i try mouse . keybourd , usb , and all otg supported things
not working i check my otg on my brother tablet so all things working howwwww!!!!!!!!!!!!!!!!!!!!
===============================================================================                                    :( why only not working on me ??? :(
please help meee
