Razr M XT907 Bootloader Question
Posted 16 September 2014 - 08:18 PM
I am currently on the bootloader for 4.2.1 unlocked, rooted with working SU running CM11 of Feb. I would love to update my CM build to one with the new Theme Engine but keep getting a Status 7 error which I think is due to the old bootloader. Is it possible to update my bootloader?
I know ADB and RSD and if pointed in the right direction am very capable of doing any flashing or using any tools needed.
Thank you in advance for any input.
Posted 16 September 2014 - 08:32 PM
Posted 22 September 2014 - 04:09 PM
I had a chance to have a few hours of me time a couple nights ago. Got my Unlocked XT907 updated with zero issues. Only took about an hour including the downloads.
Rooted with CM11 M10 installed and all setup.
Big thank you to the Dev that put that thread and those tools all together. Much respect. Sorry about being all Noobish.
Sent from my DROID RAZR M using Tapatalk
- Shark666 likes this
Posted 22 September 2014 - 04:25 PM
Just a quick update for anyone interested.
You should update to the 4.4.2 Bootloader. Update your TWRP to v2.8.0.0. There are more roms and support on the KitKat bootloader compared to the JellyBean bootloader. Just my opinion, you don't have to update to it, but one big difference is the annoying screen dimming issue is gone in the KK bootloader builds.
If you want to upgrade and need help, there are threads on here and other forums on how to or just shoot me a PM and I'll help you out.
Need Help? Send me a message
Posted 22 September 2014 - 05:21 PM
- nprevette420 likes this
Posted 22 September 2014 - 06:00 PM
I did a full update using RSD lie a few nights ago. Bootloader and all. Thank you for the offer.
You should checkout my rom has a few quirks to work out, but over all it is awesome.
Posted 17 January 2016 - 06:21 AM
