Gsm/utms Xt910 Razr Owners Get Leaked Ics Help
Posted 25 January 2012 - 01:58 AM
1. Download the file
2. Rename it to "update.zip" and place it on the root of your external SDCard
3. Go into Motorola's Recovery
4. Go! Go! Go!
i did this went to recovery and im guessing i select update from sd which i choose when i did that it checked file said ok updating and i got this:
"assert failed: file_getprop("/system/build.prop". "ro.build.fingerprint") == "MOTO/XT910_RTGB/umts_spyder:2.3.6/6.5.1-167_spu-15-M2/1326788504:user/release-keys" ||
file_getprop("/system/build.prop", "ro.build.fingerprint") =="MOTO/XT910_RTB/umts_spyder:4.0.3.6.7.1_spu-ICS-DUMMY/1326788614:user/release-keys"
e:Error in /tmp/sideload/package.zip
(status 7)
installation aborted"
Luckly it didnt brok my phone.
my phone is a unmodifyed XT910 running
System verion 651.73.30.XT910.Retail.en.EU
Android verison 2.3.5
Baseband Version U_03.1C.85P
Webtop Version WT-2.0.0-113
Kernel Version 2.6.35.7-gece0826
AP flex version GAS_EMEA_USASPDRRTGB_P042
GAS_EMEA_USASPDRRTGB_A019
Build number 6.5.1-73_SPU-11-M1-2
do i have do something first so i can update to ICS?? please help
Posted 25 January 2012 - 02:47 AM
you can get in on where it says:
To: Blur_Version.651.167.20.XT910.Retail.en.EU + BP 03.1C.91P + WT 2.0.0-139 + Bootloader 0A.6C
Download:
- mattlgroff likes this
Posted 25 January 2012 - 03:14 AM
Ok i got that file do i do the same rename it to update copy to sdcard and do motorola restore??? dont want to make a mistake and brick my phoneYou need to be on Blur_Version.651.167.20.XT910.Retail.en.EU
where it says:
you can get in on
Download:
Posted 25 January 2012 - 05:16 AM
Posted 25 January 2012 - 06:30 AM
Posted 25 January 2012 - 06:39 AM
i get assert failed, and a status 7 error :/ and i have tried to remove root and make total reset on phone. anyone know this probs ? and how to fix it ?
i have dont it now and it is sweet do what post says earlier
Download: "
put that on SDcard and do motorola restore from sdcard which will upgrade you to 2.3.6 then update to ICS file from that
my phone messed up with when i loaded it had to clear my user data now its fine
Posted 25 January 2012 - 07:06 AM
Posted 25 January 2012 - 07:15 AM
its an upgrade you will be on 2.5.5 that is 2.5.6 you have 651.73 that is 651.167can i downgrade firmware then ? i have 651.73.30.xt910
167 is a bigger number than 73
so you upgrade to that version and then upgrade again to ICS
as i said i did this worked fine till i loaded ICS and the display was messed up and it kept crashing android when i tried to unlock the screen but i all my $#!+e was still installed so i did a factory reset memory wipe from recovery console and now ICS is fine
Posted 25 January 2012 - 07:33 AM
Can I make the same process with my version:
Branding: RETAIL en.BR
Market Segment: LATAM
Version: 651.73.250
Android Version: 2.3.5
Tkks
Posted 25 January 2012 - 07:43 AM
yes sorry i made a mistake there its 2.3.5 and the update then goes to 2.3.6 NOT 2.5.5 and 2.5.6Can I make the same process with my version:
Version: 651.73.250
Tkks
as for your update i dont know mate where do you live the BR part is showing non EU from what i know
Posted 25 January 2012 - 08:26 AM
Posted 25 January 2012 - 08:57 AM
this is the file i used it will update you FROM 651.73.30 SPU11M1-2 en_EUwhere do i find the 651.167 ? the only links i see on page mirror and ur link, is 651.73 :/
TO 651.167.20.XT910.Retail.en.EU
From 651.167.20.XT910.Retail.en.EU you can then update again to ICS
Posted 25 January 2012 - 09:31 AM
Posted 25 January 2012 - 10:00 AM
Posted 25 January 2012 - 11:07 AM
Looks to be en.EU, so probably notThis update won't work on Asia Retail, will it?
Posted 25 January 2012 - 11:12 AM
Version: 651.73.250
Since i'm pretty sure that i won't be able to flash this i'm thinking to flash via rsd the US gsm version, receive the OTA Update an then flashing this...
Anyone knows if this is posible, will the rom from EU wrok with my GSM XT910???
Posted 25 January 2012 - 11:26 AM
i,m actually running this rom
Version: 651.73.250
Anyone knows if this is posible, will the rom from US wrok with my GSM XT910???
I Have the same version.
I asked thekholkand he saidthis:
"Try toflashit,itwill not workifyourpreviousROMreflashSimplywaitfor TheArcticorICSto comeout!"
I'll test and post the result
Posted 25 January 2012 - 12:29 PM
this
The file from the link should be flashed using rsd right?
Posted 25 January 2012 - 01:05 PM
On the cdma version when its a leak we first make sure we are stock then we use stock recovery to apply the leaked update unless what y'all have is a fast boot file. I know y'all are GSM and its different I'm just throwing it out there cuz I would assume its the same but could be wrong
Donate $10 or more to our Phones For Devs Giveaway and get a Custom Forum title and help the Make a wish Foundation details here: http://www.droidrzr....-custom-titles/
Posted 25 January 2012 - 02:46 PM
right to save confusion this is what i did
1) i downloaded that file and renamed it update.zip then copied it to the root of the phones SDcard
2)turned phone off
3)held both volume keys and power
4)selected motorola recovery
5) got android symbol pressed volume keys again to get menu
6) selected update from sdcard select update.zip
7) once phone updated select restart phone
8) delete update.zip from sdcard
9) copy the ics file to Root of sdcard renamed it update.zip
10) do steps 2-7 again
11) have ICS
This apears to ONLY work on GSM NOT CSMA and seams to only work if you have EU retail version
any futher questions just ask and i will try and help you
at no point do you need to plug into pc other than to transfer the zips to the sdcard
