ROM! AMBP( ANDROID MOTOROLA BLUR PROJECT! Release 3!01/15/13
Razr I
132 replies to this topic
#41 lucky58
lucky58
Posted 19 November 2012 - 10:49 PM
Edit: i think everything is finished. I found how to change icons for all android native app, the naviguation bar will now be as on all nexus phones, battery icon also, and i hope signal, i dont know yet, need to test, but motorola's .png are tooooo much numerous and different... i also had to manage hdpi and xhdpi resolutions...
deleted the apex launcher, included official pure stock 4.0.4 ICS launcher, feel free to uninstall it with root access if needed to replace it by the launcher of your choice.
i re added Livewallpaper option and added Beam live wallpaper, the official ICS one.
Re added Quickoffice to be able to manage all your files on your Razr i
Deleted Talk, download it straight from the play store, as it had a bug on the version previously linked.
Deleted some other useless apk papi92 had forgotten to remove.
i'll upload it when i have time to.
Oooo :) Hopefull waiting now. Thanks Fabylous !
#42 base1130
base1130
Posted 20 November 2012 - 05:04 AM
i'm thinking to make a version with stock ICS 4.0.4 launcher, pure android, and let you install the Apex launcher if needed, as i will use the rom like this for myself :)
I'm currently working on status bar, all launcher icons are now ICS themed, need to change battery and signal icon, then i'll try to find how to mod the special naviguation bar :)
@Faybulous:
If I have understood everything alright, you want to create an ROM that is similar to the original pure Android source version? So that means only the pure Android, no extra Apps and so on? If yes, that would be great. I like the "only-source-style". So that I have only the Apps which are coming with the source Android version by default. Root permissions would be great, too.
Is that your plan?
#43 gadzio
gadzio
Posted 20 November 2012 - 07:55 AM
do you think guys it's possible to add the MIUI "Network Assistant" (also known as the Monitor Application) ? this one : http://i.minus.com/ib1brCi7PvEobK.jpg or is it specific to miui and won't work on other rom? Coz it's pretty useful to block network access to some apps.
#44 Faybulous
Faybulous
  • 15 posts
Posted 20 November 2012 - 09:27 AM
Hi all
So yes the aim is to be as close as possible than the official ICS rom.
i have had a problem with top icons, it is more complicated than on my others android phones as the motorola's files are numerous and special for the theming part.
so i'll first upload a version with the android ICS look for all apps, but not for the notification and nav bar for the moment.
You will have a light rom, rooted, with official 4.0.4 launcher, which is super super fast, far away from apex or any other launcher.
i added a few things as Geniewidget from google, live wallpaper Phasebeam, deleted useless apps.
I ll work deeper inside the look once jelly bean will be released ;)
Thx for all comments.
  • lucky58 and climax like this
#45 caesee
caesee
Posted 21 November 2012 - 07:09 AM
thx for u work.I will try i later
#46 stoudamire
stoudamire
Posted 21 November 2012 - 08:07 AM
Unfortunately, I do not have both time and the necessary skills to help you.
However, I really appreciate your work on this device and really hope some other devs will support you in the near future.
Keep up the good work.
#47 mattlgroff
mattlgroff
    The Dark Knight
  • 2,298 posts
Posted 21 November 2012 - 09:41 AM
I suggest using the AOSP soft-keys, it will really help make it look more AOSP-like.
#48 papi92
papi92
    Developer
  • 727 posts
  • Twitter:afox2015
Posted 21 November 2012 - 10:45 AM
I am lol. Waiting on Fay to be done
Sent from my XT890 using Tapatalk 2
#49 Faybulous
Faybulous
  • 15 posts
Posted 21 November 2012 - 11:33 AM
im uploading on my DropBox the First base, with all apps with pure android look, some google apps, official 4.0.4 launcher, and a few things in addition compared to the rom you uploaded.
I didnt touched notif and nav bar yet, i dont have enough time at the moment ;)
  • climax likes this
#50 Faybulous
Faybulous
  • 15 posts
Posted 22 November 2012 - 11:30 AM
https://www.dropbox....lousVersion.zip
  • HSD-Pilot and climax like this
#51 HSD-Pilot
HSD-Pilot
  • 303 posts
  • LocationGermany
  • Current Device(s):RazR
Posted 22 November 2012 - 11:48 AM
:ph34r: Downloading now, will flash it later @ work :ph34r:
Soundcloud <> Bassgrow
#52 Igorrullez
Igorrullez
  • 5 posts
  • LocationSão Paulo
  • Current Device(s):Razr I
Posted 22 November 2012 - 12:53 PM
Downloading too...
Until the really AOSP comes to we!
I need a cyanogenmod! lol
#53 HSD-Pilot
HSD-Pilot
  • 303 posts
  • LocationGermany
Posted 22 November 2012 - 01:30 PM
It's running fine, pretty smooth :ph34r:
Well done...
#54 papi92
papi92
    Developer
  • 727 posts
  • Twitter:afox2015
Posted 23 November 2012 - 09:27 AM
Hey updates will be slow now. One more will come tomorrow with battery mod and pulldowns. A lot of my time will be spent trying to get aosp done with others. I'll do my best to post it here before anyone else!
#55 tryu1734
tryu1734
  • Twitter:T_1734
  • Google+:tryu1734
Posted 23 November 2012 - 11:35 AM
friend, can you upload on google drive, cause i can't download that, please???
#56 Arceles
Arceles
  • 5 posts
Posted 23 November 2012 - 11:58 AM
Yeah... dropbox is near impossible to use for downloading the ROM....
#57 Faybulous
Faybulous
  • 15 posts
Posted 23 November 2012 - 02:05 PM
download is fast for me...
i hadnt time to upload it these last days, so excepted if anybody share it on another link, i think you will have to deal with this... sorry :)
#58 papi92
papi92
    Developer
  • 727 posts
  • Twitter:afox2015
Posted 23 November 2012 - 05:14 PM
Uploaded release 2 to batakang. Please donate to batakang if you appreciate the fast dls mattlgroff provides this site for free to me and I appreciate it.
  • HSD-Pilot and asterix007 like this
#59 Arceles
Arceles
  • 5 posts
Posted 24 November 2012 - 05:02 AM
The ROM is indeed fast, thanks a lot :D (took a whole night to download the rom though :( )
#60 Arceles
Arceles
  • 5 posts
Posted 24 November 2012 - 06:19 AM
For some reason I can't seem to resize widgets with ADWLauncherEX in this rom... there is something related to it or it's just me?
Also tagged with one or more of these keywords: Razr I
